Like Tree22Likes
Old 03-04-2012, 12:06 AM
  #9586
DBL15's Avatar
ok guys having some heat issue's just at the end of 6 minute races
has anyone got a tekin hot wire set up they want to share for a rs pro and 6.5T tekin motor 21/87 gearing
been on the hotwire set up sheets tried running what most are running except i turned the boost off shoud l turn some boost back on?
motor temps in the 140ish and esc temps in the high 180 to mid 190ish
outside med track with 30+ second lap times
any help and advice would be great
DBL15 is offline
Old 03-04-2012, 12:17 AM
  #9587
onekiwi's Avatar
Got a fan? if not get one, make some holes in the body.
Turn timing down on motor if you can
onekiwi is offline
Old 03-04-2012, 12:23 AM
  #9588
DBL15's Avatar
how can you put a fan on a rspro ? the motor is not hot at all its the esc
yeh i am making holes in the body as well
DBL15 is offline
Old 03-04-2012, 04:56 AM
  #9589
Trader Rating: 18 (100%+)
Anyone running a Revtech saddle pack and figured out how to get it to fit correctly? I really want to run the battery I have.
****Got it to fit. If anyone has an issue fitting a battery, just man up and push the tie down forward, and down until the pin can go through the holes.****
beenaround is offline
Old 03-04-2012, 05:51 AM
  #9590
dirtydan's Avatar
Trader Rating: 47 (100%+)
I was running the same tekin setup and my motor would come off at 120 and the esc at 142 after 6 min. I was running 20/87. Make sure you don't have drag brake on. Also make sure not to over tighten the wheels. If that's not the issue turn down the current limiter to 85 and see where your temps are. If the esc is still over 150 I would drop down to a 20t pinion.
dirtydan is offline
Old 03-04-2012, 08:17 AM
  #9591
Trader Rating: 54 (100%+)
anyone know the overall lenth and stroke of the non big bores and maybe want to sell them ?
rkhess is offline
Old 03-04-2012, 10:35 AM
  #9592
onekiwi's Avatar
I have one for mine and still lots of room
onekiwi is offline
Old 03-04-2012, 12:24 PM
  #9593
DBL15's Avatar
ok mine went higher with the 20/87 gearing thats why i went up to a 21 and it dropped a bit
hmm no drag brake you say ? ok i will turn that off as its at 15% and yes current llimiter is all ready down at 80%
@onekiwi = cool mate i might look at trying to mount a little fan like what you have done , thanks for information and picture mate
DBL15 is offline
Old 03-04-2012, 04:19 PM
  #9594
jmackani's Avatar
Trader Rating: 14 (100%+)
Default Wheel Hex roll pins
Anyone find a substitute for the wheel hex roll pins? We had one snap today and by luck I have from the spares in the kit. I noticed this part is not in stock any where.
jmackani is offline
Old 03-04-2012, 04:20 PM
  #9595
using rollpins from a associated ntc3
cm.stites is offline
Old 03-04-2012, 06:18 PM
  #9596
Trader Rating: 79 (99%+)
I use roll pins too from Associated, along with J Concepts 12mm hex conversion for the B4.1 on the rear. Standard 12mm small hex on the front.
Raul Garcia is offline
Old 03-04-2012, 08:24 PM
  #9597
dirtydan's Avatar
yea drag brake will cause your esc to heat up. i dont run drag brake on the 410, but i run about 5% on the 210.
dirtydan is offline
Old 03-04-2012, 09:11 PM
  #9598
Qwkrn U's Avatar
Trader Rating: 133 (100%+)
Piano Wire available at most hobby shops. comes in a 2-3 foot long piece. measure your pin with calipers and take that with you. They should have it. presto enough material to make 30-40 pins. I use a dremel with a cutoff wheel to cut it to size.
Qwkrn U is offline
Old 03-05-2012, 06:47 AM
  #9599
jmackani's Avatar
Thanks for the suggestions. I did notice online that shorter 1.6mm pins are available I am guessing for the older style wheels. I will probably go the piano wire route.
jmackani is offline
Old 03-05-2012, 03:32 PM
  #9600
Im sure this has happened before to someone- just finished building the car and it only goes in reverse when the car is supposed to be going forward.
Im fairly sure the diff's are in correctly, im using a Tekin RS Pro with a Spektrum SR3300T.
Any help would be greatly appreciated.
