Like Tree22Likes
Old 03-18-2012, 06:27 PM
  #9721
tobamiester's Avatar
Trader Rating: 360 (100%+)
Originally Posted by Jpm1
Hey Scotty, the x-rings are crud, they leak instantly unless you pack them with a shim in my experience, the v3 ones are the 408 shock seals, I use kyosho p5's in mine and they seem to work, although after a few races there always seems to be less or next to no oil in the diffs with no apparent leaking......
x-rings are not good. Been using the P5's in mine all year with some Green Slime. No leakage at all.
tobamiester is offline
Old 03-18-2012, 07:43 PM
  #9722
Building/upgrading a 410R for a friend. Can't find a TD330004 (Front Susp holder) anywhere. If you have one or know anywhere in the US that has one in stock, pls pm me. Cheers
Old 03-18-2012, 08:09 PM
  #9723
rcmorgan540's Avatar
Default Sell?
So I just bought a 410 v3 from a member here. It will be in tomorrow. In the meantime, I broke down and bought a 408. I will more than likely sell the 410 just because it's a smaller class. My question. Assuming I sell the kit BRAND NEW. Do you think I will hurt the value by going ahead and building the kit to sell as an assembled race roller, or just keep it in the box. I really like building so I don't mind putting in the time. I would really appreciate some feedback on this.
Thanks!
rcmorgan540 is offline
Old 03-18-2012, 08:17 PM
  #9724
DBL15's Avatar
Thanks!
i would not waste your time building it as anyone who buys it (if built) would pull it apart anyway to check the build
in saying that the right buyer would love it to be pre built for them it just depends who wants it when the time comes
DBL15 is offline
Old 03-18-2012, 08:26 PM
  #9725
Thanks!
I'd say yes it would de-value it. Its basically used once you build it. As most previous TD owners know, the diffs, driveline and turnbuckles all need a little special TLC.
Sell it as the un-built kit, you should be able to get 100% money back (on your deal) as these are pretty much impossible to get. my 2c.
Old 03-18-2012, 11:01 PM
  #9726
Qwkrn U's Avatar
Trader Rating: 133 (100%+)
If anyone is looking, Im selling a 410R car with all the aluminum suspension holders and a Carbon rear tower.
Also have access to a 410R V3 nib is someone needs one of those.
Qwkrn U is offline
Old 03-19-2012, 06:57 AM
  #9727
TAMAK's Avatar
Trader Rating: 29 (100%+)
FYI, Amain has the rear shock mounts and slipper pads in stock!!!
TAMAK is offline
Old 03-19-2012, 07:12 PM
  #9728
boudin4evr's Avatar
Trader Rating: 18 (100%+)
Default durango dex410r center rear driveshaft
anybody broke one of these at the cup?
I did! WTF
boudin4evr is offline
Old 03-19-2012, 08:09 PM
  #9729
jmackani's Avatar
Trader Rating: 14 (100%+)
I did! WTF
I have on my dnx408.
jmackani is offline
Old 03-19-2012, 10:29 PM
  #9730
Trader Rating: 19 (100%+)
I did! WTF
How old was it? It's natural for moving parts to fatigue over time and wear out. If it was a new shaft that broke that's a different story, and I would think you could get it replaced.
Jonny5 is offline
Old 03-19-2012, 11:00 PM
  #9731
Trader Rating: 39 (100%+)
Woohoo! I got my electrics reorganized and a new body. Sooo nice.
ufoDziner is offline
Old 03-19-2012, 11:35 PM
  #9732
What wing is that?
Jonny5 is offline
Old 03-19-2012, 11:42 PM
  #9733
Originally Posted by Jonny5
What wing is that?
OFNA High Downforce Wing (Black) (CRT .5)
I'm not good enough to have a lexan wing last. These look nice and work well for me.
Old 03-20-2012, 06:45 AM
  #9734
dexon555's Avatar
Default DEX410 Rear Outside Hinge Pins
I am sick of the rear outside hige pin migration, the new rear hub design in the V3 gave me hope. That soon disapeared when the left side slid out more than 50% during practice then the pin sheared off on a ajump landing. I need hinge pins that screw together like the rear of the DESC410R or one that uses E-clips on either end of the shaft. I tried longer / larger set screw, I've even used shoe-goo to hold set screw, with limited success. Has someone solved this issue? Any creative solutions? Please share.
dexon555 is offline
Old 03-20-2012, 06:49 AM
  #9735
Trader Rating: 78 (99%+)
Maybe the Tresrey hub, will cure all.. I don't have that problem.
Raul Garcia is offline
