Like Tree22Likes
Old 06-20-2012, 04:35 PM
  #10591
subaru_tech's Avatar
Trader Rating: 106 (100%+)
can use some help with a question.
i broke the rr suspension holder (plastic)
so i purchased this one below.
http://www.team-durango.com/part-inf...artNo=TD330012
do i use these pivot balls ?
http://www.team-durango.com/part-inf...artNo=TD330037
thanx,sorry new to durango
subaru_tech is offline
Old 06-20-2012, 04:39 PM
  #10592
TAMAK's Avatar
Trader Rating: 29 (100%+)
Yes and Yes!! However for our local tracks, I would haver used number 4 instead of 2.
TAMAK is offline
Old 06-21-2012, 06:05 AM
  #10593
dexon555's Avatar
If I were you I would buy this instead, it is a much better/easier system.
http://www.team-durango.com/part-inf...artNo=TD330307
http://www.team-durango.com/part-inf...artNo=TD330309
It is the pill insert system similar to 8th scale buggies.
One Aluminum suspension hanger with many easy to change anti-squat options.
dexon555 is offline
Old 06-21-2012, 06:08 AM
  #10594
dexon555's Avatar
Originally Posted by THE GOOCH
Thanks, I'll try that.
There is an article in TD's tips and tricks section of their web site.
dexon555 is offline
Old 06-21-2012, 03:05 PM
  #10595
Can somebody running a V3 give me the part number for the front wheel hex? The online instruction manual for the DEX410 is for the older 410 and doesn't have part numbers for the V3 specific parts.
qwkpony is offline
Old 06-21-2012, 03:26 PM
  #10596
Team Tekin
Randy_Pike's Avatar
#TD330312
Randy_Pike is offline
Old 06-24-2012, 10:07 AM
  #10597
Jammin57's Avatar
Trader Rating: 120 (100%+)
I bought a new 410r v1 and it came with a new motor and esc but the lrp website says its for 1/12 and also it didn't come with a sensor wire and esc doesn't have a regular sensor wire plug on it but the motor is sensored is there a special sensor wire needed? This is the motor and esc
http://www.lrp.cc/en/products/electr...50652/details/
Jammin57 is offline
Old 06-24-2012, 01:50 PM
  #10598
what´s the degree on the original DEX410v3 ALU casterblocks? have heard 17 degree?
Gillblade is offline
Old 06-24-2012, 03:51 PM
  #10599
Trader Rating: 52 (100%+)
The sensor wire plugs in under the motor and battery wires. Also that is a good speedo just don't think it will do well in a 4 wheel with a 5.0.
tonyd is offline
Old 06-24-2012, 09:23 PM
  #10600
Correct, there was talk of also doing some 19 degree castor blocks but I see that only the 21 degree ones are available as an option.
Badger5 is offline
Old 06-26-2012, 06:05 PM
  #10601
Trader Rating: 54 (100%+)
http://www.rctech.net/forum/r-c-item...r-updated.html
rkhess is offline
Old 06-28-2012, 08:55 PM
  #10602
Has anyone tried a Brushless Hobbies 120 amp Esc? Would it fit?
THE GOOCH is offline
Old 06-29-2012, 08:12 AM
  #10603
I use the Hobbywing Xerun 120a in my DEX410 and i think they are the same size. Works fine.
ridgeracer is offline
Old 06-29-2012, 08:28 AM
  #10604
Trader Rating: 156 (100%+)
I put a brushless hobbies in mine, with a Spektrum 3520 and novak glitch buster. I didn't use there cap, I used a lrp works cap(the 3 small caps in a row). Its tight but it fit
Breeze is offline
Old 07-02-2012, 04:11 PM
  #10605
Originally Posted by Konich
Then you have something built wrong as the Tresrey diff hoop drops into any V3 without any modification.
Sorry to say but nothing has been built wrong . I have attached a picture to show what the actual problem is. The hoop is lower than the original plastic V3 hoop. The battery hole are correct though
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-img_2138.jpg
AmiSMB is offline
