Like Tree22Likes
Old 08-31-2012, 06:48 AM
  #10981
TAMAK's Avatar
Trader Rating: 29 (100%+)
Nano tech 5100 saddles fit no problem.
TAMAK is offline
Old 09-03-2012, 08:20 AM
  #10982
Hello,
I just ordered a dex41v3 on frieday and the kit should come this week!
I want to use my lrp x12 6.5 and the lrp Sphere Comp. TC-Spec., would a 22 pinion a good starting point, for a big loamy outdoor track?
I do not racing at the moment, just practicing and maybe go to a club next year!?
Maybe someone have any extra building tipps, excapt from the td "in the pit" tipps?
Thx in advance
micholix is offline
Old 09-03-2012, 08:36 AM
  #10983
Trader Rating: 2 (75%+)
Originally Posted by micholix
Hello,
Thx in advance
I believe 22t should work well since someone recommended me a 22t for my 7t for a big track as well.
fung_kyle is offline
Old 09-03-2012, 08:46 AM
  #10984
tedstryker's Avatar
Trader Rating: 88 (100%+)
just finishing up my build gonna use 10.5 what pinion should i use with stock spur...
tedstryker is offline
Old 09-03-2012, 09:37 AM
  #10985
san.'s Avatar
Trader Rating: 61 (100%+)
I use a 25 tooth, Mike. Start with the stock timing on the motor itself (end bell).
san. is offline
Old 09-03-2012, 01:05 PM
  #10986
tedstryker's Avatar
Thnx buddy..will do.
Old 09-03-2012, 02:08 PM
  #10987
Trader Rating: 79 (99%+)
Thumbs up
10.5 in a 410 is never a good combo. The car is too heavy, and your track is small. It will overheat. Run atleast a 8.5..
Raul Garcia is offline
Old 09-03-2012, 02:13 PM
  #10988
san.'s Avatar
Guess it all depends on the which motor. I've been running the Speed Passion v3 (5deg mechanical) for almost a year, yep same motor and pinion to date. The buggy podiums almost every time out at our local track.
san. is offline
  #10989
Briguy's Avatar
Trader Rating: 125 (100%+)
I found that out this weekend as I put in a 13.5 to just get started in 4wd again . 7.5 will be in it before Thur !
Briguy is offline
Old 09-03-2012, 03:10 PM
  #10990
tedstryker's Avatar
proper gearing with a 10.5 I''m sure it will work out fine...........
Old 09-04-2012, 05:28 AM
  #10991
THX fung_kyle!
I have a fiew more questions:
Do you use grease at the pivot balls?
Witch oil do you us in the diffs and shocks?
Do you thread lock the screws, witch go from the bottom in the motor-mount, because the manual do not say this!?
Any more building tipps, or should i just follow the manual?
micholix is offline
Old 09-04-2012, 08:10 AM
  #10992
Trader Rating: 19 (100%+)
+1. Cush ran a 10.5 boosted when be first had the buggy with a 22 on it. Temps were good, but as he gained skill with the car he needed more motor to keep up on the long straights our tracks generally have. Without boost 25-26 seems about right.
Jonny5 is offline
Old 09-04-2012, 08:17 AM
  #10993
tobamiester's Avatar
Trader Rating: 360 (100%+)
Ted, ran a 10.5 in mine at Critters and it worked very well and ran cool. Was great to get used to the car and work on handling. Think i ran a 23/24T Pinion.
tobamiester is offline
Old 09-04-2012, 08:54 AM
  #10994
tedstryker's Avatar
Thnx for the help Toby...
Old 09-04-2012, 09:26 AM
  #10995
THX fung_kyle!
I'm not sure on those yet. I'm sure someone with more knowledge will help you!
