Like Tree22Likes
Old 11-14-2012, 02:57 PM
  #11431
Originally Posted by INFERN0
If you've ever bent a front inner hinge pin on the front arms try this, dig up an old OFNA hex driver or similar hex wrench that you don't need. Using a dremel cut off disk cut to length of your stock pins.
These will be stronger by far as hardened tool steel will sheer before bending most likely saving your front aluminum pin support.
I do this now and my pins stay true, the one I pulled out I thought was good was slightly bent meaning fine camber and toe adjustments were not accurate.
I'm hoping Durango releases hardened hinge pins.
3mm hard steel dowel pins from McMaster-Carr work great and are cheap. People have been using these for a long time on the DESC410R SCT truck. Also, the stock outer rear hinge pins are weak on this car. RC8 outer rear hinge pins are a drop-in replacement and they are much stronger.
Stealth_RT is offline
Old 11-15-2012, 05:48 PM
  #11432
DBL15's Avatar
just wondering is anyone running the carbon chassis that the after market companies like 8 Racing has built for this buggy
as we all know its not the lightest buggy on the market?
thoughts about the carbon chassis from anyone running them?
DBL15 is offline
Old 11-16-2012, 09:01 AM
  #11433
INFERN0's Avatar
I would imagine a full cf chassis would be slightly lighter with a bit more flex. It would most likely work very well on rough surfaces. How thick are they?, 4mm?
INFERN0 is offline
Old 11-16-2012, 12:11 PM
  #11434
Jochim_18's Avatar
Originally Posted by Cloaked
Hey Guys
So I managed to pick up a DEX410 for $150 AUD with Spares which I thought was a pretty good deal.
Im just wondering, what are the essential spares or hop up parts I should get for this?
Im guessing:
Front A Arms
Spare Spur Gears
Clutch Pads
Shock O Rings
Anything Else?
Any essential mods I should get?
Ill be running in 4WD Stock with a Trinity D3 17.5 motor, HW Xerun 2.1 60amp ESC and steering will be done via a SAVOX 1257TG.
Pretty much the same electrics as the 22SCT in my Sig.
Appreciate the help fellas!
Front and rear arms
Rear Hub Carrier (Very weak)
Outer hinge pin (Very wear I reccommend get the lunsfornd Titanium hinge pins)
Jochim_18 is offline
Old 11-16-2012, 01:26 PM
  #11435
Autocratic's Avatar
Trader Rating: 26 (100%+)
Tresrey says to use the aluminum side pods with the carbon chassis, but I wonder how much flex it would have if it was ran with the plastic pods. Could possibly be a good option for a loose track with minor jumps.
Autocratic is offline
Old 11-16-2012, 01:34 PM
  #11436
Konich's Avatar
You have to run the Aluminum sides, feel free to run the plastic sides and when the center shaft pops out you'll know why. Without the sides you can twist the car in your hands with little efffort.
The CF chassis is 4mm and works well on rough tracks as well as high bite clay tracks. Almost all the Tresrey drivers run the CF chassis over the aluminum. In fact I might be the only one running a AL DEX410. I do have a complete CF roller ready for this season though
Konich is offline
Old 11-16-2012, 01:38 PM
  #11437
Autocratic's Avatar
Hell, I've popped the center shafts out with the stock chassis and plastic pods. Maybe I need the aluminum pods...
Old 11-16-2012, 01:40 PM
  #11438
Konich's Avatar
Or run the V1 slipper setup. Why Durango screwed with the center shaft setup I have no clue. Good thing my V1 is dialed!
Konich is offline
Old 11-16-2012, 01:48 PM
  #11439
Autocratic's Avatar
Do tell. I didn't know there was a difference. I'm also wanting the two-way slipper that's on the website, but they haven't released any details about it.
Old 11-16-2012, 02:48 PM
  #11440
Trader Rating: 79 (99%+)
I run a alloy V3...
Raul Garcia is offline
Old 11-16-2012, 10:11 PM
  #11441
dangerwr's Avatar
But are you gonna get permission to race? The Unser track is pretty sweet and plenty big for Wheeler!
dangerwr is offline
Old 11-16-2012, 11:11 PM
  #11442
jackcarter3's Avatar
I am running the atomic carbon conversion. I like it. It's strong and light and there is more room. It takes like 2months to get though as they are made to order and they aren't cheap.
jackcarter3 is offline
Old 11-18-2012, 04:30 PM
  #11443
DBL15's Avatar
yeh i seen them as well and were custom made to your order
what side pods are you running with this chassis
just thinking about setting up a light weight version for stock 17.5 for a event
DBL15 is offline
Old 11-18-2012, 04:57 PM
  #11444
Trader Rating: 44 (100%+)
i have the 8-carbon chassis and was running it with the plastic side pods. i didn't have any issue with the drive shaft popping out. (knock on wood)
if you do that and use a shorty pack, you should really be able to knock off 150~200g off the overall chassis weight.
wyl03 is offline
Old 11-18-2012, 06:36 PM
  #11445
Trader Rating: 31 (100%+)
Guys what are these wheel cones used for? Part # TD714002
http://www.team-durango.com/part-inf...artNo=TD714002
jonnymorrow is offline
