Like Tree22Likes
Old 09-07-2012, 12:58 PM
  #11026
tobamiester's Avatar
Trader Rating: 360 (100%+)
Originally Posted by jjjheimer
My 2010 spec got run over by a bus, but some things such as the titanium turnbuckles and a few miscellaneous parts survived.. what would be some essential upgrades with the V3 I should get? Probably gonna get the TD aluminum rear bulkhead braces, but other than that?
I have the Tresrey hoops and some of the bearings from the 2010 car. Which of the rear hub carriers should I get, they have 1' and 0' ones.
Thanks..
Was it hit by a Short Bus or a real bus ?
Get an Alum Servo Arm. Hubs depend on what setup you want and your track. Run the plastic ones first (v3 comes with both). then get Alum Tresrey ones later.
tobamiester is offline
Old 09-08-2012, 07:22 AM
  #11027
Originally Posted by privategab
tekin rs with 8.5 ... it is enough torque/speed for him? Im thinking about wich one kit will be the better for me,,,
It's a Tekin RS Pro. I run on a very small 75ft X 50ft indoor track and the 8.5 is plenty of power. I actually run faster lap times with a 10.5.
qwkpony is offline
Old 09-09-2012, 12:30 AM
  #11028
Hey guys. Just pulled the trigger on a Dex410 v3. Looking for a good motor/esc combo for it. I see a lot of guys running the rs pro 6.5t combo. I currently run at a small indoor track and was wondering what the best combo would be for it. Here is a link to some pictures of the track if that helps. http://www.carolinasrcracers.com/for...=pics-of-track
sierravmax is offline
Old 09-09-2012, 09:27 AM
  #11029
Trader Rating: 2 (75%+)
Upgrades to add up haha! I ordered around $500 in upgrade alone already
fung_kyle is offline
Old 09-09-2012, 06:45 PM
  #11030
Real bus. Left the DEX on top of my other car and drove off...
jjjheimer is offline
Old 09-11-2012, 09:13 PM
  #11031
Gosh... the space for motor wire us tight in the car. My motor wires are nudging the body right now.
Old 09-11-2012, 09:17 PM
  #11032
Briguy's Avatar
Trader Rating: 125 (100%+)
I run my wires short between the ESC and motor . They can't be much longer than an inch .
Briguy is offline
Old 09-11-2012, 09:59 PM
  #11033
Hy,
I've got my dex410v3 on monday and started to build the Diffs.
How many shims did u use and on witch side?
When i put the shims like the manual says, i have quite a lot of gear mesh....
I know the diff cases can be different from molding, just to have a oriantation where i have to go!
I bought some extra shims, so it should be easy to get the right gear mesh.
thanks in advance
micholix is offline
Old 09-11-2012, 11:08 PM
  #11034
Trader Rating: 44 (100%+)
do yourself a favour and checkout the various electronics layouts below. it will save you many hours, sleepless nights and possibly your sanity too.
(been there, done that)
http://www.oople.com/forums/showthre...ghlight=wiring
wyl03 is offline
Old 09-12-2012, 07:41 AM
  #11035
R/C Tech Elite Member
Trader Rating: 520 (100%+)
Originally Posted by micholix
Hy,
thanks in advance
go to team Durangos website, and look at the tips on building the diffs, good info there.
flame56mx is offline
Old 09-12-2012, 10:13 AM
  #11036
kevin107's Avatar
Trader Rating: 109 (100%+)
Sorry to post on all the Durango threads.. but I thought Durango lovers should be aware of this...
Someone told me.. we'll be giving away something from.... TEAM DURANGO this week on RCSoup.com!
http://www.rcsoup.com/2012/08/rc-sou...ar-every-week/
kevin107 is offline
Old 09-12-2012, 11:19 AM
  #11037
boudin4evr's Avatar
Trader Rating: 18 (100%+)
i have the V1 dex410r
anybody upgrade their shocks?
boudin4evr is offline
Old 09-13-2012, 11:44 AM
  #11038
dexon555's Avatar
Hy,
thanks in advance
Experiment by adding or subtracting shims on both sides until the output shaft spins butter smooth.
dexon555 is offline
Old 09-14-2012, 04:56 PM
  #11039
Default Quick question
Hi guys I am new to the Durango dex 410 platform as I just picked up a used one in the classifieds. My question is can you upgrade a older spec car to the v3 spec or did they change to a completely new layout. I can't seem to find the info anywhere. Thanks for your time.
mckenzies is offline
Old 09-14-2012, 05:18 PM
  #11040
The Original 410 is still a great car and very similar - and has all the upgrades. The v3 (not v3R) comes with Big Bores. The small bores on your 410 are still good - the Big Bores are more of a tuning option, better on rough tracks.
I'd update the Wheel hexes on all 4 wheels to the v3 14mm hexes are old wheels are near impossible to find. Grab a PDF of the v3 manual from the TD website and get part numbers. You just need the hexes/pins, Rear Hubs/Bearings. Then get some of the new wheels (DE-Racing also make Good rims for the v3).
If the diffs are leaking (from the original x-ring seals, get some DNX408 shock O rings and replacement. Or Kyosho P5 orings).
Thats all the springs to mind. The old body was very tight fitting. PL & JC make nice Cab forward bodies that give you more room under the hood. They look fancy too
