Like Tree22Likes
Old 08-20-2012, 06:53 AM
  #10891
Briguy's Avatar
Trader Rating: 125 (100%+)
Originally Posted by fung_kyle
Do both the front and back use 14mm hex now?
Yes
Briguy is offline
Old 08-20-2012, 11:27 AM
  #10892
Originally Posted by ABBOTT
Check their webpage for tips on building diffs and reaming ball cups. I also suggest an alloy servo saver arm(Tresrey and Racers Edge make these) or totally eliminating it by using the right side setup from the DESC if your servo will handle it. An alloy servo arm is a must as well IMO.
Tigergutt is offline
Old 08-20-2012, 01:55 PM
  #10893
onekiwi's Avatar
Does anyone have the 8 racing chassis? What are your thoughts on that? How much does it shed off the scales?
onekiwi is offline
Old 08-20-2012, 02:08 PM
  #10894
jackcarter3's Avatar
Originally Posted by Tigergutt
I doubt it sheds much. They recommend you use the aluminum sides with the carbon chassis. I went with the atomic conversion to shed some weight.
jackcarter3 is offline
Old 08-20-2012, 10:30 PM
  #10895
Trader Rating: 2 (75%+)
Which part should a dex410 owner stock up the most?
fung_kyle is offline
Old 08-20-2012, 11:43 PM
  #10896
Trader Rating: 44 (100%+)
the 8racing chassis is around 70g lighter.
it's worthwhile only if you are running stock class, IMHO.
as nice as it is (and i have 1), i can't see the benefit of using it in mod class. i would prefer the additional 70g and as low CG as possible.
- front arms
- front & rear hinge pins
- diff gear
wyl03 is offline
Old 08-21-2012, 06:06 AM
  #10897
dexon555's Avatar
Bearings.
dexon555 is offline
Old 08-21-2012, 08:47 AM
  #10898
Just compiled a list of upgrades and parts. Wow it'll cost around $400 to get the car shiny. haha
Old 08-21-2012, 10:16 AM
  #10899
Hi Guys,
I need advise on gearing for tight indoor carpet track, what will be the right size of pinion and spur to run 13.5t motor?
GodOfWar is offline
Old 08-21-2012, 12:41 PM
  #10900
Jammin57's Avatar
Trader Rating: 120 (100%+)
Is anybody running different ball cups that don't pop off as easy?
Jammin57 is offline
Old 08-21-2012, 01:20 PM
  #10901
R/C Tech Elite Member
Trader Rating: 520 (100%+)
I have yet to have one pop, but they do come off easier than I'd like when doing maintenance. I did change over to Kyo(or Losi) balls and cups on my 210, mostly because I had em, and I was bored..
flame56mx is offline
Old 08-21-2012, 01:34 PM
  #10902
Briguy's Avatar
The HD ball cups rarely pop off and only do if your wheels are anywhere but pointing to the ground .
Briguy is offline
Old 08-21-2012, 01:36 PM
  #10903
Associated TC5/6 ballstuds and RPM ballcups are the best setup IMO.
qwkpony is offline
Old 08-21-2012, 01:45 PM
  #10904
Jammin57's Avatar
Thanks for the answers do the Lunsford ball cups work any better and are the 210 ball cups and balls the same as the 410
Jammin57 is offline
Old 08-21-2012, 01:48 PM
  #10905
big chris's Avatar
Trader Rating: 51 (100%+)
Originally Posted by dexon555
Bearings.
Which bearings specifically?
big chris is offline
