Like Tree22Likes
Old 10-15-2012, 01:26 PM
  #11221
Default Broken drive axles
Originally Posted by boudin4evr
yes I've broken 3 of them! frustrating!
Any fix for this issue? Or are there other brands that are stronger and fit in the dex410?
Borik is offline
Old 10-15-2012, 01:36 PM
  #11222
Briguy's Avatar
Trader Rating: 125 (100%+)
Originally Posted by Borik
I'm looking into getting the dex410v3. Though I heard the drive axles are weak and have a tendency to break. Is there truth to that, I'm going to be running an LRP esc and reedy 7.5 motor.
I`ve had the 410s since the original and broke one once when I smacked the wall and broke the front arm , which is reasonable . Axles have been fine for me , racing twice a week .
Briguy is offline
Old 10-15-2012, 02:31 PM
  #11223
I ordered extra frt and rr drive axles as well as frt and rr a-arms...just in case. I pick it up wednesday and start the build. Hopefully have it ready for weekend racing.
Borik is offline
Old 10-15-2012, 03:24 PM
  #11224
jmackani's Avatar
Trader Rating: 14 (100%+)
I have to ask what are you hitting? I too have owned mine for a year and never broke one.
jmackani is offline
Old 10-15-2012, 03:40 PM
  #11225
Rob Phillips's Avatar
Originally Posted by tntpower
Where do you install the angle ball cups in the V3 kit? The manual don't show them.
http://www.team-durango.com/part-inf...artNo=TD330293
The manual doesn't specify this, but there are a few extra parts included that are for other kits, this being one of them.
Rob Phillips is offline
Old 10-15-2012, 03:44 PM
  #11226
R/C Tech Elite Member
Trader Rating: 520 (100%+)
I broke a couple in my car first few times out and traced it to the output yoke set screw worked loose, and put extra pressure on it. Made sure the locktite I used was red, and haven't had one issue with them since..Most durable 4wd I have ever owned..
flame56mx is offline
Old 10-15-2012, 04:18 PM
  #11227
Default dex410 v3 broken drive axles
I haven't broken any. I'm buying the 410v3 and heard the drive axles are a little weak and break. This is my first Durango and was just wondering.
Borik is offline
Old 10-15-2012, 04:20 PM
  #11228
Konich's Avatar
Use some red loctite, and keep them lubed with a little bearing oil will help keep them from binding. Also set the slipper per the manual as well.
Konich is offline
Old 10-15-2012, 05:12 PM
  #11229
Originally Posted by Stealth_RT
Car has plenty of travel with the droop screws installed. I run 21-2mm ride height and full down travel is more than double that. How much down travel do you need? If you remove the droop screws, watch that the dogbones don't pop out of the diff outdrives at full down travel. Also, too much rear droop can cause too much weight transfer to the front wheels off power, and can cause the car to get loose or unstable coming into corners.
I'm just doing a bit of bench tuning and getting to know the car since I can't get to the track right now.
I grabbed Ryan Lutz's setup from the RROC and I noticed that he is running the rear shock lengths at 99mm (center to center mounted), which I'm trying to figure out how he achieved that without removing the droop screws.
Also, is the ackerman plate that comes with the V3 suppose to only have two positions? I noticed that the setup sheets for the previous version has two positions, but the V3 setup sheet has three positions.
Old 10-15-2012, 05:29 PM
  #11230
Briguy's Avatar
Stock ackerman plate has two positions , TD340001 is the optional plate that has three positions .
Briguy is offline
Old 10-15-2012, 06:34 PM
  #11231
Thanks for the part number and info. I just wasn't sure if the three hole was suppose to ship with the kit or not since it listed on the setup sheet.
One more question, what are the extra 4 beveled aluminum washers for? Look like they should go behind a wheel hex...
Old 10-15-2012, 06:40 PM
  #11232
Briguy's Avatar
The previous versions used the washer behind the pin as the rear were pin drive style . Some reason they were included in the V3 kits .
Briguy is offline
Old 10-16-2012, 06:50 AM
  #11233
That what I was thinking. Thx
Old 10-16-2012, 09:59 AM
  #11234
Team Tekin
Randy_Pike's Avatar
We may have pulled Ryan's droop screws.
Randy_Pike is offline
Old 10-16-2012, 12:43 PM
  #11235
Cool, thanks Randy.
I see that the setup calls for the old #2 VR rear block, do you know what that changed?
