Like Tree22Likes
Old 07-23-2012, 01:01 PM
  #10666
Trader Rating: 51 (100%+)
Originally Posted by Autocratic
They are the small bore springs. Big bore springs only come in black.
Thank you that makes more sense then to me
Garnold is offline
Old 07-24-2012, 06:49 AM
  #10667
Does anyone know how running the inner vs outter hole on the front aluminum hub affect handling?
jha07 is offline
Old 07-24-2012, 07:34 AM
  #10668
Trader Rating: 125 (100%+)
The inner hole will slow down the reaction and be smoother. It will also go through bumps better. Outer will be more precise and make the front end square up better.
kwiksi is offline
Old 07-24-2012, 10:30 AM
  #10669
Thanks, that's what I had suspected.
Another question I had is about the front diff. I tried in the past playing with different fluid and found that a heavier front diff fluid increased on power steering. But recently, I increased the front diff fluid in my DESC410R and had the exact opposite result. I got less on-power steering.
Now I'm wondering if I was wrong before, or if the two cars just behave differently?
jha07 is offline
Old 07-24-2012, 01:19 PM
  #10670
Trader Rating: 19 (100%+)
The sc has a center diff, so it will behave differently. If you had the locker in your sc I would think that you would have found the same thing as in your buggy. Also consider that there is much different leverage forces at work between the buggy and the sc- even though the diffs are the same, the size of the tires are very different. A possible explanation for why sc diff oils are generally higher than buggy oils. I don't really bother comparing between the two, rather tune to what each wants as you're racing. As long as the car does what you want and how you want, the numbers matter only for referencing a setup.
Jonny5 is offline
Old 07-24-2012, 03:20 PM
  #10671
Good point about the SC having a center diff.
Speaking only about the buggy, how did you find heavier diff fluid in the front affect handling?
jha07 is offline
Old 07-24-2012, 05:51 PM
  #10672
Autocratic's Avatar
Trader Rating: 26 (100%+)
Wondering when TD is going to release that center torque slipper posted awhile back.
Autocratic is offline
Old 07-24-2012, 06:51 PM
  #10673
It took away a bit of entry steering, but gave more on power steering out of the corner. That was on high bite clay, and we added a rear sway bar to loosen the back up on entry then.
Jonny5 is offline
Old 07-24-2012, 09:33 PM
  #10674
Jpm1's Avatar
I'm changing to indoor, is there any merit handeling wise in changing to plastic side rails, I have the spec edition with the alloy sides?
Has anyone done much testing between the 2
Cheers Justin
Jpm1 is offline
Old 07-24-2012, 10:24 PM
  #10675
Cheers Justin
It will "soften" the chassis up, allowing it to flex more. Depending on what you're trying to do it can help. We're using the Tresrey carbon chassis so the aluminum sides are the only thing we run.
Jonny5 is offline
Old 07-25-2012, 08:02 AM
  #10676
dexon555's Avatar
Cheers Justin
Plastic rails are better suited for loose outdoor tracks, felx makes the car more stable. Alloy rails work well on high traction indoor tracks, makes the car more percise in handling.
Just my opinion.
dexon555 is offline
Old 07-25-2012, 09:03 AM
  #10677
KH
Johnny5
You were right. This car does get the motor hotter than running TC. It seems it's only because it can't breathe tho. I installed a sonic 5.5 geared at 21/87. I ran it outdoor for about 5 mins and then went to the indoor track. One of the motor wires came unsoldered. I temped the motor and it was at 220deg! I put the vented body on and it helped a bit but still over 200. I'm running the SP 2.0 with the boost on zero. I know in TC on hot days I let the motor get up to 210 with no probs. does anyone run a fan on the motor somehow? I installed my revtech 8.5 and it runs at 140deg 24/87 gearing with 30deg of timing in it. It's plenty fast and will get the job done. I really want the power of the 5.5 back tho. Any advice is appreciated. But DAMN do I love this car!!
KH is offline
Old 07-25-2012, 09:26 AM
  #10678
JOJOHAMBONE's Avatar
Trader Rating: 31 (100%+)
newpaint from rob majors at 521 designs on the bulldog
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-256416_3919966596574_1709896024_o%5B1%5D.jpg
JOJOHAMBONE is offline
Old 07-25-2012, 10:37 AM
  #10679
t8rtot's Avatar
Trader Rating: 14 (94%+)
LRP and Reedy's run hot..
t8rtot is offline
Old 07-25-2012, 11:00 AM
  #10680
TAMAK's Avatar
Trader Rating: 29 (100%+)
Originally Posted by KH
Johnny5
My guess is a bad motor. I had a problem with my 8.5t Novak Ballistic getting too hot, installed a 8.5t Speed Passion and temps were WAY cooler
TAMAK is offline
