Like Tree22Likes
Old 10-28-2012, 01:46 PM
  #11341
boudin4evr's Avatar
Trader Rating: 18 (100%+)
i now have big bores for my car, and STILL not a v3!
dont hesitate, its an awesome car!
boudin4evr is offline
Old 10-28-2012, 02:26 PM
  #11342
Trader Rating: 79 (99%+)
Guys, whoever is on the east coast, and going to get hit by this storm, be safe. I live right on the water in CT. We are going to get pounded..
Raul Garcia is offline
Old 10-28-2012, 02:43 PM
  #11343
JosephBlack's Avatar
Originally Posted by ryanpatrickgore
What about the older dex410 model? A few if them for sale around here.
Would I be netter buying the new one?
What are the main differences between the 2?
Ryan,
If you starting out from scratch, a new V3 is the only way to go. Absolutely no reason to go with the R version. You will spend way more in upgrades to the R then you would just gettin the V3. Now, if you looking at a 2010 spec with big bores and other upgrades, then go for it. But otherwise V3.
JosephBlack is offline
Old 10-28-2012, 03:40 PM
  #11344
tobamiester's Avatar
Trader Rating: 360 (100%+)
Yeah Raul, been prep'ing all day for it. Be Safe buddy.
tobamiester is offline
Old 10-29-2012, 08:23 AM
  #11345
Has anyone found that their V3 front shock tower is about 1 layer of CF thicker than the rear? And quite difficult to fit in place on the front bulkhead?
Gump is offline
Old 10-29-2012, 04:25 PM
  #11346
Potoczak's Avatar
Trader Rating: 120 (100%+)
Hey guys what setup should I start with for a high bite indoor carpet track???
Potoczak is offline
Old 10-29-2012, 09:30 PM
  #11347
Hi guys I'm in the process of swapping my diff stock o ring to Kyosho p5 but I don't seems to be able to remove my sun gear out of the diff case, any trick on that? I think this is sounds silly... It's tight in there
frozencone is offline
Old 10-30-2012, 01:41 AM
  #11348
Adam's setup is a good start: http://www.oople.com/forums/showthread.php?t=90385
Chris-s is offline
Old 10-30-2012, 07:04 PM
  #11349
boudin4evr's Avatar
the hex ends of outdrive were supposed to be filed a little so that the gear slips right on and off!
to get it off:
turn outdrive over and put it into a socket, hit outdrive with a punch, itll bend eclip put then youre golden! dont forget to file or dremel off the hex part of outdrive when you go back together!
Old 10-30-2012, 08:40 PM
  #11350
P6
so the b44.2 is coming the usual cf bling and its gonna be +8 longer 3mm narrower , whats gonna make the dex410v3 better than the b44.2 besides the adjustments capability i have a dex210 love it for the adjustments it kills my brothers b4.1 in every way without him throwing money into adjustment parts
P6 is offline
Old 10-30-2012, 10:42 PM
  #11351
Rob Phillips's Avatar
Finally! I got to run my DEX-410 and I absolutely love it. I used Ryan Lutz's RRoC setup (minus pistons and the old rear block) and it was pretty much good to go. I think I could use a little more pack in the dampening, but overall it was awesome. Can't wait to get some more laps with it.
I think this is my new favorite...
Rob Phillips is offline
Old 10-31-2012, 04:02 AM
  #11352
Trader Rating: 126 (100%+)
You can use the same shock parts, wheels/tires, with your DEX210. You can also put rubber boots on shocks/outdrives. No ball diffs to rebuild. Probabaly the most important thing is you won't have the same buggy as everyone else has! Dare to be diff.
kwiksi is online now
Old 10-31-2012, 04:08 AM
  #11353
R/C Tech Elite Member
Jamison R's Avatar
Trader Rating: 66 (100%+)
No ball diffs to rebuild or repair. Im seeing alot of diff work when I see someone with a b44.1 Only time will tell how good the new AE buggy is.
Jamison R is offline
Old 10-31-2012, 05:40 AM
  #11354
Maxxingout's Avatar
Trader Rating: 17 (100%+)
The dex410 is actually longer than the b44.2 by a little over 1in. The diff thing is a bit more of a pain -to a point- then the gear diff, but in the end they both require maintenance. As far as "better" well that as you know is more up to the driver/setup than it is the rc. Now as far as strength & tuning capabilities goes will be more of the question that needs to get answered. Though we have the b44.1 to kinda go off of the b44.2 is a bit different so only time will tell.
Maxxingout is offline
Old 10-31-2012, 07:46 AM
  #11355
dMITIj's Avatar
Hello guys.
If you find the right diff & shock oil for your lokal track, how often do you/i have to chance the oil?
Best Regards.
dMITIj is offline
