Like Tree22Likes
Old 08-29-2012, 12:09 PM
  #10966
Originally Posted by hotdognobun
2nd hand 2010 would be better. 2010 comes with alloy sides alreay so getting plastic would be cheaper. hey if you want my v3 sides ill send it to you. just pay $5.00 for shipping
Posted to the UK ?
mikeyscott is offline
Old 08-29-2012, 03:41 PM
  #10967
Panda-PR's Avatar
Hi, on the v3- whats a good setup for indoor carpet (shocks, diff)?
I went with stock setup from the manual for the moment.
I liked so much this car that went and bought the lunsford kit (stock ones were popping out) and djoints. Using a tekin 6.5/ rs pro
Panda-PR is offline
Old 08-29-2012, 04:08 PM
  #10968
ABBOTT's Avatar
Check the TD website for carpet setups.
ABBOTT is offline
Old 08-29-2012, 04:35 PM
  #10969
Briguy's Avatar
Trader Rating: 125 (100%+)
http://www.petitrc.com/setup/durango...oDEX410v3.html
Briguy is offline
Old 08-29-2012, 11:25 PM
  #10970
Can anyone confirm if these fit in the DEX410Rv3?
http://www.hobbyking.com/hobbyking/s...dProduct=23134
caltrigger is offline
Old 08-30-2012, 12:33 AM
  #10971
hotdognobun's Avatar
Trader Rating: 32 (100%+)
http://www.rctech.net/forum/electric...hread-497.html
hotdognobun is offline
Old 08-30-2012, 02:05 AM
  #10972
Thanks for that!! I may stick to saddles...
Also wanting to change the Plastic suspension hangers in the Rv3 for the aluminum with insert versions.. can anyone give me all the part numbers to do the conversion? I have most of them but want to be sure before I order online.
Old 08-30-2012, 02:37 AM
  #10973
onekiwi's Avatar
You can always download the V3 manual and get the parts numbers from that
onekiwi is offline
Old 08-30-2012, 07:28 PM
  #10974
Hunter14's Avatar
I have a dex 410 and I have had the diff ring chipping and stripping. It is not the bevel gear that is stripped or chipped it is the ring gear. Is there a fix for this. Please help.
Hunter14 is offline
Old 08-30-2012, 09:54 PM
  #10975
KH
I replaced both of mine with the hardened steel ones. No problems since.
KH is offline
Old 08-30-2012, 10:35 PM
  #10976
slow_jun's Avatar
Trader Rating: 14 (94%+)
http://www.amainhobbies.com/product_...tial-Ring-Gear
slow_jun is offline
Old 08-30-2012, 10:37 PM
  #10977
slow_jun's Avatar
http://www.amainhobbies.com/product_...pension-Hanger
slow_jun is offline
Old 08-31-2012, 12:03 AM
  #10978
Trader Rating: 44 (100%+)
with the DEX410, it is critical to check the play/slop on the centre drive shafts/gear box. The moment there is a bit of slack, then you need to check
- set screw on bevel gear (always use loctite)
- bearings
- play in gear box (to reduce any play in the area where the bearing sits in the gear box, you can actually cut a thin strip of electrical tape and place it between the bearing and diff case, cheap fix ... or just get a new gear case )
Code:
If it fits in my V1, then it should fit in the V3. Having said that, whilst the HobbyKing has good punch, it struggled towards the end of a 5mins race (I find the HK shorty more suited to 2wd). I prefer the Protek shorty instead for a heavy car like DEX410.
wyl03 is offline
Old 08-31-2012, 12:57 AM
  #10979
onekiwi's Avatar
Anyone have the nanotech saddle packs?
What are the exact height of the 4.85 and the 5.0 that are approved? HK say 25mm for both but they haven't always been real exact in the past
onekiwi is offline
Old 08-31-2012, 01:15 AM
  #10980
slow_jun's Avatar
4.85 will fit
not so sure of the 5. but check with the specs, it should give you an idea what are the dimensions.
as per HK site
Spec.
Capacity: 4850mAh
Voltage: 2S3P / 2S Cell / 7.4V
Discharge: 50C Constant / 100C Burst
Weight: 132g EA (290g Total Inc Wires)
Dimensions: 69x47x25mm EA
Balance Plug: JST-XH
Discharge Plug: 4mm Bullet-connector to your own custom plug
Spec.
Capacity: 5000mAh
Voltage: 2S2P / 2S Cell / 7.4V
Discharge: 30C Constant / 60C Burst
Weight: 285g (including wire & case)
Dimensions: 70x47x25mm (Each)
Balance Plug: JST
slow_jun is offline
