Like Tree22Likes
Old 05-01-2012, 01:14 PM
  #10231
jboquire's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Bman's 3XNT
Car looks good! Do you know a Brandon D.? Races a 22. He was out here for a few years but just recently moved back to San Diego. Cool dude, just wonder if you guys race at the same track........
I've seen a Brandon D. at SDRC a couple of times. Fast guy.
jboquire is offline
Old 05-01-2012, 01:16 PM
  #10232
jboquire's Avatar
Originally Posted by dexon555
Nice paint.
Thanks, jb
jboquire is offline
Old 05-01-2012, 01:38 PM
  #10233
Team Tekin
Randy_Pike's Avatar
There is no bad batch of cvd bones. Anything can break on any given day. The slipper is mean to reduce shock loads and prevent major failures, it's there for a reason.
The bone in the picture though looks like it might have bound up or seized and then broke
Randy_Pike is offline
Old 05-01-2012, 02:55 PM
  #10234
R/C Tech Elite Member
Trader Rating: 520 (100%+)
Well, you are right on things breaking at anytime, but I have never seen a cvd break where, and as easily as mine did, no crash, no binding. I seriously hope there is a quality issue with the CVD's, or at least in my case, because if they break this easy, you will see a lot of 410's for sale, mine included..
flame56mx is offline
Old 05-01-2012, 03:12 PM
  #10235
Briguy's Avatar
Trader Rating: 125 (100%+)
I was very surprised to see your break . I had the original 410r , a V3 when first came out , and my other V3 should be here tomorrow . The only CVDs I ever broke was fronts when I was breaking spindles from rubs or bad landing . But have seen people rip apart the drive train because the slipper was to tight .
This is an awesome and durable buggy !
Briguy is offline
Old 05-01-2012, 03:19 PM
  #10236
TAMAK's Avatar
Trader Rating: 29 (100%+)
Agreed this buggy is TOUGH!! But, I would still say ask Durango and see what they say, I am sure they did testing on the CVD's to see how they break. If its a fluke thing than hey, its a fluke thing... But make them aware and they can document it.
Like I can tell you that the ring gears can be caused by two things: 1.) improper shimming 2.) Porosity in the casting ( I took photos of mine NIB and sure enough it was a bad batch, they sent me two new ones.. No issues with them since.
TAMAK is offline
Old 05-01-2012, 04:08 PM
  #10237
I am not doubting that, and I am assuming mine was a fluke or a bad part, because of how clean it broke. Like I said before, no crash, slightly nosed into a slower speed small double before a tight left hand turn, and the car did donuts..lol I sent an email to Durango, although I am unsure if I sent to the correct address. I have already replaced the part, and am not looking for a freebie, just want them to know more than anything else. I enjoyed the build,. and look forward to putting a few more laps in next time
Old 05-01-2012, 05:38 PM
  #10238
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Can't say that there was a bad batch but the outer hinge pins on the DEX408 have been breaking too. I just heated mine up with a torch to temper them a little bit more. Maybe the new items have been hardened to much? Could be purely isolated.....
Bman's 3XNT is offline
Old 05-02-2012, 06:19 AM
  #10239
dexon555's Avatar
Just making an observation that there has been many reported Dog-bone failures from New V3 kits of late. Go back and count them. This is a new occurance, because it was never a reported issue on the DEX410 in such numbers before now.
dexon555 is offline
Old 05-02-2012, 08:57 AM
  #10240
I guess that the drive shafts are pressure cast as machining would be a complete nightmare and expense for something so small. If they are cast then it is more than possible that there was an inclusion/porosity in the metal where it has broken, especially as where the breakages are where there is a thickness or size change in the cast.
This doesn't mean a batch issue, but could just a duff component that has slipped through the net. I've also seen a new 410R do this at might local track. Even so TD should replace the broken parts.
Badger5 is offline
Old 05-02-2012, 09:08 AM
  #10241
Team Tekin
Randy_Pike's Avatar
I'm all for reporting it. That is the only way that the factory will know to look into any potential issues.
I have no doubt that that breakage being as "odd" as it was is likely an isolated incidence. Regardless I've mentioned it to the powers that be and they're aware and paying attention.
Old 05-02-2012, 02:49 PM
  #10242
DBL15's Avatar
but there is so many more people having no issues at all with motors in the 5.5 to 6.5T with plenty of power
i would like to know how tight the slippers are , as every drive line takes a whole heap of pressure if there is no slip at all
i think its 8.2mm of thread showing on the slipper clutch maybe check you slipper setting to make sure its not to tight?
DBL15 is offline
Old 05-02-2012, 02:54 PM
  #10243
Woulvesbaine's Avatar
Hey ~
I am getting a v3 and would like to know what parts I should stock up on for racing. Front arms?
What maintenance at what frequency do you regularly do?
Also, can anyone share any good clay setups with me? I will be running this at WCRC in Southern Cali.
It's been a while since I ran a 4wd and I'm looking forward to running one that does not break every time you look at it!
Woulvesbaine is offline
Old 05-02-2012, 04:33 PM
  #10244
dexon555's Avatar
Originally Posted by Woulvesbaine
Hey ~
The DEX410 is super durable, dare I say the most durable in the class. I highly recommend reading the "tricks & tips" section of the TD web-site. The usual suspects would be a good idea.
Full set of A-arms.
Set of hinge pins.
Full set of bearings (Boca Bearings $23 for entire set)
Spurgear.
dexon555 is offline
Old 05-02-2012, 05:07 PM
  #10245
Full set of A-arms.
Set of hinge pins.
Spurgear.
Sweet. Thanks!
