Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
#946
Not sure if this has been mentioned before but, for those looking for a great Saddle Pack for their Durango Buggy-The Venom 30C 4200 is 23mm high and should fit nicely!
I'm using the Venom 50c 4500mah and it's awesome.
I run Venom 5000mah 40-50c in my 2wd stuff and it's been super good to me. I've had a lot better luck with the venoms than other name brand stuff
#947
Just ordered the DEX410 from A-Main. The part number is TDR102001 which matches to the 2010spec from the Team Durango website? Can someone confirm the part number from the 2009 version?
Hope this is as strong as the 1/8 buggies?
#948
If you go here:
team-durango.com/race-cars/dex410/gallery/
It says dBoots Terrabyte on the tires, but I can't seem to find them for sale anywhere! These look like a really good tire. . . I want to buy them.
P.S. I think the DEX is very durable. The thing is, it's so wicked fast that if you're not careful you will break it.
#950
The older version came with 2000wt. There is only one version of the "R". That's 2010.
#952
Bman: FYI, I just picked up a R kit and it had 2000 diff fluid not the 10000 and 5000.
#953
#955
I just got in a DEX410 PRO KIT and on the front of the box before the DEX name it say's 2010 spec on it.
It has part number TD102001 on it.
So from what i have seen,if its a 2010spec kit it will say it on the box.
SAC
SAC
#956
i will be running a lrp sxx tc with a novak 7.5 what pinion!!! do u guys suggest? stock spur of course...
#957
- Ball stud came loose and unpop
- Wheel pin (i replaced with hard steel pin and after that, never had the problem again)
- shock cap loose (oil leaking by the shock cap when the pression is too heavy
- Diff leaking (changed the oring with kyosho p4 and never had the problem again)
But as the losi 8ight, the DEX410 need time to be fully broken in
#958
If you purchased your kits from a hobby shop in the United States they are 2010 Kits from HRP Distribution. 2009 Kits where never moved threw HRP.
JT @ HRP
JT @ HRP
#959
heres a battery that fits the durango if you are looking for a higher c and mah rating, 45c 5200 mah , i just ordered mine it should be here soon
http://www.racers-edge.com/Racers_Ed...lp2s5200sp.htm
#960
JT: I bought my kit at a local hobby store and it came from HRP. He received it Friday. It had 2000 diff fluid in the box. Don't know if that signifies a 2009 kit or 2010 kit. I don't really care one way or the other, just letting people know.
