Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
#886
I run the Futaba BLS451 servo in my B44's Lamar, I you know I get around just fine.
#888
#889
Hey Guys,
We post the measurements for all of our ProTek R/C batteries and our 45C 5200mAh saddle packs are only 25mm in height. They should easily fit into the Durango.
http://www.amainhobbies.com/product_...hROAR-Approved
JT
AMainHobbies.com
JT
AMainHobbies.com
#891
any of you guys running the sxx tc in your durango?
#892
Not as standard. But it will fit the the 410R maybe just buying the part from the R to modifie. If you want own making get idea from post#92
http://www.oople.com/forums/showthread.php?t=31939
A lot of picture with electronic inside you can see the batteries used
It doesn t seems to have a standard coming out. A lot of people drilled them to different size.
As anyone tested the ghea pistons?
http://www.ghea.se/Various1.htm
#895
#896
410R ($350) vs 410 PRO ($650)
can someone tell me the difference.. what am i getting extra for $300?
Thinking of getting one for a club race...
#898
thats what i thought.. just looked at the durango website.. doesnt look worth it... and dont think it would make a big difference for a club car.
only thing i might consider is the swaybars.
what esc/motor combo are most guys using? im looking at the tekin rs pro.
#900
Hello,
I just recently built my 410R, and plan to run on a pretty tight and technical track which really doesn't require alot of power. That being said, I am opting to use a 9.5T. I am curious where would be a good starting point in terms of a pinion?
