Like Tree22Likes
Old 12-28-2011, 05:24 AM
  #8836
TeamJammin!'s Avatar
Anyone out there using a castle MMP? Between the MMP and the spektrum reciever, having a tough time getting things to fit.
TeamJammin! is offline
Old 12-28-2011, 06:39 AM
  #8837
Trader Rating: 94 (100%+)
Originally Posted by Mike Marshall
POS is pretty harsh. I have had several Tekin motors that I never had any problems with. The Shoe has been dominating Stock at Smac with the same Tekin motor for 3 seasons now. Sounds to me like you were over/under gearing the motors or something, it could be several factors. Tekin easily has the best customer service of the speedo/motor companies, so any issues you had I am sure could have been worked out. I am not arguing what is the best, because that is all personal preference, but to call a company like Tekin junk or POS is ridiculous.
i AGREE some ofn the fastest motors ive had were tekin. and are still running
redracerd is offline
Old 12-28-2011, 07:14 AM
  #8838
tobamiester's Avatar
Trader Rating: 360 (100%+)
Originally Posted by D-A-N-4-4
S what are the best motor brands to choose from. I'm thinking the tekin rs pro for esc but not sure which 6.5 motor brand as there seems to be mixed thoughts on the tekin. Has anyone used viper? I heard they were good.
Run a Viper VST 7.5 in my DEX410r and no complaints. Ran a 10.5 VST before and again perfect motor. Runs cool, plenty of power, good quality manufacturing.
As with everything in this hobby, YMMV, based on use and experience.
tobamiester is offline
Old 12-28-2011, 08:38 AM
  #8839
Trader Rating: 25 (100%+)
Ok I'm gonna go with the viper vtx10r and 6.5. As theres a few guys who have them at the track, they have a good reputation, they are a little cheaper than tekin, they're waterproof, and they have a year warranty.
So I'm thinking 20t pinion and stock spur to start off with? I run on a smallish medium carpet track that's pretty technical. I went with the 6.5 because there isnt much run up to the jump so I want to be able to blip the throttle and be able to clear them. I may have to tone the motor down with the program or on my spectrum but I want the power to be there.
Thanks,
Dan
D-A-N-4-4 is offline
Old 12-28-2011, 08:41 AM
  #8840
t8rtot's Avatar
Trader Rating: 14 (94%+)
+1 i run viper and have no complaints. nice power, especially torque. perfect indoors.
im not going to say there aren't better products, but i don't think you can really go wrong with any of the top sensored motors available.
some run hot, others cooler. it doesn't hinder performance. i've heard the LRPs are as smooth as they come.
t8rtot is offline
Old 12-28-2011, 08:45 AM
  #8841
Thanks,
Dan
Yeah you'll be fine with that. I run a 20T on my 7.5 and its PLENTY of power
Old 12-28-2011, 08:53 AM
  #8842
t8rtot's Avatar
Thanks,
Dan
10.5 sounds like it would've been the ticket. there are a few guys that went with that way of thinking (bigger is better, so the power will be there) not that its wrong but its just too ballistic, there is still way too much wheel spinning even with them turned down. the 10.5 has almost no spin and more than enough torque to take doubles with only 3ft run ups. while you'll have stay in the lower range of the power spectrum of that motor, the 10.5 will be in its sweet spot 90% of the track.
maybe something you try later down the line. you might suprise yourself when you look at the time sheet
t8rtot is offline
Old 12-28-2011, 08:56 AM
  #8843
yeah I liked the VST 10.5 in mine but needed just a little more to catch the faster guys (shame my driving isn't good enough to hang with them once I caught up to them with the 7.5). With our new slower local track layout I'm thinking of going back to a 10.5.
Old 12-28-2011, 09:27 AM
  #8844
Alright well I'll try the 6.5 first and if it's to much after I turn it down I'll try a larger turn. It's almost impossible to spin out at our track so I won't be loosing the power to the ground with a higher powered motor. The way I drive is being light on the trigger and then blip the throttle before jumps so I think the power will help me.
Thank you guys a lot! Your like my own personal consultants, very fast responses thanks!
Old 12-28-2011, 09:35 AM
  #8845
only brushless systems or motors ive ever had issues with were novaks. never had a single issue with my hobbywing,speed passion or my tekins. and out of them all i like my tekins the best.
cm.stites is offline
Old 12-28-2011, 11:42 AM
  #8846
onekiwi's Avatar
How do I calm the rear down, it wants to kicks out/swaps ends especially on the 90 turns. Im on carpet
Front
40wt 1.3*2 dark blue/dark red
middle tower outer arm
1.3mm sway bar
7000
Rear
35wt 1.2*3 light blue/light green
middle tower middle arm
+2/-2
5000
19mm ride height
full droop
onekiwi is offline
Old 12-28-2011, 12:26 PM
  #8847
t8rtot's Avatar
any big jumps?
i would go down a mm or 2 in rear ride height. you'd be suprised.
t8rtot is offline
Old 12-28-2011, 12:31 PM
  #8848
Maybe 30wt or 32.5 in the rear shocks? I heard lowering the oil wt. Calms it down
Old 12-28-2011, 12:39 PM
  #8849
Konich's Avatar
I'd go 35w in the front and 30w in the rear with the big bores.
Konich is offline
Old 12-28-2011, 01:44 PM
  #8850
onekiwi's Avatar
no big jumps and on the original bores, it is slapping a fair bit
onekiwi is offline
