Like Tree22Likes
Old 01-29-2012, 03:40 PM
  #9271
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Jpm1
why over gear it?
22/85 is over-geared?
Cpt.America is offline
Old 01-29-2012, 04:34 PM
  #9272
ABBOTT's Avatar
Yes, it is. 20 should be better
Vent the body, it really is not an option if you want the temps to go down.
ABBOTT is offline
Old 01-29-2012, 04:58 PM
  #9273
Konich's Avatar
I run 85/22 with my 6.6 Tresrey V3 motor and my temps haven't been above 170. Granted I have one of those neat Gainabull bodies, but that couldn't be the difference could it?
Konich is offline
Old 01-29-2012, 05:19 PM
  #9274
ABBOTT's Avatar
85 or 87/22? I also run the Tresrey body and it does make a difference in temps.
ABBOTT is offline
Old 01-29-2012, 05:21 PM
  #9275
ABBOTT's Avatar
Congrats to Jorn on the Reedy win.
ABBOTT is offline
Old 01-30-2012, 03:36 AM
  #9276
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Yup, you beat me to it......
Jorn Neumann and Team Durango, Reedy Race of Champions.......Champion!rango,rango,rango.........
Bman's 3XNT is offline
Old 01-30-2012, 11:23 AM
  #9277
Trader Rating: 29 (100%+)
do you know which one buy a dex410rv3 or dex410v3 ?
taztal3 is offline
Old 01-30-2012, 11:32 AM
  #9278
onekiwi's Avatar
If you can get it the V3 hands down.
It will cost you more to upgrade the RV3 to the V3 if you decide to, although you can see durangos top driver uses the small bore shocks, that can save you some $$
onekiwi is offline
Old 01-30-2012, 02:18 PM
  #9279
Default This past weekend...
I finally got to run a race day with my Durango and it was a blast.
Round 1
The wheelers didn't show up in the numbers we expected, but we got enough for our own class. One guy ended up breaking and couldn't finish the day. So it was me vs. my good friend. He is a much better driver but the DEX410 gave his XX4 the business. It was pretty cool because there is a big triple that I make, no worries about breaking, and he doesn't. I kept making ground when he was in front, or adding to my lead when I was. Unfortunately my ESC hit thermal and it was all over with only 28 seconds left to the round.
Round 2
Still trying to figure this one out, as it happened in the main too, but I stripped my spur gear out. The mesh seemed fine.
A-Main
When checking in I flipped upside down, yelled out to warn other drivers, and proceeded to have a ST land right on top of me. (The RD combined classes when we were down to two). Everything seemed fine from the drivers stand except my wing appeared to be smashed/bent. We take off and after two laps the XX4 broke. After the race was done, I realized that I finished the whole race with a broken rear bulkhead, which explains the goofy looking wing. On the last lap my spur let go again so I still need to figure out whats going on there.
All in all I'm still happy, even having to replace parts...
J.Pietsch is offline
Old 01-30-2012, 02:25 PM
  #9280
t8rtot's Avatar
Trader Rating: 14 (94%+)
Round 1
Round 2
A-Main
look at venting the body and loctite your screws
t8rtot is offline
Old 01-30-2012, 02:27 PM
  #9281
dangerwr's Avatar
Man, I wish I could come up with a good reason as to why you are stripping spurs. Is the screw that connects the motor plate to the plastic mount tight? Can the assembly twist at all? And if your bearings are good I can not imagine why your spur is stripping. Beyond me!
dangerwr is offline
Old 01-30-2012, 05:00 PM
  #9282
mdl060374's Avatar
Quick question regarding assembly. I noticed there are 2 different types of ballcups (not including the sway bar mini ones).
One is slightly curved, and a bit longer, but I dont see where to use these in the diagram. I am guessing the rear arm attached to the hub?
From looking at the diagram, they all look flat. Probably not a big deal, but I just cant figure out where they go, if anywhere.
mdl060374 is offline
Old 01-30-2012, 05:06 PM
  #9283
ozzy-crawl's Avatar
Trader Rating: 14 (100%+)
some guy is probably at home putting a 210 together wondering were his ball cups are
fairly sure all the 410 ones are straight
think the 210 has slightly curved ones
ozzy-crawl is offline
Old 01-30-2012, 05:10 PM
  #9284
Briguy's Avatar
Trader Rating: 125 (100%+)
The mold tree is the same for the v3 and 210 . You do not use the curved ends for the V3 .
Briguy is offline
Old 01-30-2012, 05:16 PM
  #9285
Without more information... I would guess that you aren't snugging down your motor screws enough, and the motor is backing itself out just a tad as you run around the track, and bzzzzzz!!!! stripped spur.
