Like Tree22Likes
Old 05-04-2012, 04:23 AM
  #10261
FLHX1550's Avatar
I keep going back and forth on getting a V3 or not, kind of wondering what the "must have" updates are to get the DEX410V3 as bullet proof as you can? I've heard you need the alum center driveshaft hoops / chassis brace but what else?
FLHX1550 is offline
Old 05-04-2012, 04:55 AM
  #10262
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
rear hoop breaks on very hard belly hits. some tracks this will never be a issue.
arms seem very tough. Rear uprights a spare set is a good idea. rear outer hinge pins.
drive pins ( they can fall out and if you lose a wheel nut you will lose the pin)
Spare front dogbones. Spare ring gear or machined version.
Alloy servo saver a must if you like the servo saver tight.
ammdrew is offline
Old 05-04-2012, 05:36 AM
  #10263
Trader Rating: 56 (98%+)
Randy - whats the lowest turn motor in this car I can run safely you think on an RS? Have an RS on the shelf, and budget is a bit tight to pick up a pro right now.
jhhack is offline
Old 05-04-2012, 05:55 AM
  #10264
dexon555's Avatar
Pulled directly from Tekin web site.
RS-Motor Limit Brushless Mode: 7.5 Turn, 540 2-pole (36mm)
Why would'nt you check here first?
http://www.teamtekin.com/rs.html
dexon555 is offline
Old 05-04-2012, 06:22 AM
  #10265
tobamiester's Avatar
Trader Rating: 360 (100%+)
I wouldn't run an RS with a low turn motor in this car as you'll likely have heat issues. I'd say 10.5 is the lowest you should go with an RS.
tobamiester is offline
Old 05-04-2012, 07:05 AM
  #10266
Trader Rating: 29 (100%+)
I would not run an RS I this or any other 4wd buggy. Tekin even states that the RS Pro is recommended for 4wd buggy. Sell the RS and buy a used pro it might cost you $40 give or take. Cheaper than burning up the RS.
Walkman is offline
Old 05-04-2012, 07:17 AM
  #10267
Dexon - I'm familiar with the info on the site and the manual. However, just because it 'can' run down to a 7.5 doesn't mean it's always a great idea to max it out an I've heard 4wd buggy is a beast when it comes to stress on electronics. This is why I asked in thread, for opinions from racers based on practical experience.
tobamiester / walkman- that's pretty much what my gut was telling me, but i wanted to get some input from other guys that run tekin and this specific buggy. Better not to try to be cheap now, and end up costing double later... Hopefully by the time I get the new kit together, I'll find a good deal on a RS pro. I had a RS pro sitting for ever and traded it. That was prior to deciding to try this kit/class.
Thanks!
jhhack is offline
Old 05-04-2012, 08:27 AM
  #10268
i ran a 8.5 with the rs in this car. no issues at all. added 2 cutouts for cooling and that was it. and if you actually read the packaging the rs will run down to a 5.5 in a 2wd car.
cm.stites is offline
Old 05-04-2012, 08:41 AM
  #10269
jboquire's Avatar
Trader Rating: 21 (100%+)
+1 on this comment, I run 10.5 Redline right now with an RS, no issues. I tried with an 8.5, gets hot after 4-5 min.
jb
jboquire is offline
Old 05-04-2012, 02:35 PM
  #10270
jackcarter3's Avatar
i am building up the v3 kit now and the carbon front shock tower doesnt fit into the 2 plastic pieces that mount to the chassis. is this a common thing to have to mod?
jackcarter3 is offline
Old 05-04-2012, 02:43 PM
  #10271
jboquire's Avatar
Do you have a picture?, I just built mine last week and I didn't have any issues.
jb
jboquire is offline
Old 05-04-2012, 02:47 PM
  #10272
jb
i can take a picture later. the plastic pieces i am talking about are the ones the four screws go into holding the shock tower onto them. they are notched for the tower to sit down into. the notches in mine arent even close to allowing the tower to sit flush.
Old 05-04-2012, 03:32 PM
  #10273
wtcc's Avatar
Maybe you just swapped them? Was one of my mistakes on the rear of the car.
The front was ok, but the holes were a little wrong so I had to force it a little bit to fit the screws in them...
wtcc is offline
Old 05-04-2012, 04:44 PM
  #10274
no, i had them right there just wasnt enough room to set the tower in so i shaved about a mm off and it went in snug. those are the thickest shock towers i have seen. i measured them at 4.6mm thick...... anyway, its coming together fine now.
Old 05-04-2012, 06:40 PM
  #10275
mnracer's Avatar
I had the same issue with the front shock tower! I had to mod the front uprights slightly with a exacto....
mnracer is offline
