Like Tree22Likes
Old 01-15-2012, 04:32 PM
  #9061
Originally Posted by jimkoimanis
I had the same problem when I was running ballistic motors I found that the sensor port on the back of the ballistic motor was playing up
What do you mean by playing up? sorry my english is not so good.
putte_Rolf is offline
  #9062
Originally Posted by ABBOTT
Cant hurt to try, but when you geared down(19 tooth) the motor temp went down and esc went up, that tells me the pinion is getting to small. I think 20-22 is common for a 6.5 in this car.
I remember Danger talking about the Novaks on occasion, maybe he has something he can add. I'm just not familiar with their products anymore.
Okey I will try a 20t next time i drive.
Old 01-15-2012, 04:40 PM
  #9063
jimkoimanis's Avatar
The sensor port was faulty
I changed motors and put my Orion motor in the esc temp went back to normal I tried the ballistic motor on my viper speed and it wouldn't work no power and esc started to get hot
jimkoimanis is offline
Old 01-15-2012, 04:42 PM
  #9064
Okey thanks for the info.
I will try out a 20t and see if that helps. if not i will try a other motor.
Old 01-15-2012, 04:46 PM
  #9065
No problems i have two ballistics that do the same thing I would be changing motors be4 u do any damage to the brain board on the esc
Old 01-15-2012, 06:18 PM
  #9066
Slash and Burn's Avatar
Trader Rating: 24 (100%+)
I'm running a 8.5 in my V3 and am running a 18t pinion. Temps are normal after a 5 minute race. I would say try running a lower pinion, but you may have other issues that others have written about.
Slash and Burn is offline
Old 01-15-2012, 06:20 PM
  #9067
what is the lowest pinion that fit v3 with standard spur gear?
Old 01-15-2012, 07:30 PM
  #9068
Trader Rating: 27 (100%+)
anyone have a bigbore setup for high traction clay?
C_Money is offline
Old 01-15-2012, 08:21 PM
  #9069
Trader Rating: 25 (100%+)
I'm running on high traction carpet with stock sways on it, and I'm at 35wt front and 30wt rear. Hope this helps I've only ran a few times but those few times but haven't had traction rolling even with fast turning on ridiculous traction with soft compound tires.
D-A-N-4-4 is offline
Old 01-15-2012, 10:12 PM
  #9070
Don't know
Old 01-15-2012, 10:13 PM
  #9071
PM me your email and I'll email you a couple setups from our track.
Old 01-15-2012, 11:17 PM
  #9072
Qwkrn U's Avatar
Trader Rating: 133 (100%+)
If you have Coultons latest setup in PDF form email it to me.
Qwkrn U is offline
Old 01-15-2012, 11:49 PM
  #9073
Thanks for asking, cause I just realized I hadn't put his on a pdf. I'll do it and email it to you.
Old 01-16-2012, 04:50 AM
  #9074
jackdani's Avatar
hi guys,
i would like to ask a couple of quick questions!
i m about to buy a dex410 v3, as soon as it gets to my local shop,
and i m wondering which electric to be used.
some one told me to use 6.5 motor...
but i already have a gm 10.5 spare motor which i could use on this one,
furthermore when i went to the track (indoor-small) the first time they told me they all use 10.5 or 8.5 motors and that they usually race a free category in which every one can use every motor turns.
So my question is:
1)in case i use my gm 10.5 is it fine run it with sxx stock specv2?
2)do you suggest to use timing on esc?
3)and which pinion usually goes with 10.5??
(because i only know they use 18/19 pinion for 6.5)
4) servo department: is it fine a sanwa sdx-801??
[use of the car will be: bashing and some race at the track mentioned ^]
thank you very much, every help is really appreciated!!!
jackdani is offline
Old 01-16-2012, 10:10 AM
  #9075
I've officially joined the Durango family. I traded my SSC LCG Slash 4x4 for a Durango DEX410R. First time running a buggy of any sorts, and I have to say this thing is amazing. I have only raced SCTs, both 2wd and 4wd. This buggy makes them feel like gigantic turds.
I outfitted it with my spare electronics which include:
  • LRP SXX Comp V2
  • LRP X12 5.5 w/ 13mm rotor
  • KO Propo Servo
It has all the acceleration my TEN-SCTE has, all the speed, yet turns on a dime. I have some learning to do that's for sure, but I am amazed with this buggy. Also, the durability was tested on accident as I went down our straight wide open and about 3/4 the way down, the front lifted, which caused it to cartwheel the rest of the way. I thought for sure I broke it but all was fine. Kudos!
J.Pietsch is offline
