Like Tree22Likes
Old 11-18-2012, 06:38 PM
  #11446
R/C Tech Elite Member
Jamison R's Avatar
Trader Rating: 66 (100%+)
Originally Posted by jonnymorrow
Guys what are these wheel cones used for? Part # TD714002
http://www.team-durango.com/part-inf...artNo=TD714002
They are for old style wheels
Jamison R is offline
Old 11-18-2012, 06:39 PM
  #11447
jmackani's Avatar
Trader Rating: 14 (100%+)
They are used with the older pin style wheels instead of the newer hexes. They make nice wing washers also.
jmackani is offline
Old 11-19-2012, 05:51 PM
  #11448
TJames987's Avatar
Trader Rating: 11 (92%+)
Default B44.1 or Durango 410?
I'm thinking about switching to the Durango buggy. The B44.1 is an ugly bastard and handles terribly. I noticed the durango has gear-diffs versus the b44 uses ball diffs. For Durango owners do you find that the gear diffs are less maintenance as the ball diffs in the b44 tend to become crunchy?
Also is the high dollar 410V3 worth the extra $ versus the "R"? Whats different?
Thank's ya'll
TJames987 is offline
Old 11-19-2012, 06:11 PM
  #11449
Trader Rating: 520 (100%+)
Thank's ya'll
Gear diffs are way less work, as long as you set the mesh correctly, basically when you need to rebuild the B44 diff, I check mesh and touch up oil level.... Definitely worth the extra coin for the V3, BB shocks and many other hidden upgrades.
flame56mx is offline
Old 11-19-2012, 10:33 PM
  #11450
Default 21 degree hubs
Have some of these 21 degree hubs arrive. Will be trying in the next few days.
I expected the stock ones to be 19 degree, but after measuring them against the 21's the STD ones are 4 degrees less , must 17 degre.
WillF is offline
Old 11-20-2012, 06:08 AM
  #11451
79kmc's Avatar
Thank's ya'll
I had a b44.1 for a few months and now i just bought myself a dex410 off a mate and what a difference it is to drive, it handles so much better than the ae and it's way more predictable, the r hasn't got any upgrades buy the time you buy all the necessary upgrades for it you might aswell of bought the 410v3, cause your going to spend at least another couple of hundred bucks for the all the upgrades you want
79kmc is offline
Old 11-20-2012, 12:11 PM
  #11452
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Is anyone running the Exotek wider hubs? If so what are you using wheel nuts? Just doesn't seem like enough threads for my confidence. Lmk, thanks.
Bman's 3XNT is offline
Old 11-20-2012, 05:41 PM
  #11453
DBL15's Avatar
Originally Posted by wyl03
i have the 8-carbon chassis and was running it with the plastic side pods. i didn't have any issue with the drive shaft popping out. (knock on wood)
if you do that and use a shorty pack, you should really be able to knock off 150~200g off the overall chassis weight.
good thinking mate i will look into it as well thanks for the tip
DBL15 is offline
Old 11-20-2012, 07:03 PM
  #11454
Could anyone tell me any issues with the original high spec 410 buggy?
Have an option to buy a NIB one and if I get a good deal might take it.
Would adding the new big bores pretty much make it as good as the new 410 V3?
thorns is offline
Old 11-20-2012, 09:01 PM
  #11455
slow_jun's Avatar
Trader Rating: 14 (94%+)
expensive before and not so pricey now.
V3 changes
-BB shocks -$59/set (2 pcs)
-Ti Coated shock shafts $12.50 /set ( 2pcs)
-More shock holes on towers for more options (F/R) -$27-30 each
-Rear Hangers (Insert type) more options $24 plus inserts $ 4.99
-Side Composite pods
-less Allu options such as Ti rods, rear gearbox inserts,Allu shock mounts,steering link, steering mounts, Mid drive gear plate.
-Kuhler bodies
-14MM hex ( old 12mm/Pin rims are phased out).
-HD Cups
-Longer Diff cups/ Paired with shorter center shafts.
http://www.team-durango.com/race-cars/dex410v3/
slow_jun is offline
Old 11-22-2012, 01:28 PM
  #11456
Hello everyone!
Okay, so I use to be really into RC back when I was younger. I have been out of the hobby for almost a decade now, and am sort of rusty. I'm a poor college student, and have very slowly pieced together a dex410r v2 over the past year and a half. I came really close to selling it to go with something cheaper, but stuck it out, and I am now FINALLY finishing it up.
My last hurdle seems to be finding the right sized pinion. I'm running a Tekin RS and their matching motor, and due to the position of the connections on the motor and limited body space, I'm pretty sure that I can only mount the motor in one position. The problem I have, is that with the stock spur gear, the motor won't get close enough for and 18t pinion to mesh. What do you guys recommend I do? I was trying to save money and went with the basic RS over the PRO, so I need to be sure that it doesn't get too toasty under there. Won't be doing any serious racing, but will be at Unser and Mhor from time to tim. Should I get a larger pinion and spur? I'm lost haha...
benjamin27 is offline
Old 11-22-2012, 01:31 PM
  #11457
Jamison R's Avatar
What turn motor? What size spur do you have now. Most people I see using the rs over the pro overheat if motor is under a 10.5
Old 11-22-2012, 01:45 PM
  #11458
I have an 8.5t and whatever spur came with the kit... Am I out of luck?
Old 11-22-2012, 01:47 PM
  #11459
Jamison R's Avatar
No you can run them. Just get the gearing right and turn the current limiter down to 50. I would guess 23-24 pinion if you have a 87 spur
Old 11-22-2012, 01:52 PM
  #11460
I just took a look and you are right, its an 87t spur.
