Like Tree22Likes
Old 08-06-2012, 12:51 AM
  #10726
Originally Posted by Autocratic
You can use B44 fronts with these parts:
Hi, Are they direct fit? Does it require and dremeling or trimming to fit?
Thanks.
frozencone is offline
Old 08-06-2012, 05:16 AM
  #10727
tobamiester's Avatar
Trader Rating: 360 (100%+)
TD330004 front outer hinge pin holder
TD330006 front inner hinge pin holder
TD330307 Adjustable rear outer hanger
TD330309 hanger inserts (for above)
TD330008 inner rear hinge pin holder
TD330037 pivot balls
TD320007 skid plate
TD330007 1degree rear hubs
RPM73392 RPM Long Shank Ball cups
ASC31284 TC5 8mm ballstud (fairly certain this is the right part#)
KYOORG05 Kyosho O-rings or TD330099 DNX408 O-ring to replace Diff X-ring
Worthy upgrades: TD330016 Caster Left
TD330019 Caster Right
Originally Posted by jzwolen
so i just picked up a DEX410R and looking to get back into racing after a 15yr absence. Without going through 715 pages of this thread, are their any MUST mods/tweaks to the car that I should do? I'm already installing the aluminum arm mounts as a starting point. Anyone using the D-Joint center universals?
tobamiester is offline
Old 08-06-2012, 05:30 AM
  #10728
ABBOTT's Avatar
I have been waiting to see a few reviews on the D joints myself; it is getting close to time for a drive line rebuild. Do they reduce the contact the rear joints make with the batteries?
ABBOTT is offline
Old 08-06-2012, 06:39 AM
  #10729
Trader Rating: 38 (100%+)
TD320007 skid plate
Thanks tobamiester, both for the info, and the parts from you that should be arriving shortly. I think i'm most of the way there, aside from the Alum. Caster blocks.
jzwolen is offline
Old 08-06-2012, 07:23 AM
  #10730
dexon555's Avatar
I had them for a while now and i've noticed a lot less wear. I'm not sure about battery clearance because I shim my rear diff hoop. Hope this helps.
dexon555 is offline
Old 08-06-2012, 07:27 AM
  #10731
I been using the D joints for few months, it do help on eliminating pin coming out compare to the stock parts. With the D joints, I able to fit DNX's Alu servo arm. As for the rear part, it do raise a bit compare to stock.
GodOfWar is offline
Old 08-06-2012, 09:17 AM
  #10732
Team Tekin
Randy_Pike's Avatar
The D joints are a big friction reduction compared to the stock parts. The drive train is much more free which adds up to speed.
Randy_Pike is offline
Old 08-06-2012, 09:28 AM
  #10733
Trader Rating: 19 (100%+)
Another +1 for the D Joints. Smoother, quieter, less wear. Very nice parts and worth the money, especially if you're in need of new center shafts anyway.
Jonny5 is offline
Old 08-06-2012, 11:59 AM
  #10734
ABBOTT's Avatar
Just what I wanted to here. Thanks
ABBOTT is offline
Old 08-06-2012, 07:15 PM
  #10735
Briguy's Avatar
Trader Rating: 125 (100%+)
Will they work on the v3 buggy since the rear cvd shorter on the v3 ?
Briguy is offline
Old 08-06-2012, 07:20 PM
  #10736
Autocratic's Avatar
Trader Rating: 26 (100%+)
Thanks.
Direct fit.
Autocratic is offline
Old 08-06-2012, 11:41 PM
  #10737
i am using it on my Dex410V3, direct fit with no problem.
GodOfWar is offline
Old 08-07-2012, 06:48 AM
  #10738
Briguy's Avatar
Thanks !
On a different note , does anyone know where I can get an under tray other than from team-azarashi ? Really don`t want to wait a month to get it .
Briguy is offline
Old 08-07-2012, 07:24 AM
  #10739
Thanks !
I ordered a couple from Bugle Boy in Australia. Had them in about a week, air mail. Fitment is nice, but I only got them for outdoor. For indoor I would just use the AE chassis tape. Stuff is plenty tough for the clay at LHR. Lasts about 2-3 race days outdoor though.
Jonny5 is offline
Old 08-07-2012, 06:56 PM
  #10740
Trader Rating: 2 (75%+)
TD320007 skid plate
So this is all that's required right? I've seen people recommending aluminum diff hoops and servo saver arms. Those are just for preferences right?
Thanks!
fung_kyle is offline
