Like Tree22Likes
Old 05-14-2012, 05:21 PM
  #10351
Briguy's Avatar
Trader Rating: 125 (100%+)
You charge it just like a stick pack .
Briguy is offline
Old 05-14-2012, 07:17 PM
  #10352
R/C Tech Elite Member
Trader Rating: 520 (100%+)
Originally Posted by Panda-PR
Putting my v3 together!
I need some advice on how to charge saddle packs, anyone has a link or care to explain? I have experience with electrics but this is my first saddle pack. Thanks
If you are referring to a balance charging lead, they can be hard to find, I usually build my own..Here is a pic
Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-imag0511.jpg
Red balancer wire to red, blk to blk, and blue to link wire..
flame56mx is offline
Old 05-14-2012, 07:53 PM
  #10353
Autocratic's Avatar
Trader Rating: 26 (100%+)
For anyone who's running a Speed Passion GT2.0 Pro with either the Proline or JConcepts body, what motor are you running and what are your temps after 6+mins? Any ESC boost or drag brake?
Autocratic is offline
Old 05-14-2012, 07:57 PM
  #10354
Panda-PR's Avatar
Attachment 921120
Now this makes more sense! Thanks
I think it will be ready for the weekend. So, for a large 1/8 track, dusty, big jumps what do you guys suggest for diff/shock oil? Thanks
Panda-PR is offline
Old 05-14-2012, 08:55 PM
  #10355
I run on a dusty med bite track, and my diff oils are at 10/3 frt-rr and they feel good. Shock oils are 35/30 frt/rr, I have tried a few different shock pistons, so I am not sure where I am at currently..
Old 05-15-2012, 07:29 AM
  #10356
TAMAK's Avatar
Trader Rating: 29 (100%+)
GT2.0 Pro W/ V3 Comp 7.5. 87/23. Temp are: Motor=130* and esc heatsink w/ yeah racing fan= ice cold.
205mod
No added timing
Punch set to 3
VERY Small track.
Whenever I run at S&N Trackside (larger track) I have no issues with temps. I did notice with the bulldog body my temps did go up on the esc and motor. I cut a few holes in the body and added a better fan and no problems since.
TAMAK is offline
Old 05-15-2012, 09:06 AM
  #10357
Trader Rating: 19 (100%+)
I'll get you a setup sheet later for Cush's esc. Tresrey/SP esc motor combo, esc around 130-140, motor 140-150 depending on how strapped he's driving it. Wicked fast though on a 125x65 clay indoor track.
Jonny5 is offline
Old 05-15-2012, 03:45 PM
  #10358
teeforb's Avatar
Trader Rating: 94 (100%+)
i have blank pistons. how many holes and what size shall i do? i was thinking of 4 hole and 1.2mm.
thx
teeforb is offline
Old 05-15-2012, 05:02 PM
  #10359
Autocratic's Avatar
Sounds good. I was running a Viper with a Trinity 6.5 and Thunder Power 7.5 and was seeing 180+ on the ESC. About 160 on the motor.
Old 05-16-2012, 07:05 AM
  #10360
TAMAK's Avatar
Were you running a fan? Check ALL bearings, car may feel smooth with wheels and tires on but feel them individually. Cut breather holes in body, What size track? Gearing?
TAMAK is offline
Old 05-16-2012, 05:37 PM
  #10361
subaru_tech's Avatar
Trader Rating: 106 (100%+)
does anyone have info on putting rear 14mm hexes on a 410r.
the fronts fit perfect.
but the rears have a gold spacer 2mm.
when you take the spacer off.the new 14mm hex doesnt sit up against the bearing.
just checking before i put try and find some smaller shims to install
subaru_tech is offline
Old 05-16-2012, 06:59 PM
  #10362
Autocratic's Avatar
No fan. No room on the Viper I had.
I now have a SP GT2.0 Pro, and I will be running the fan.
I haven't gone through the car in awhile, but last time I raced everything rolled pretty free.
Track is Mike's Hobby Shop in Carrollton, Tx. Medium size.
Gearing is 87/22.
I'm redoing the front/rear diffs with new oil in a few days so I'll be checking everything as I go along.
Old 05-16-2012, 07:16 PM
  #10363
tobamiester's Avatar
Trader Rating: 360 (100%+)
You need to add a shim or two otherwise it will bind when you tighten it up.. I used a regular Nitro clutch shim on my old 410R.
tobamiester is offline
  #10364
Trader Rating: 78 (99%+)
Gearing is 87/22.
Gear 83/22, run the 119 mod profiles. Loving it...
Raul Garcia is offline
Old 05-17-2012, 12:45 AM
  #10365
thx
Hupo frequently use 4*1.4mm (front) and 5*1.3mm (rear) with big bores. Try with 45wt front and 32.5wt rear.
alex-fr is offline
