Like Tree22Likes
Old 01-30-2012, 05:25 PM
  #9286
mdl060374's Avatar
Originally Posted by Briguy
The mold tree is the same for the v3 and 210 . You do not use the curved ends for the V3 .
Ah ok thanks. I noticed alot of extra parts lying around.
mdl060374 is offline
Old 01-30-2012, 06:01 PM
  #9287
jmackani's Avatar
Trader Rating: 14 (100%+)
Actually you may need need them depending on where you are running the rear camber links in the outer holes on the hubs to clear the inside of the rims.
jmackani is offline
Old 01-30-2012, 06:03 PM
  #9288
Briguy's Avatar
Trader Rating: 125 (100%+)
Actually , you don`t . The bent ends were made to clear the tranny in the 210 .
Briguy is offline
Old 01-30-2012, 06:50 PM
  #9289
Qwkrn U's Avatar
Trader Rating: 133 (100%+)
For those asking about bodies.
Here is the Bugleboyracing body. Hands down the coolest looking body out.
Qwkrn U is offline
Old 01-30-2012, 06:57 PM
  #9290
duckman996's Avatar
Originally Posted by tobamiester
Check the Tresrey Blog for details : http://tresreyusa.blogspot.com/2011/...t-arm-mod.html
A couple of guys modified that but just doing 2mm + 3mm so as not to make the arm too weak by taking the full 5mm off.
I just read this "mod"... I do have a question?
"Tresrey Japan also used the bent ball cup off a 210 to get some steering back if needed, however its not necessary."
How would the bent ball cup add more steering?
duckman996 is offline
Old 01-31-2012, 03:18 AM
  #9291
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Because of the angle the steering link is, it rubs on the rim at full lock. So the bent rod adds extra clearence for this.
Bman's 3XNT is offline
Old 01-31-2012, 04:04 AM
  #9292
jmackani's Avatar
If you move the camber to the farthest hole out on the rear outer hubs, the straight ball cup rubs the inside of the rim at full droop. Using the angled ball cup keeps it from rubbing at full droop. I.E. if you are using Carson Wernimont's setup from OCRC, then the straight ends will rub the inside of your rims.
jmackani is offline
Old 02-01-2012, 01:03 PM
  #9293
anybody knows any shop in the world that have any dex410 v3 in stock?
tomi30 is offline
Old 02-01-2012, 01:04 PM
  #9294
Briguy's Avatar
My friend`s shop has one left . PM me if you want the info .
Briguy is offline
Old 02-01-2012, 01:16 PM
  #9295
DBL15's Avatar
yep Venom Group in Australia have just got new stock in as well
DBL15 is offline
Old 02-02-2012, 04:59 AM
  #9296
I send them an e-mail but in their page still appears pre-order..
do you know any shop in europe?
tomi30 is offline
Old 02-02-2012, 05:46 AM
  #9297
ozzy-crawl's Avatar
Quick question, have not run a 1/10 buggy in a long time and unlike a 1/8 there is no front droop screws. Are people using limiters in the shocks or are they not needed ?
ozzy-crawl is offline
Old 02-02-2012, 08:16 AM
  #9298
I run on astroturf and carpet and use 2mm of limiters inside the shocks. Check the setup sheets on the Team Durango website to see what people are running.
Chris-s is offline
Old 02-02-2012, 09:31 AM
  #9299
ANiznik's Avatar
Default gearing an 8.5
i just built a new in box but older 2010 series 410 for a friend and just like to ask what pinion are guys running with an 8.5? its a tekin redline 8.5 on a older lrp tc spec esc. the car has an 87t spur. any help would be great! he has an 18t pinion on it and i'm of opinion that will be to small!
ANiznik is offline
Old 02-02-2012, 01:30 PM
  #9300
DBL15's Avatar
sorry not sure about Europe shops
Australia has them but there web site is not live or up to date thats all
they still have pre order for the DEX408 but we have them and built them same as the V3 there on pre order only i have had mine for over 3 months now
DBL15 is offline
