Like Tree22Likes
Old 03-26-2012, 12:25 PM
  #9811
dexon555's Avatar
Default DEX410
Originally Posted by mcheroke
Took my v3 and 210 out to sdrc yesterday for the first time out. The 410 has to be the most fun car I have ever driven hands down. I didn't break anything but I did run into a problem towards the end of the day however. The screw backed out of the bottom of one of the aluminum c hubs (should have used red locktite I guess not blue) and the chromed hat bushing fell out somewhere over the double tabletop. Does anyone know if the hat bushing from the tlr 22 would work since I'm sure these aren't available from Durango? The inside diameter of the bushing should be the same since it uses an m3 screw to attach thru the bottom of the steering knuckle into the c hub.
+1 on the huge fun factor.
Those bushings are available everywhere. You gotta put a tiny dot of TD's red thread lock on any screw that fastens to metal. Check also where the servo link arm connects to steering link. its an upside down tapered screw that fastens to a pivot ball. A place the manual fails to show thread lock application.
dexon555 is offline
Old 03-26-2012, 12:29 PM
  #9812
TAMAK's Avatar
Trader Rating: 29 (100%+)
If you bought the V3 new, it should have came with one extra. At least the old Dexx410's did
TAMAK is offline
Old 03-26-2012, 01:03 PM
  #9813
mcheroke's Avatar
Trader Rating: 15 (100%+)
Funny you mentioned the servo link, that loosened up and I lost steering in the first couple of laps. A little loctite fixed that. I checked the bag o spares that Durango includes in the kit and there wasn't an extra hat bushing. I did check Durango's website and it shows they are available but we all know the website is full of poop 90% of the time. I placed a call to my lhs this morning and they are seeing if HRP really has them in stock.
Has anyone had issues with the sway bar pivot balls stripping out while trying to tighten the setscrew down to the wire?
mcheroke is offline
Old 03-26-2012, 02:58 PM
  #9814
dexon555's Avatar
Default DEX410
You are right about the knuckle bushings, I did a online search and they were backordered. How the TD parts site works is, if the item is shown as in stock there (green bars) then the parts exist in Germany. HRP, just has not ordered, or received it yet. The good / bad news is that if you wanted to you could order the parts direct from Germany. This however is very expensive because they only ship to U.S. in next day format. You could also check e-bay, people have developed a cottage industry of buying complete kits and parting them out. Other alternatives are companies like TSR Products, Tresrey, DE racing, Proline (for Bodies) etc...
Below is a link to the tech article about the swaybar mod, it can be found in the Tricks and Tips section of their web site. I would not build a Durango without checking all those articles first.
http://www.team-durango.com/blog/cat...ndtips/page/2/
Don't give up, it's still the fastest car out there. Parts availability will get ten-times better when the HRP contract expires. Hope this helps...
dexon555 is offline
Old 03-26-2012, 03:11 PM
  #9815
hi im going to buy the orion r10 and i want to know if it fits well in the car becouse i have a mamba max and i have to put it sideways I know the lrp and the tekin are smaller but I like the orion (if it dosnt fit well I would buy lrp) and I appreciate so much if you can put a pic and by the way anybody knows if it can be adjust without the programming box?? its so expensive...
tomi30 is offline
Old 03-26-2012, 04:25 PM
  #9816
Rideordieguy1's Avatar
Trader Rating: 45 (100%+)
Cool +1 on swaybar...
My pivot balls did strip with very slight tension! I was surprised especially with it being from my v3 kit! So I just run rear sway bars anyway! Other than that it's a great buggy!
Rideordieguy1 is offline
Old 03-26-2012, 08:32 PM
  #9817
Autocratic's Avatar
Trader Rating: 26 (100%+)
Can someone give me a quick refresh on tires?
Losi front Blockheads
Losi front/rear Sprints
Proline Holeshots front/rear
When do/don't use these tires on this car?
Autocratic is offline
Old 03-26-2012, 08:36 PM
  #9818
DBL15's Avatar
Same for me mate rear only for sway bars
DBL15 is offline
Old 03-26-2012, 09:18 PM
  #9819
Trader Rating: 19 (100%+)
Not an Orion, but the Tresrey GT2.0 Pro is similar size and fits well. The Orion will fit no problem, as long as your receiver isn't as big as the old grey Spektrums
Jonny5 is offline
Old 03-26-2012, 09:21 PM
  #9820
Qwkrn U's Avatar
Trader Rating: 133 (100%+)
Orion R10 fits fine as long as you are careful where you put everything. I'll get a pic later of mine. I had a tekin rs pro before and replaced it with the R10.
Qwkrn U is offline
Old 03-26-2012, 10:16 PM
  #9821
ozzy-crawl's Avatar
Trader Rating: 14 (100%+)
Hopefully the hobbywing v3 will be out in the next few weeks. should be a bit cheaper than the orion. the program box is about 1/3 the price
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-hobbywing_v3_esc_2.jpg
ozzy-crawl is offline
Old 03-27-2012, 06:45 AM
  #9822
FLHX1550's Avatar
I really wish I could find the "new" R version of this car somewhere
DEX410Rv3
If someone knows where to get one, let me know. I would go with the V3, but are unavailable still from HRP
FLHX1550 is offline
Old 03-27-2012, 06:58 AM
  #9823
jonny5 thks for the pic!!
the 160 2-3s comes only with foward/brake? can you change to foward/ brake/reverse or adjust it without the setting box?
tomi30 is offline
Old 03-27-2012, 07:26 AM
  #9824
Cool Dex 410 V3 R...
DEX410Rv3
What's up dude! I got my V3 from Tresrey-USA. The R version seems to
Always be in stock
Check the online store!
Old 03-27-2012, 08:11 AM
  #9825
jmackani's Avatar
DEX410Rv3
http://www.absolutehobbyz.com/produc...oducts_id=7777
jmackani is offline
