Like Tree22Likes
Old 04-24-2012, 06:23 PM
  #10141
FrEaKiShTuNER's Avatar
Trader Rating: 200 (100%+)
Originally Posted by tobamiester
Ah yeah. Congrats!!!
Just finished up my build tonite . Going to be running my old Small Bores for now..
Very nice!!! I like the paint..
I liked the small bores on my R, but I run on a technical bumpy indoor clay. And I'm hoping the big bores will help settle her down. Plus with all the other goodies the v3 has in the box. Figured the upgrade was a good idea. With towers coupons and "easy pay", it was a no-brainer!!
FrEaKiShTuNER is offline
Old 04-24-2012, 06:41 PM
  #10142
Originally Posted by kwiksi
pm'd you about the Esc I bought of you on the 19th. haven't received any confirmation about it bro.
thanks, D
derbrylac is offline
Old 04-24-2012, 06:46 PM
  #10143
tobamiester's Avatar
Trader Rating: 360 (100%+)
Thanks. Didn't come out as well as I liked. Messed up the faskmask (trying a different brand). But nothing that can't be made to look nice without some nice decals
The bearings look improved in the v3 kit. I put a full set of Acer Ceramics in mine and a little Tresrey bling (servo arm and rear diff loop). Refreshed the electronics with a new RS Pro (with v2.23). Will see how she rolls tomorrow night
tobamiester is offline
Old 04-24-2012, 07:05 PM
  #10144
Autocratic's Avatar
Trader Rating: 26 (100%+)
Where did you get the Finnisher body?
Autocratic is offline
Old 04-24-2012, 07:07 PM
  #10145
My LHS has them in stock
Old 04-24-2012, 07:49 PM
  #10146
Autocratic's Avatar
Happen to know where they got them from? JC website doesn't even have them up and I don't see them anywhere online.
Old 04-24-2012, 07:59 PM
  #10147
Ray Kindstrom's Avatar
Trader Rating: 153 (100%+)
Tower has them:
http://www3.towerhobbies.com/cgi-bin...&I=LXCEZC&P=FR
Ray Kindstrom is offline
Old 04-25-2012, 03:27 AM
  #10148
ScottyM's Avatar
Trader Rating: 27 (100%+)
Originally Posted by DBL15
8.5 = 24
or
6.5 = 21 or 22
hope that helps
Thanks. That helps alot..
ScottyM is offline
Old 04-25-2012, 06:24 AM
  #10149
dexon555's Avatar
Looks sweet, but where's the Ti turnbuckles, and is that shoe goo on the screws on the bottom of the chassis?
dexon555 is offline
Old 04-25-2012, 06:49 AM
  #10150
The TI turnbuckles seems like alot of money..but I guess I'm in for $100 in bearings so a little more wont hurt Bottom is covered in AE Chassis guard. Will see how it lasts. I predict maybe one race night
Old 04-25-2012, 06:58 AM
  #10151
dexon555's Avatar
The 3m guard?
dexon555 is offline
Old 04-25-2012, 08:00 AM
  #10152
The 3m guard?
maybe manufactured by 3M. Was packaged in AE packaging. It has an adhesive backing. Just had to cut it out.
Old 04-25-2012, 10:02 AM
  #10153
jmackani's Avatar
Trader Rating: 14 (100%+)
Finally, figured out why there was no real part number for the new oversized 1deg rear hubs. They just kept the old 1deg part number and when you order the old number you get the new oversized hubs. Just blindly ordered the old hubs from A-Main and received the new oversized hubs in the TD package with the old number. Mystery Solved!
TDR330007 Team Durango 1 Rear Hub Set (This part# brings a left and right 1deg oversized rear hub) The product pictures show the old standard size hubs.
You're lucky. The last set I ordered were still the old ones.
jmackani is offline
Old 04-25-2012, 10:06 AM
  #10154
Woulvesbaine's Avatar
Thinking a 4wd buggy may be my next purchase. Considering the v3 now that parts and supply seem to be on the mend. How solid is it?
Also, sometimes I come across a 2010 spec available as lightly used etc. Would you take a 2010 spec over a v3? What are the differences?
Woulvesbaine is offline
Old 04-25-2012, 11:36 AM
  #10155
dexon555's Avatar
DEX410 is extremly durable and very quick. If you can afford the V3 Kit new then buy it. Otherwise a reasonably priced Spec is the way to go.
The Spec was the "Super" kit in 2010 ($650), it had all the available upgrades, including but not limited to Ti Turnbuckles (even for Sway Bars) and the $100 set of aluminum side rails. It lacked the newer options like the machined diff gears and FAT shocks (however many people still run the standard shocks depending on the track).
The V3 has many new improvements the Spec did not, the FAT shocks, counter sunk chassis screws, more camber link adjustment holes, longer center drive shaft coupler, and new "Pill" type anti-squat adjustment system, and TiNi shock shafts. It also uses the new HD ball cups but with steel turnbuckles and the shock stand offs are cheap plastic unlike the metal type found on the Spec. The rear diff holders are also plastic, not alloy like on the Spec. The Spec came with full rubber boots, for axles and shock shafts. The spec also came with machined alloy servo mount and ackerman.
Bearings on the SPEC were absolute garbage!! The V3 seems to have better quality bearings but I would still replace them with a bearing kit anyway.
Another huge change was new 14mm hexes and new rims for the v3. The Spec used a hex front and a pin type rear, but 14mm hexes can be easily changed out on the Spec.
So in conclusion, it's just about parts lists, every thing that works on the Spec will work on the V3 and any improved parts on the V3 will work on the Spec.
dexon555 is offline
