Like Tree22Likes
Old 07-31-2012, 03:27 PM
  #10711
KH
Originally Posted by Jonny5
Ken, I have an extra set of 1deg Tresrey hubs with the big outer bearings. No more bearing issues back there. Hit me up at the track if you want.
Sounds good dude. See u tomorrow?
KH is offline
Old 08-01-2012, 09:47 AM
  #10712
Panda-PR's Avatar
Regarding the v3, what parts should I pay attention to?
I already changed the diff hoops and servo saver crank to tresrey, also found the hard way that an aluminum servo horn is needed. After a crash I noted that a turnbuckle didnt popped out or broke it just simply got pushed in (went from 21mm to 17 mm) and the stock plastic servo horn jumped a few teeths.
So, what else should I work on?
Panda-PR is offline
Old 08-01-2012, 09:48 AM
  #10713
dangerwr's Avatar
Look out for the people behind you!
dangerwr is offline
Old 08-01-2012, 10:08 AM
  #10714
INFERN0's Avatar
If you have good soldering skills or the right pin crimp set I would suggest custom length servo wires to eliminate excessive wire under body. I found wire can find its way to moving parts and can help trap hot air under the shell.
I custom cut all my wires to help with under body airflow. Try also two layers of mounting tape under esc and RX to dampen hard shock from chassis.
INFERN0 is offline
Old 08-01-2012, 10:10 AM
  #10715
Trader Rating: 19 (100%+)
Won't be racing, but I'll cruise out there and bring the hubs.
Jonny5 is offline
Old 08-01-2012, 10:21 AM
  #10716
Panda-PR's Avatar
Yeah! LOL ! And also the ones on the next lane that after a jump always finds my car as a nice place to land.
Hmm good call, theres a messy set of wires on mine.
I was also thinking on cutting the lower sides on the front of the body for a little airflow.
Panda-PR is offline
Old 08-04-2012, 01:25 PM
  #10717
so i been having issues with the axle pin coming off..tried locktite blue still keeps coming off..now my rear arm is all jacked up..going to try red locktite and its not striped..anyone know what pin is compatible ? cant seem to find it on amainhobbies for stock not sure the size on the axle pin 2mm pin shaft??..what other brand pin will work?
also i notice my rear drive shaft got hot is that normal? i do have grease on my rear diff still no leaking..
thanks
iMarky is offline
Old 08-04-2012, 03:08 PM
  #10718
tobamiester's Avatar
Trader Rating: 360 (100%+)
thanks
Yup you need Red locktite on all of those. Tower has them http://www3.towerhobbies.com/cgi-bin...?&I=LXCCLV&P=7
See them on ebay too.
Part # 310120.
A little heat maybe normal but not "hot'. The heat maybe from a bad bearing.
tobamiester is offline
Old 08-04-2012, 06:15 PM
  #10719
ABBOTT's Avatar
The center drives do get rather warm after a long run. Just check for abnormal binding every so often. Of course the more they wear the more heat they will generate. The rear drive is far more critical as a failing pin can cost you a battery. It is easy to check since you will be handling them every time you change packs.
I have had good luck adding another set screw to the other side of all my cvds. You do have to dremel them down for the correct clearance. The key is to get them together when they are free of any lubrication. Once they are greased, the chances of getting the parts to stay together decreases tremendously no matter which type of thread lock is used.
ABBOTT is offline
Old 08-04-2012, 06:26 PM
  #10720
Regarding Lubricants on CVD's, I've had good results with a dry wax lub, specifically http://www.amainhobbies.com/product_...-Lubricant-4oz
Old 08-05-2012, 04:29 AM
  #10721
Trader Rating: 125 (100%+)
thanks
Prob solved.
http://www.tresrey-usa.com/tresrey-a...eel-hub-clamp/
kwiksi is offline
Old 08-05-2012, 10:57 AM
  #10722
Trader Rating: 52 (100%+)
The hex is not his problem it is the 2mm pin in the axle joint itself. I did what others have done. Clean with motor spray and red loctite. Also make sure you get the flat spot in the correct spot so the grub screw is in it. Let dry before you use the car.
tonyd is offline
Old 08-05-2012, 03:58 PM
  #10723
Try using two grubscrews, although I tighten the additional one a little first (opposite the flat side) then tighten the flat side one. Never had a pin come out.
Hoping that next years kit will come with captured cvd'd like the truck and 2wd.
Chris-s is offline
Old 08-05-2012, 09:00 PM
  #10724
Trader Rating: 38 (100%+)
so i just picked up a DEX410R and looking to get back into racing after a 15yr absence. Without going through 715 pages of this thread, are their any MUST mods/tweaks to the car that I should do? I'm already installing the aluminum arm mounts as a starting point. Anyone using the D-Joint center universals?
jzwolen is offline
Old 08-06-2012, 12:00 AM
  #10725
joho's Avatar
your ultimate solutions on a loose CVD pin
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-dsc00941.jpg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-dsc00945.jpg
joho is offline
