Like Tree22Likes
Old 02-08-2012, 12:39 PM
  #9391
boudin4evr's Avatar
Trader Rating: 18 (100%+)
Originally Posted by DRCRacer299
This will be a very big positive for parts availability for Durango in the USA. It's not going to happen overnight but I would say within a couple of months that parts supply for Durango products will be ample here in the USA
Just as an FYI, my shock oil is 525cst, not the same as 52.5wt. 525cst would probably equate to about 45-47.5wt. Also always note that I am not good at downsiding jumps so I set my car up to be able to flat land occasionally! ;-)
Yeah right LUTZ! you are a God at the wheel! amazing to watch you drive!
boudin4evr is offline
  #9392
joelwhite's Avatar
Trader Rating: 62 (100%+)
Originally Posted by Raul Garcia
Now, my first question. Has anyone tried a "shorty" lipo yet? It does fit. Any track results with one?
Been running a CRC shorty for a while now. Its a direct fit if you run the leads to the back. I put some weight on both sides to keep the pack in the middle. It stays well on its own,may not be needed. But the rear is pretty light anyway. I do run the brass on the sides and rear skidplate. I like how the one pack cleans up the whole area though. That may be the biggest thing.
joelwhite is offline
Old 02-08-2012, 01:47 PM
  #9393
Team Tekin
Randy_Pike's Avatar
What?! ha ha ha
Randy_Pike is offline
Old 02-08-2012, 04:37 PM
  #9394
Rideordieguy1's Avatar
Trader Rating: 45 (100%+)
Cool HD ball cups...
Whats up guys ordered the Lunsford turnbuckle kit for both my 210 and V3. Has any1 ran the V3 car with its stock ball Cups and do they poP off as well. Wanna run it on Friday not sure if I'll get them in by then. Thanks!
Rideordieguy1 is offline
Old 02-08-2012, 04:54 PM
  #9395
ive had no issues with my 410rs ball cups popping off after doing the reaming trick to the ends.
cm.stites is offline
Old 02-08-2012, 04:57 PM
  #9396
dangerwr's Avatar
+1
dangerwr is offline
Old 02-08-2012, 05:01 PM
  #9397
Cool Reaming?
Care to explain if u don't mind thanks!
Old 02-08-2012, 05:02 PM
  #9398
take a body reamer to the end where the turnbuckle threads in and ream the hole a little bigger then the fattest part of the turnbuckle before the adjustment knob so that theres no friction.
Old 02-08-2012, 05:10 PM
  #9399
Cool So....
So reaming the threaded part of the ball cup is going to stop it from popping off the ball stud? Thanks.....
Old 02-08-2012, 05:20 PM
  #9400
dangerwr's Avatar
I do believe it helps to make sure the turnbuckle can be adjusted freely BUT think you want to polish the ball stud a little with a dremel.
The thing is to move past the typical break-in period when it comes to the ball cups & such on this car.
dangerwr is offline
Old 02-08-2012, 05:44 PM
  #9401
it helps remove the stiffness found in the turnbuckles and allows them to move freely so they dont tend to lock up and force themselves off the ballstuds.you want them to be a tight but loose fit over the ballstud other wise if they are to tight they will continuously pop off because theres no room for play. polishing the ballstuds will also help alot. i used a dab of grease on the top of my ball studs before i put the ends on and havent had any issues.the day after i built the car i had the cups popping off while adjusting and did the reamer trick and the grease and havent had one pop off yet.
Old 02-08-2012, 06:24 PM
  #9402
Cool Cool
Cool I'll try that. Thanks for all the help guys!
Old 02-08-2012, 06:35 PM
  #9403
DBL15's Avatar
no issue's at all with the V3 unless you really mess up and give the pipe a big hit
compaired to the older 410 version they are much better
DBL15 is offline
Old 02-10-2012, 01:44 PM
  #9404
OU812_77's Avatar
how did you get the CRC shorty to fit for me it was about a 1 or 2mm to long and i could not get the battery clip in, did you modify anything?
OU812_77 is offline
Old 02-10-2012, 02:57 PM
  #9405
joelwhite's Avatar
It would only fit with the leads at the back, its snug but goes in and out fine. Kinda have to angle in too, it seems weired at first but once you got it, its easy.
