Like Tree22Likes
Old 03-27-2012, 08:14 AM
  #9826
FLHX1550's Avatar
Originally Posted by Rideordieguy1
What's up dude! I got my V3 from Tresrey-USA. The R version seems to
Always be in stock
Check the online store!
Thanks!
FLHX1550 is offline
Old 03-27-2012, 08:22 AM
  #9827
FLHX1550's Avatar
Any possibility to run B44.1 wheels front and back on the DEX410? I already have a stock pile of wheels/tires to fit the rear of my TLR22, just wondered if it is possible.
FLHX1550 is offline
Old 03-27-2012, 08:55 AM
  #9828
Trader Rating: 19 (100%+)
B44 fronts will bolt on, but will rub slightly at full lock, assuming they are the same wheels on the B44.1 as on the original. Rears will work- depending on if you have pins or hexes you will either need shorter drive pins or the j concepts hex adapters.
Jonny5 is offline
Old 03-27-2012, 09:07 AM
  #9829
dexon555's Avatar
Default 410
My pivot balls did strip with very slight tension! I was surprised especially with it being from my v3 kit! So I just run rear sway bars anyway! Other than that it's a great buggy!
Ball studs for turnbuckles? or Pivot balls for swaybars?
dexon555 is offline
Old 03-27-2012, 09:09 AM
  #9830
dexon555's Avatar
Default 410
Originally Posted by DBL15
Same for me mate rear only for sway bars
Below is a link to the tech article about the swaybar mod, it can be found in the Tricks and Tips section of their web site. I would not build a Durango without checking all those articles first.
http://www.team-durango.com/blog/cat...ndtips/page/2/
dexon555 is offline
Old 03-27-2012, 09:22 AM
  #9831
Rideordieguy1's Avatar
Trader Rating: 45 (100%+)
Cool Sway bar
The swaybar studs. The ones for spec never had problems. Guess it was the cone shaped set screws per the TD site.
Rideordieguy1 is offline
Old 03-27-2012, 11:23 AM
  #9832
Autocratic's Avatar
Trader Rating: 26 (100%+)
What version of 410 are you talking about? B44 front wheels are 12mm hexes.
Autocratic is offline
Old 03-27-2012, 11:59 AM
  #9833
dexon555's Avatar
Default SPEC
I had the same issues on my spec, I dug through the archives and found the solution. It works well now.
dexon555 is offline
Old 03-27-2012, 12:09 PM
  #9834
Possible then that the b44 hexes are needed. A friend I race with used his old b44 wheels without issue for the first few months he raced the 410, so its definitely do able. Blasphemy, but do able
Jonny5 is offline
Old 03-27-2012, 12:30 PM
  #9835
Trader Rating: 79 (99%+)
ok.. everyone breathe.. associated style wheel/losi front wheel are used with orginal 410 versions. V3 or V3r use 14mm hex,. you can retro the new car to the old style to fit current b44 front rim. Proline or J concepts make a 12mm hex conversion for the rear.
Raul Garcia is offline
Old 03-27-2012, 12:32 PM
  #9836
morgoth's Avatar
I took my car out for the first time since october at a club race. The track was a little bumpy in the morning, but my car was dialed thru the jumps.
I was running dark blue spring in the front and 4x1.4 hole pistons with 400cts oil in them. And the light greens springs in the rear with 5x1.3 pistons and 300cts oil. My car soaked every bump while other cars were bouncing thrue the ruts and jumps.
The steering of my car was very aggressive on turn in (long front links in the lowest position), but that was exactly what I needed on the tight car. My car had so much steering and changed direction very fast. In the afternoon the track was really bumpy but my car was still going great while the other buggies really started to have problems. Damn, I love this machine
morgoth is offline
Old 03-27-2012, 05:40 PM
  #9837
Trader Rating: 156 (100%+)
Just cleaned my car up and put a few new parts on.
Breeze is offline
Old 03-27-2012, 05:46 PM
  #9838
Konich's Avatar
I see some stuff I REALLY like!
Konich is offline
Old 03-27-2012, 06:02 PM
  #9839
ozzy-crawl's Avatar
Trader Rating: 14 (100%+)
that looks very very sweet
ozzy-crawl is offline
Old 03-27-2012, 06:23 PM
  #9840
Autocratic's Avatar
Can someone give me a quick refresh on tires?
Losi front Blockheads
Losi front/rear Sprints
Proline Holeshots front/rear
When do/don't use these tires on this car?
Anyone got any opinions?
