Like Tree22Likes
Old 04-17-2012, 05:30 PM
  #10051
dexon555's Avatar
Default DEX410
Originally Posted by gene1219
my 'rango
Nice Looking 410 Gene.
dexon555 is offline
Old 04-18-2012, 05:14 AM
  #10052
DCNash55's Avatar
Default servo horn
ok so after 5 hours of searching and reading i still cant find a replacement servo horn thats not going to strip out in 2 laps.... can anyone provide a part number? preferably to amain, i have a rather large order ready, and would like to add this so i can get it here for racing this weekend....
futaba bls451
dex 410R (2010)
DCNash55 is offline
Old 04-18-2012, 05:32 AM
  #10053
Trader Rating: 78 (98%+)
futaba bls451
dex 410R (2010)
I use the racers edge pro servo horn. But I don't think your servo would last...
Raul Garcia is offline
Old 04-18-2012, 06:17 AM
  #10054
DCNash55's Avatar
whys that?
DCNash55 is offline
Old 04-18-2012, 06:21 AM
  #10055
whys that?
Plastic gears....
Old 04-18-2012, 06:32 AM
  #10056
DCNash55's Avatar
Plastic gears....
what servos do you recommend?
DCNash55 is offline
Old 04-18-2012, 07:25 AM
  #10057
Hitec 7940 FTW.
Old 04-18-2012, 07:57 AM
  #10058
whys that?
The DEX410 has a servosaver so I think you will be ok with your servo, even if it has plastic gears.
ridgeracer is offline
Old 04-18-2012, 09:41 AM
  #10059
JosephBlack's Avatar
Is TD330022 for the Big bores or the small bores?
JosephBlack is offline
Old 04-18-2012, 10:16 AM
  #10060
dexon555's Avatar
Default Servo Info
futaba bls451
dex 410R (2010)
I also use the racer's edge servo horn. Team Durango also has an aloy servo horn that should work well.
The servo I use is a SAVOX sc-1251mg, Low Profile. It is a bit noisy but works well. The small size also makes room for a transponder mount up front.
dexon555 is offline
Old 04-18-2012, 10:41 AM
  #10061
boudin4evr's Avatar
Trader Rating: 18 (100%+)
Originally Posted by dirtydan
I am using 10k mugen oil front and rear. 1 degree rear carriers and 1.2mm sway bar in the rear and the car is money.
what dirt surface?
traction?
was debating either 10000 f&r or 12000 f&r
what would be the difference?
thanks
boudin4evr is offline
Old 04-18-2012, 10:55 AM
  #10062
I have my transponder mounted under my front diff. It's stealth...
Old 04-18-2012, 11:17 AM
  #10063
The BLS451 has metal gears with the exception of the plastic primary. I've been using this servo in my 410 for some time now and have had no issues.
What's up Raul?
scurry is offline
Old 04-18-2012, 12:57 PM
  #10064
What's up Raul?
Shane, how's it going... We now have parts support.. loving it. My 210 is completely different than the last time we raced. My 410 is almost there. How you doing?
Plastic gears in servos dont last .. you need a 7940.
Old 04-18-2012, 01:01 PM
  #10065
TAMAK's Avatar
Trader Rating: 29 (100%+)
Shame, how's it going... We now have parts support.. loving it. My 210 is completely different than the last time we raced. My 410 is almost there. How you doing?
Have you tried the Durango 210 gear diff at all. I was thinking of getting one now that they are in stock.
TAMAK is offline
