Like Tree22Likes
Old 05-08-2012, 06:55 PM
  #10306
subaru_tech's Avatar
Trader Rating: 106 (100%+)
Originally Posted by san.
Yes they will. Since you own the 210, you can try it yourself. Grab the 210 rear hexes and slap them on the 410r front and rear.
there both in the mail,or i would have done that.
give me alittle credit.
subaru_tech is offline
Old 05-08-2012, 08:46 PM
  #10307
jackcarter3's Avatar
so can you buy the small bore shock set anywhere? i bought the spring tuning kit from tower front and rear and they dont fit the big bore v3 bodies. wish they woulda clarified. i will buy some small bore shocks to have around as an option if anyone knows who has them or if anyone has some they wanna dump?
jackcarter3 is offline
Old 05-09-2012, 01:24 PM
  #10308
TAMAK's Avatar
Trader Rating: 29 (100%+)
Take a close look at Carsons shock towers!!! Molded plastic/composite?? Randy, whats up? And a solid rear gearbox insert, brass?
http://www.team-durango.com/blog/201...-jbrl-round-3/
TAMAK is offline
Old 05-09-2012, 02:00 PM
  #10309
Jmuck69's Avatar
Trader Rating: 14 (100%+)
It seems the standard bore shocks are the way to go for the 410.
Jmuck69 is offline
Old 05-09-2012, 02:07 PM
  #10310
I'm guessing hes testing out some one off/non mass produced parts
AWDdude is offline
Old 05-09-2012, 02:19 PM
  #10311
dirtydan's Avatar
Trader Rating: 47 (100%+)
im haveing an issue with the wheel hex pins snaping on the rear right wheel. i had it happen twice during practice 3 weeks ago, and twice racing this weekend. any idea what could be causing the pins to snap? im using the standard plastic 14mm wheel hex and it doesnt seem to be binding, but i put a shim behind the hex to make sure and it it still snaped in the main.
dirtydan is offline
Old 05-09-2012, 02:22 PM
  #10312
Team Tekin
Randy_Pike's Avatar
Yeah we're all testing some new parts on this car right now. I ran the plastic towers at the Cactus. They have a few more holes for the shock mounts,etc.
The smaller shocks weren't bad to begin with guys. Jorn won the Reedy with them
Randy_Pike is offline
Old 05-09-2012, 02:24 PM
  #10313
Team Tekin
Randy_Pike's Avatar
I hate to say it but it's the plastic hexes causing it. They're fine for most tracks but if your track has good bite you should get the aluminum ones. There are some roll pins that can also last longer but they too can break over time. IT's the smallest play that over time will bend the pin, fatigue it and break.
The plastic hexes are fine in front though.
Old 05-09-2012, 04:50 PM
  #10314
Autocratic's Avatar
Trader Rating: 26 (100%+)
Randy, care to share your setup from Cactus?
Autocratic is offline
Old 05-09-2012, 05:55 PM
  #10315
dirtydan's Avatar
cool thanks for the info i ordered the aluminum hexes
dirtydan is offline
Old 05-09-2012, 10:29 PM
  #10316
onekiwi's Avatar
And the rear diff inserts look like they might be solid brass
IS that a bugelboy shell as well
onekiwi is offline
Old 05-10-2012, 05:01 AM
  #10317
Ray Kindstrom's Avatar
Trader Rating: 153 (100%+)
Anyone have an extra set of std bore shock they want to part with?
Ray Kindstrom is offline
Old 05-10-2012, 05:22 AM
  #10318
onekiwi's Avatar
Yep make me an offer
onekiwi is offline
Old 05-10-2012, 06:25 AM
  #10319
TAMAK's Avatar
Talked to Carson last night and they are brass.
TAMAK is offline
Old 05-10-2012, 12:42 PM
  #10320
mdl060374's Avatar
Absolutely loving my V3, no complaints at all. Durable, fast, easy to control, and so far reliable.
However, I have a concern/question about the bigbores.
When they are assembled and mounted, I notice when fully extended, they have a bit of slop or play when I initially begin to compress them. All 4 do it, so:
I am guessing:
1) Its normal and nothing to be concerned about?
2) I did something wrong when assembling them/filling them with oil.
3) the pistons are loose on the shaft (which isnt true, I checked them. 2 guys at my local track asked this..)
Now, when I did assemble them, I initially bled them through the hole (with the screw), but though too much oil leaked out, so I refilled them 100%, and didnt bleed them at all the 2nd time, hoping that would fix the issue. It didnt.
The only thing I can think of is that perhaps there is a suction inside the shock (bladder related), that is causing the oil to vacuum up to the top, leaving some play upon initial compression.
thoughts?
(it isnt a huge deal, but been kind of bugging me so I thought I would ask if any of you experienced this..)
mdl060374 is offline
