Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
#916
FYI - the Thunder Power 45C saddle packs do not fit the DEX410. I have to send mine back to amainhobbies and switch for the ProTek set. Oh well, it will save me $20.
I should have checked the height before I ordered. The Thunder Powers are 28mm high and the Durango max's at 25mm.
#917
Any of you guys break the very front hingepin holder? I've destroyed 2 and another racer destroyed one by bumping a PVC pipe.
My rear diff spur also lost 3 teeth somehow, it just started clicking so I took it apart and found this.
I got a Tie-rod out of the box with no threads also.
This car is frustrating me pretty bad. I've only got 11 laps at a small indoor track. I've only put about 1700 MAH through the battery.
Try shimming the diff in the housing so there is very little backlash between the ring gear and bevel gear. Not too tight, and not too loose. Even then, it might happen again, until you replace the kit bearings with something of better quality. I lost 1 gear before properly shimming, and 1 more after that, until I replaced the kit bearings with Avid. No more ring gear problems, since.
Properly adjusting the slipper is key to reducing broken drive pins and also reduces the chance of breaking the ring gears.
This car requires a steep learning curve, so don't give up on it. Check and double check. Strip it down a few times and inspect everything. Learn what needs more attention, and what is bullet proof. It's not perfect, ...no car is, ...but it's damn close!
Good racing!
#919
#920
#921
John..Colton did'nt break once last year did he? We just need the front outer alum. hingepin holder and were good to go.
as far as servicing the diffs.............piece of cake, now if they were ball diffs, I would be like yeah im very slow at this.........but Im a gascar racer, so that's all I work with are gear diffs, working on these is no different than a 1/8 buggy.
#922
#923
Have any of you guys played around with the rear shims on the hub and arms? What would have a greater effect on handling. the shims on the inner hinge pin or hub? I know changing the shims on the hub change wheelbase and rear traction, and I am assuming the shims on the inner hinge pin will do the same. Am I wrong on this? Or is the inner just for wheelbase and not for traction?
Thanks........
#924
shim on the arms aka hinge pins to move them foward or back does effect handling if you move them foward usually would give you more rear bite shortening the length if you move them back u would be less stable in the rear ,but the car would turn better,as far as wheels base anytime you widen the rear the more stable the car would be but also not near as responsive hope this makes since..
#929
Trader Rating: 23 (100%+)
