Like Tree22Likes
Old 08-28-2012, 01:50 PM
  #10951
jackcarter3's Avatar
Can't find the part number for the standard shock caps. Anyone know?
jackcarter3 is offline
Old 08-28-2012, 02:22 PM
  #10952
Briguy's Avatar
Trader Rating: 125 (100%+)
TD330013
Briguy is offline
Old 08-28-2012, 03:23 PM
  #10953
Trader Rating: 44 (100%+)
Originally Posted by hotdognobun
i still prefer a 2010. after 5months with my v3 i actually added options parts that basically made it a 2010 with big bores. it cost more to fully hop a v3 to be the same spec as 2010. I love aluminum
yeah .. probably cheaper to get a mint 2010 and then buy a set of big bores (from the v3).
wyl03 is offline
Old 08-28-2012, 03:30 PM
  #10954
JosephBlack's Avatar
I run zero hopups on my V3. It's suits me quite well. No problems and hardly any maintenance after several club races and practices.
Aluminum looks cool though.
JosephBlack is offline
Old 08-28-2012, 06:13 PM
  #10955
Trader Rating: 264 (100%+)
gearing for a 8.5?
Fred Perkins is offline
Old 08-28-2012, 07:22 PM
  #10956
Trader Rating: 52 (100%+)
Originally Posted by Fred Perkins
gearing for a 8.5?
Try 23 and check temps every 2min.
tonyd is offline
Old 08-29-2012, 01:03 AM
  #10957
That's what I'm mulling.
Only thing I really will do is change ballends and cups to HPI/Losi like I did before and prob add the alloy servo saver thing from Tresrey, prob the machined gears and maybe the d joint centre shafts
Just got to scratch the head re Orion R10/Sanwa 451R install if I get the car.
Would prob go with an Orion 7.5 motor
Ran diffs 12.5/7k last time, plan to try something around 5/3k this time.
mikeyscott is offline
Old 08-29-2012, 02:02 AM
  #10958
hotdognobun's Avatar
Trader Rating: 32 (100%+)
Originally Posted by mikeyscott
So what did you add? I had a 410R back in 2010.
Alloy sides, stiffen car?
I'm looking at a mint used 2010 spec at the mo. what's essential upgrades/updates?
2wd I'll be running the kyosho RudeBits DB1.
to match 2010 spec: $270+
alloy sides
rear alloy gearbox imserts
alloy steering rack
alloy steering plate
alloy main gear mount 25mm
titanium turnbuckles
quick release shock mounts
my extra upgrades: $700+ ouch
boca orange bearings
tresrey gearbox hoops
tresrey big shocks
8racing carbon chassis
alloy flex brace
djoint centre driveshaft
titanium hinge and turnbuckel
alloy steering servo
titanium screws
alloy screws
hotdognobun is offline
Old 08-29-2012, 06:25 AM
  #10959
alloy sides
alloy steering rack
tresrey big shocks
alloy flex brace
titanium screws
alloy screws
Off that list I'd only go
Old 08-29-2012, 06:31 AM
  #10960
Trader Rating: 79 (99%+)
I don't use the djoints . But I do use the lunsford kits. Never looked back.
Raul Garcia is offline
Old 08-29-2012, 07:27 AM
  #10961
Hi,
Ok cheers, certainly would save a few .
If I land a 2010 spec, it'll have the titanium turnbuckles, so would just change the ball ends etc.
Just wonder how better/worse it'd be compared with a Kyosho.
Diff ring gears would prob upgrade.
M
Old 08-29-2012, 07:41 AM
  #10962
Rob Phillips's Avatar
Where are you guys starting at on set up for a fairly tight indoor clay track?
I'm planning to pick one of these up for the fall/winter and so I'm trying to gather some info.
Rob Phillips is offline
Old 08-29-2012, 08:17 AM
  #10963
t8rtot's Avatar
Trader Rating: 14 (94%+)
Hi,
M
you don't need all the aluminum. my 410, i added alum. turnbuckles and rear diff insert holders..
the car is a tank and ready to win out of the box...
t8rtot is offline
Old 08-29-2012, 08:38 AM
  #10964
Only reason about the alloy sides is I'm looking at a 2nd hand DEX410 2010.
What ever model I end up with, it's a case of making sure drivetrain is solid etc..
With the exception of winter I've had very few issues with my Kyosho. I only mention winter, due to plastics suffering due to the cold.
Old 08-29-2012, 12:01 PM
  #10965
2nd hand 2010 would be better. 2010 comes with alloy sides alreay so getting plastic would be cheaper. hey if you want my v3 sides ill send it to you. just pay $5.00 for shipping
