Like Tree22Likes
Old 06-09-2012, 06:40 PM
  #10516
1slash's Avatar
My Dex410 seems to be making a very odd sound that I thought was normal until I heard a couple other Rangos running.
It is kind of a rattling clunking sound, hard to explain but what are some specific areas I should check when my vehicle is making unnormal sounds?
the diffs are fine and I have just replaced all the bearings in the vehicle to avid. when I just run the spur and pinion without the center driveshafts connected it sounds fine.
Any help would be great.
1slash is offline
Old 06-09-2012, 08:44 PM
  #10517
Carlos69's Avatar
Originally Posted by seth556
Just picked up the 410 original kit, not the v3. Got a deal, and apparently the big bores aren't the greatest.
Really ? I haven't heard that. BB will give a lazier feel over all but more stable over rough.
Carlos69 is offline
Old 06-09-2012, 08:51 PM
  #10518
R/C Tech Elite Member
Trader Rating: 520 (100%+)
Originally Posted by Woulvesbaine
Hey. Thanks. Great info and input. Please post pics. I take it I need the hotwire to download the new Tekin software? It's on my list to buy this week.
Yeah, you will need the hotwire to download v223, but to get all the advantages out of the speedo, you'll want one anyways..here are a couple pics, the layout on the 410 is a little rushed, I would like to clean it up a bit...
Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-imag0501.jpgTeam Durango DEX410 4WD 1/10 Off-Road Buggy Thread-imag0411.jpg
flame56mx is offline
Old 06-09-2012, 09:12 PM
  #10519
Woulvesbaine's Avatar
Odd. I would have checked pinion spurr contact first. Video it with your phone if you can and link it.
Woulvesbaine is offline
Old 06-09-2012, 09:15 PM
  #10520
Attachment 933033Attachment 933039
Very cool. Thanks! Neat center ESC setup for the 210. Is that a standard part? I bought my dex210 brand new but assembled and I'm just setting it up now.
Old 06-09-2012, 09:24 PM
  #10521
No, actually I had to drill a second set of hole in the chassis to move the rear battery holder forward an inch or so, and the battery strap is from a 22 made by Diggity designs. I currently have it set up a little different, so I can run full size packs if the need arrives.
Old 06-09-2012, 11:04 PM
  #10522
1slash's Avatar
All right I will try to get a video up in the next day or two.
pinion and spur mesh seems fine. Plus it dose not make the sound when I run the motor without the center shafts in there mounting points on the slipper rig.
Thanks for the reply
1slash is offline
Old 06-09-2012, 11:50 PM
  #10523
dirtydan's Avatar
Trader Rating: 47 (100%+)
put some wd40 in your cvd's they tend to make noise when there not lubed.
dirtydan is offline
Old 06-10-2012, 05:21 AM
  #10524
DBL15's Avatar
What stuff might I need to know about this, setup wise, or stuff I need to get, change, whatever?
Let us guess the seller told you the big bores are not the greatest
Nothing wrong with them mate that's why there in all the latest 1/10th durango cars and truck buggy etc
DBL15 is offline
Old 06-10-2012, 07:58 AM
  #10525
tobamiester's Avatar
Trader Rating: 360 (100%+)
I use Dry Wax every other race on all my CVDs (http://www.amainhobbies.com/product_...-Lubricant-4oz) .
Keep an eye on your CVD pin wear. They wear pretty fast and good to keep a couple of sets in your pit box and replace them as needed.
tobamiester is offline
Old 06-10-2012, 08:03 AM
  #10526
The Big bores are some of the best but they're more of a tuning option based on your track. If its very bumpy then they help settle the car down. If its smooth/high traction some (including myself) like the regular bore shocks (which make the car feel a little lazy in those conditions - just my experience).
If you got the original DEX410 kit then you've gone most of the upgrades, needed or otherwise. Pick up an Alum Servo Saver Arm and Rear Diff Hoop (TD or Tresrey make em).
You might want to do a the 14mm hex conversion as the older style wheels are hard to find (unless you use B44 wheels).
Old 06-11-2012, 10:53 AM
  #10527
My motor will be coming tomoorow 7.5 reedy mod..what pinion gear you guys recommend for indoor track use? I'm not sure on the gear ratio on the v3 stock spur gear.. I want to know what's the sweet spot for gearing
Thanks guys
iMarky is offline
Old 06-11-2012, 11:54 AM
  #10528
onekiwi's Avatar
Start with 21/22/23 and change for temps
onekiwi is offline
Old 06-11-2012, 03:26 PM
  #10529
Cool thanks
iMarky is offline
Old 06-11-2012, 03:42 PM
  #10530
mesa80's Avatar
On heavy acceleration and braking my car was also making a very odd clicking sound turned out to be the wheel slipping on the hex i would check as i thought it was the spur or diffs too just an idea
mesa80 is offline
