Like Tree22Likes
Old 05-06-2012, 07:56 PM
  #10291
Ray Kindstrom's Avatar
Trader Rating: 153 (100%+)
So I, like many lately, have a V3 coming. I was lurking through some of this thread over the past few days, trying to consider what hopups are needed and which hopups are wanted. (I know....they should be one and the same) So far it looks like the Tresrey HD pins, P5 o-rings, TD servo crank, TD weight set (center/sides), Tresrey alum rear hex and 1*hubs and TD front alum hexes are the needs?
Have I missed anything? Gear box holders?
Wants would be that sweet looking Tresrey Red carbone chassis. I see the one on Cush's car and I feel warm and fuzzy inside. I mean that chassis is a work of art!!!
Ray Kindstrom is offline
Old 05-06-2012, 08:06 PM
  #10292
R/C Tech Elite Member
Trader Rating: 520 (100%+)
That chassis is cool looking.. Needs are the diff hoops, servo crank, and maybe the rear aluminum diff holders, the rest is bling, but cool looking anyways.. The V3 uses different diff seals, and they seem to work better than previous versions. The weight set is would be a nice tuning option for sure..
flame56mx is offline
Old 05-06-2012, 08:09 PM
  #10293
Hoops added to the list. Forgot all about those, thanks!
Old 05-06-2012, 08:10 PM
  #10294
Trader Rating: 19 (100%+)
[QUOTE=Ray Kindstrom;10700078Wants would be that sweet looking Tresrey Red carbone chassis. I see the one on Cush's car and I feel warm and fuzzy inside. I mean that chassis is a work of art!!![/QUOTE]
Last edited by Jonny5; 05-06-2012 at 08:11 PM. Reason: apparently I can't properly quote...
Jonny5 is offline
Old 05-06-2012, 10:04 PM
  #10295
hotdognobun's Avatar
Trader Rating: 32 (100%+)
does the durango big bore shock part fit the Tresrey shock set? i want to use titanium shock shaft but i read the tresreys is 3mm is the durangos the same? thanks
hotdognobun is offline
Old 05-07-2012, 07:02 AM
  #10296
That requires slight modification to the shock body and a few shims, just need to drill the holes a bit bigger. I know Raul did this mod to his set of shock, but I think he is using Kyosho shafts.
Jonny5 is offline
Old 05-07-2012, 02:49 PM
  #10297
Briguy's Avatar
Trader Rating: 125 (100%+)
Anyone know of these available from someone in the states ?
http://www.ebay.com/itm/Team-AZARASH...item2a1aa1b36a
Briguy is offline
Old 05-07-2012, 06:08 PM
  #10298
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
First hard run on the Durango. Setup coming around. Tq, fast lap, track record. Poped turnbuckle off on a bad landing finished 4th.
Blue and white car
http://www.youtube.com/watch?v=Q1xGg...e_gdata_player
ammdrew is offline
Old 05-07-2012, 06:57 PM
  #10299
<snip URL to Azarashi undertray protector because I'm a noob>
Can't help you there, but an alternative you may want to consider is Bugle Boy Racing's undertray protector. They come from Australia, and need to be used with a Bugle Boy bumper + screws for fitting on the DEX410.
rayonnair is offline
  #10300
Autocratic's Avatar
Trader Rating: 26 (100%+)
Just order off Ebay. I ordered a body for my B4.1 and got it in less than a week. Pretty fast considering it came from China directly.
Also, if you're looking for an undertray, the JConcepts or Team Associated sheets work really well. However, the Azarashi tray looks like the B44 tray, in which you could velcro the body to it.
Autocratic is offline
Old 05-07-2012, 07:43 PM
  #10301
ajj
ajj's Avatar
Trader Rating: 18 (100%+)
+1 for the J Concepts stick on chassis protector. Just sold my DEX410r after 6 months of solid racing and the car still looked like new. Only one scratch on the bottom.
ajj is offline
Old 05-08-2012, 06:41 PM
  #10302
subaru_tech's Avatar
Trader Rating: 106 (100%+)
can someone tell me if the 14mm hexes from the v3 will fit on a 410r.
i just bought the 410r and a 210.
want to be able to use tires on both.
subaru_tech is offline
Old 05-08-2012, 06:43 PM
  #10303
san.'s Avatar
Trader Rating: 61 (100%+)
Yes they will. Since you own the 210, you can try it yourself. Grab the 210 rear hexes and slap them on the 410r front and rear.
san. is offline
Old 05-08-2012, 06:45 PM
  #10304
TAMAK's Avatar
Trader Rating: 29 (100%+)
210 kit comes with an extra set of plastic 14mm hex's
TAMAK is offline
Old 05-08-2012, 06:51 PM
  #10305
tobamiester's Avatar
Trader Rating: 360 (100%+)
I ran them on the rear of my old 410R. I had to add a shim between the hex and bearing as it bound up (the 410R has the older/smaller bearing/hub than the v3).
tobamiester is offline
