Like Tree22Likes
Old 03-30-2012, 02:22 PM
  #9871
mdl060374's Avatar
Well, its been awhile since I got the kit, but finally got the elctronics installed and took it outside on the pavement for a test run. I was very impressed and am looking forward to getting it on the track. It seemed relatively quiet compared to what I was expecting from reading the forums.
However..... One area of concern is that within 2 minutes, the front ballcup came unscrewed to the bolt that holds it to the steering hub (wheel side).. (Luckily I found the gold washer that fell off) so I loctited it down really well.
Round2, same thing happend on the other side within 2 minutes. Unfortuantely I lost the washer this time.
Now is this just a matter of loctiting the hell out of it, and using pliers on the ballcup to get a real secure screw down? (I was hesistant b/c I didnt want to scrape or break the ballcup initially. But bviously I will have to risk it going forward.)
Or is this something that someone has an aftermarket fix for?
(I did notice when building the kit it seemed like not the best way to secure a ballcup since they are made w/o any treads for a wrench to fit on... But I figured it wouldnt be an issue. Looks like I was wrong)
Any advice would be great.
mdl060374 is offline
Old 03-30-2012, 02:33 PM
  #9872
Suspended
Trader Rating: 440 (99%+)
Hey guys I just picked up a near new 2 run old DEX410R buggy. I was just wondering if there are any must have upgrades for it that I should order right away. Or if it's good to just throw some electronics in it and hit the track?
MattP is offline
Old 03-30-2012, 03:25 PM
  #9873
tobamiester's Avatar
Trader Rating: 360 (100%+)
Congrats on getting the buggy Recommended hop-ups are here:
http://www.rctech.net/forum/10000411-post8515.html
tobamiester is offline
Old 03-30-2012, 04:07 PM
  #9874
Jpm1's Avatar
Does anyone know we're to find jorn's setup sheet from this years reedy race?
Jpm1 is offline
Old 03-30-2012, 04:27 PM
  #9875
Autocratic's Avatar
Trader Rating: 26 (100%+)
It's on the Team Durango website.
Autocratic is offline
Old 03-30-2012, 04:45 PM
  #9876
Jpm1's Avatar
I've looked but can only find the 2011 setup not 2012.
Jpm1 is offline
Old 03-30-2012, 05:30 PM
  #9877
Suspended
Thanks.
MattP is offline
Old 03-30-2012, 06:29 PM
  #9878
jmackani's Avatar
Trader Rating: 14 (100%+)
Any screw into metal should be done with locktite. In addition, the ball cup has a hole in it. The ball stud head uses an allen wrench to tighten through the ball cup itself.
jmackani is offline
Old 03-30-2012, 06:46 PM
  #9879
Autocratic's Avatar
DEX410v3 - US - West Coast
Both Jorn and Ryan 2012 Reedy setups are on there.
Old 03-30-2012, 06:47 PM
  #9880
jmackani's Avatar
Lutz also keeps all of his on http://lutzinator.com
jmackani is offline
Old 03-31-2012, 01:54 AM
  #9881
Jpm1's Avatar
Found it, I wasn't looking under v3, looking at jorn's setup, the color springs he was using makes me think he was using small bores, does anyone know if this is right or was he using different colored springs from standard with the big bores???
Jpm1 is offline
Old 03-31-2012, 02:23 AM
  #9882
onekiwi's Avatar
Jörn uses the small bore shocks, they are pretty darn good as well
onekiwi is offline
Old 03-31-2012, 01:30 PM
  #9883
dirtydan's Avatar
Trader Rating: 47 (100%+)
if anyone is looking for a 410v3 i may have one for sale.
dirtydan is offline
Old 04-01-2012, 08:11 AM
  #9884
Autocratic's Avatar
Ok.
Does anyone know what TD# gives you the 0° hubs in the large outer bearing?
340008 - small bearing, no markings on the hubs
Also, are the front steering blocks different or are they all the same?
Old 04-01-2012, 08:57 AM
  #9885
jmackani's Avatar
Ok.
340071
If you get it, let me know if the 1 degree hub is also on the parts tree.
jmackani is offline
