Like Tree22Likes
Old 01-17-2012, 01:13 PM
  #9091
tobamiester's Avatar
Trader Rating: 360 (100%+)
Originally Posted by grapejuice
Always use red on the cvds though, you can still get them out by heating them up with a lighter or soldering iron tip. I've used the kit red with no issues, but I use some I bought from the auto parts store now.
Yup +1 on Red threadlock on all CV's on the drive train. Its absolutely the safest thing to do with this car.
tobamiester is offline
Old 01-18-2012, 07:58 AM
  #9092
front and rear diff oil setups? clay with a 6.5
slumpin is offline
Old 01-18-2012, 08:08 AM
  #9093
JOJOHAMBONE's Avatar
Trader Rating: 31 (100%+)
Ive been running 10k front and 7k rear with my 6.5 on a outdoor clay track and it seems to do well that will be a good starting point.
JOJOHAMBONE is offline
Old 01-18-2012, 08:54 AM
  #9094
t8rtot's Avatar
Trader Rating: 14 (94%+)
i really like the 10k FR and 5RR. i've been to 3tracks and it is a good starting point.
with this car you really can adjust it to fit your driving style. just play around with oils and you'll find a sweet spot.
t8rtot is offline
Old 01-18-2012, 09:16 AM
  #9095
ABBOTT's Avatar
+1 Oil choices can really very depending on dirver and track but those both sound like reasonable starting spots.
ABBOTT is offline
Old 01-18-2012, 09:17 AM
  #9096
dangerwr's Avatar
+1. This setup worked well for me and then tried 5k & 3k and liked it better on our smaller track.
dangerwr is offline
Old 01-18-2012, 09:27 AM
  #9097
Shark413's Avatar
Trader Rating: 24 (100%+)
I saw this posted over on oOple, is this a real problem? Is there a solution? I have not had any issues with my servo but it does look like the saver is blocked at full lock.
Posted by eNick on oOple:
Hi,
In some side position of steering the saver function of servo saver is blocked by servo body. Marked by red arrow on the picture below.
Shark413 is offline
Old 01-18-2012, 09:28 AM
  #9098
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Does anybody know where the v3 is available for purchase? Out of stock everywhere.
Cpt.America is offline
Old 01-18-2012, 09:36 AM
  #9099
Team Tekin
Randy_Pike's Avatar
Hi,
It appears he's got his servo spaced out off of the mount. Not sure why but this "idea" is causing the rub in the first place.
Randy_Pike is offline
Old 01-18-2012, 09:38 AM
  #9100
Hi,
maybe when he built the servo arm (330001) its built too short , left out spacer 390024 ?
Old 01-18-2012, 10:19 AM
  #9101
Atomicsickness's Avatar
Trader Rating: 26 (100%+)
Hi,
I think the point that is trying to be made here is not the rubbing. If you look how the servo saver is suppose to work even if there was say a 2mm or 3mm it would still expand down and hit the servo once the saver was engaged.
Atomicsickness is offline
Old 01-18-2012, 10:32 AM
  #9102
dangerwr's Avatar
Last year the was a bit of discussion of certain servos not fitting well in the DEX410. Not sure if this is one but have known people that have taken a dremel to the top of their servo for fit issues.
dangerwr is offline
Old 01-18-2012, 11:14 AM
  #9103
BLKNOTCH's Avatar
This is very very upsetting indeed as I have preordered DEX410V3 from my LHS www.averagejoesrc.ca back in November 2011 and am still waiting on it to arive?!?!?!?!?!?! and from what I understand it may be another month before it arrives grrrrrrrrr.
BLKNOTCH is offline
Old 01-18-2012, 11:18 AM
  #9104
It ain't pretty but a pic of my Futaba S9452. You can see clearance between servo and arm. So like Danger said, its likely a servo choice issue...
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-img00302-20120118-1407.jpg
Old 01-18-2012, 11:21 AM
  #9105
Yeah, can't get them anywhere right now. I have a nice DEX410 2010 Spec for sale if anyone wants to get on the track right away with the 410 platform
