Like Tree22Likes
Old 02-02-2012, 03:34 PM
  #9301
ozzy-crawl's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Chris-s
I run on astroturf and carpet and use 2mm of limiters inside the shocks. Check the setup sheets on the Team Durango website to see what people are running.
thanks, was having trouble with the setup sheets for some reason as they were not showing full content. tried a few others and they worked
ozzy-crawl is offline
Old 02-02-2012, 06:00 PM
  #9302
dangerwr's Avatar
Originally Posted by ANiznik
i just built a new in box but older 2010 series 410 for a friend and just like to ask what pinion are guys running with an 8.5? its a tekin redline 8.5 on a older lrp tc spec esc. the car has an 87t spur. any help would be great! he has an 18t pinion on it and i'm of opinion that will be to small!
24t is a good place to start!
dangerwr is offline
Old 02-02-2012, 06:27 PM
  #9303
DBL15's Avatar
Scotty pretty sure none of us are running limiters on our shocks mate and not having any problems at all
DBL15 is offline
Old 02-02-2012, 06:58 PM
  #9304
ozzy-crawl's Avatar
Thanks Darren, wasn't sure as always had them on 1/8
Old 02-02-2012, 07:03 PM
  #9305
TAMAK's Avatar
Trader Rating: 29 (100%+)
okay guys. Question...
I notice the pros are running high diff fluid 10k 10k and Lutz is in the 30k's. Can someone explain the cars performance regarding high vs low diff fluid? I run 5k / 3k. What would say 10k / 10k do? I suppose I would change the fluid and test but will check her first.
TAMAK is offline
Old 02-02-2012, 07:07 PM
  #9306
jmackani's Avatar
I notice the pros are running high diff fluid 10k 10k and Lutz is in the 30k's. C an someone explain the cars performance regarding high vs low diff fluid? I run 5k / 3k. What would say 10k / 10k do? I suppose I would change the fluid and test but will check her first.
The heavier diff fluids make the car less touchy. Lutz started this in his desc410r and is probably carrying it over to the buggy also. In addition, if you are using the old bottles of durango fluid that were labeled 30000 and they were really 3000. I have some here both new and old with the same part number on them and they started to drop a zero.
jmackani is offline
Old 02-02-2012, 07:14 PM
  #9307
dangerwr's Avatar
I know going to Losi 5k & 3k on our track worked well for most people. I thought the buggy was more responsive and even more predictable. Last year most ran 10k & 5k.
dangerwr is offline
Old 02-02-2012, 07:17 PM
  #9308
I'm running 10k and 3k and the car is dialed!
Walkman is offline
Old 02-02-2012, 07:59 PM
  #9309
tobamiester's Avatar
Trader Rating: 360 (100%+)
Pic from ToyFair via RedRc.com
tobamiester is offline
Old 02-02-2012, 08:39 PM
  #9310
DRCRacer299's Avatar
This past weekend at the Reedy Race I ran 12k, 12k. One thing I have started doing at the encouragement of Hupo is to run a 'square' diff set-up. Meaning same front and rear. This seems to balance the car better.
Also as to why i'm running these heavier fluids. Well I started the week off with 7, 7. But I was 'diffing' out exiting corners and going heavier eliminated that issue and made the car easier to drive for me on that track.
DRCRacer299 is offline
Old 02-02-2012, 09:39 PM
  #9311
slow_jun's Avatar
Trader Rating: 14 (94%+)
Default Most expensive TD Parts i have seen
410 Midrive Clamps.
slow_jun is offline
Old 02-02-2012, 09:50 PM
  #9312
Old 02-02-2012, 10:14 PM
  #9313
ozzy-crawl's Avatar
Wow nice price mite get 2
Old 02-02-2012, 10:40 PM
  #9314
rpeker's Avatar
What body is that?
rpeker is offline
Old 02-02-2012, 11:53 PM
  #9315
Originally Posted by rpeker
What body is that?
new proline body. they have a new one for the 210 as well.
JJBTEXAS is offline
