Like Tree22Likes
Old 01-01-2012, 07:50 PM
  #8911
the tekin motors are really good.they are comparable to the trinity/epic duo3 series and have alot more rpm then the new reedy sonic series do. a 6.5 should be a good choice depending on track size.the tekin also is pretty easy to setup.
Originally Posted by D-A-N-4-4
Tekin it is then. I'll just run it with the stock profile until I have enough to get the hot-wire. How are the tekin motors? I'm going to be using a 6.5
cm.stites is offline
Old 01-01-2012, 07:51 PM
  #8912
Briguy's Avatar
Trader Rating: 125 (100%+)
IMO 6.5 is to much unless your on a huge track . I prefer Trinity D3 motors .
Briguy is offline
Old 01-01-2012, 09:00 PM
  #8913
rcfiend's Avatar
Trader Rating: 42 (100%+)
Hey guys I'm going to be purchasing a 4x4 buggy pretty soon and I have a couple of questions.
1. For racing do you recommend purchasing the V3 or the 410R and why?
2. Are the wheels for the 410 interchangeable with the 210?
rcfiend is offline
Old 01-01-2012, 09:08 PM
  #8914
Briguy's Avatar
V3 , Because it has a few updates and the aluminum suspension mounts that are needed . The V3 and 210 share the same rear 14mm hex wheels .
Briguy is offline
Old 01-01-2012, 09:11 PM
  #8915
rcfiend's Avatar
Thanks Briguy! One other question. Is there anything else I need to buy, hop ups, or is it ready to go out of the box?
rcfiend is offline
Old 01-01-2012, 09:12 PM
  #8916
Briguy's Avatar
I would get the aluminum rear diff supports .
Briguy is offline
Old 01-01-2012, 09:14 PM
  #8917
rcfiend's Avatar
Ok, Thx.
rcfiend is offline
Old 01-02-2012, 08:07 AM
  #8918
tobamiester's Avatar
Trader Rating: 360 (100%+)
Originally Posted by rcfiend
Ok, Thx.
Just my experience, but I ran plastic suspension mounts for one year without any breakages.
I put the aluminum ones on and broke the Rear Bulkhead AND the new suspension mounts on the first race.
I would say it depends on what size track you run on, and the height of the jumps. I only run my buggy on a small indoor clay track and have not had any issues with the plastic ones but the breakages I did incur where on the same track (maybe my bulkhead was fractured before I added the Aluminum ones, or maybe the changes stressed the bulkhead...I dunno). Went back to plastic ones as I just wasted $40.
So my humble opinion would be get the Alum servo saver, Diff hoops , Brass Chassis weight/protector first...
tobamiester is offline
Old 01-02-2012, 01:36 PM
  #8919
MantisWorx's Avatar
Trader Rating: 28 (97%+)
there has been some interest in these bodies for the DEX210. it looks like i am going to import some to the US for the 210! if you 410 guys are interested i can bring some of those in too, i think they look really good. if you are interested PM me please. I am not subscribed to this thread
http://bugleboyracing.com/index.php?productid=1
MantisWorx is offline
Old 01-02-2012, 02:29 PM
  #8920
would definetly give us a bigger selection to choose from and his undertrays would be nice also.
Old 01-02-2012, 02:30 PM
  #8921
Qwkrn U's Avatar
Trader Rating: 133 (100%+)
wish you would have posted this a few days ago. I just ordered 2 of the 410 bodies.
Qwkrn U is offline
Old 01-02-2012, 03:52 PM
  #8922
Anyone know the part numbers for the AE ball studs and rpm rod ends? Cant even set camber without the rods popping off this new kit and i tryed the grease trick with the steel turnbuckles but still doing it which is very frustrating for a brand new kit.
Old 01-02-2012, 04:08 PM
  #8923
Qwkrn U's Avatar
This will give you enough to do 1 car and have spares, this is what I did.
Long shank RPM cups
73392 black qty 2
8mm and 10mm TC5 ball studs
31285 10mm qty 2
31284 8mm qty 2
You can also just replace the cups with the Losi ball cups and retain the stock studs.
LOSA6016
Qwkrn U is offline
Old 01-02-2012, 04:15 PM
  #8924
thanks Wayne, trying to get this car done to run at smac next time im visiting family down there.
So the losi ball cups fit the stock camber links and stock ball studs?
Old 01-02-2012, 04:21 PM
  #8925
Qwkrn U's Avatar
yes My Desc410R has Losi ball cups. Just make sure they are actual losi cups as the RPM ones fit too tight on the stock ball studs. Thats why I went with the associated stuff on the 210 and 410 buggys. Just easier to find ball cups. Studs can be hard to find as they are metric thread. Standard assoc stuff is not metric so make sure to get the tc5 stuff I listed the part numbers for.
Qwkrn U is offline
