Like Tree22Likes
Old 08-13-2012, 07:49 AM
  #10816
What would be a better choice for a stock 4x4 buggy class as far as esc goes?
Novak GTB2 or the Speed Passion esc that comes with the 10.5T combo (Citrix I think) ??
caltrigger is offline
Old 08-13-2012, 01:31 PM
  #10817
Just ordered a new DEX410v3 for indoors this winter. Debated between this and a B44.1. I've had B44's in the past, and the ball diffs/plastic gears sucked then and still suck now. And it was a PITA to get to the gears/diffs for repairs.
Stealth_RT is offline
Old 08-13-2012, 03:48 PM
  #10818
Autocratic's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Briguy
The 1* hubs help settle down the rear end . Do you have any weight in the rear ?
I'll try those. Just ordered a set.
I have both skid and side weights.
Autocratic is offline
Old 08-13-2012, 03:54 PM
  #10819
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Has anyone tried the 21 degree front castor blocks yet? What did you notice? Thanks...
Bman's 3XNT is offline
Old 08-13-2012, 04:43 PM
  #10820
Trader Rating: 19 (100%+)
Tonyd had them on his car last time we were racing with him. He said they gave less (smoother) entry steering and more steering on exit. His car looked very good on the track.
Jonny5 is offline
Old 08-13-2012, 05:29 PM
  #10821
Any advantages to running a shorty pack vs. normal saddle packs, other than having only 1 battery brick to deal with? Well, less battery weight, but ppl are adding rear weight anyway.
Old 08-13-2012, 06:08 PM
  #10822
Trader Rating: 126 (100%+)
Only advantage I can think of is if your sharing shorties with your DEX210. A shorty in this buggy will make it very edgy. Everybody is adding weight to the rear with the saddles as it is. Your gonna have to add alot more ballast to keep the rear planted. Not worth it in my opinion.
kwiksi is offline
Old 08-13-2012, 06:39 PM
  #10823
badassrevo's Avatar
Looking at picking up a V3 on payday.
Can some one list the part numbers for the required hop up's?
aluminum rear diff hoop
aluminum servo saver arm
aluminum rear diff braces
D joint shafts
badassrevo is offline
Old 08-13-2012, 06:50 PM
  #10824
Briguy's Avatar
Trader Rating: 125 (100%+)
D joint shafts
Tresrey - TYTD055 TD - TD310208
Tresrey - TYTD036 TD - TD330311 Racer`s Edge - RCE9801
TD - TD310006 and TD310007
TD - TD220001
TD - TD210010
Briguy is offline
Old 08-13-2012, 08:23 PM
  #10825
D joint shafts
Don't forget this: http://www.tresrey-usa.com/categorie...ACTION-WEIGHT/
Jonny5 is offline
Old 08-13-2012, 09:07 PM
  #10826
Trader Rating: 79 (99%+)
Who uses the D Joint shafts?
Raul Garcia is offline
Old 08-13-2012, 09:09 PM
  #10827
Originally Posted by Raul Garcia
I need the fr, rf 2*, rr 2*, 4* rr.
Anyone have these? Used is ok..
Old 08-13-2012, 11:04 PM
  #10828
RPage's Avatar
Raul, I have the 3 RR mounts. I sent you a PM
RPage is offline
Old 08-14-2012, 06:24 AM
  #10829
ABBOTT's Avatar
I like the Tresrey rear weight also. I did away with the skid and use flat head screws in the back. Now everything back there is nice and flush like the rest of the chassis.
I am curious, on the newer cars the rear diff hoop was upgraded. Does it still break, or are people just changing it for piece of mind.
I have opted to forgo the servo saver all together. By using the right side post and arm from the DESC you will have more room to get the servo wire routed with out damaging it. Just DO NOT use a sissy servo.
ABBOTT is offline
Old 08-14-2012, 07:14 AM
  #10830
onekiwi's Avatar
Anyone run a viper esc in their buggy? What class are you running and are you having temp problems? Im thinking about the esc but not sure about the low air flow being a problem with an esc without a fan. I always want a fan on a 4wd running mod and high grip
onekiwi is offline
