Like Tree22Likes
Old 07-21-2010, 08:59 AM
  #871
mackyrocks's Avatar
Originally Posted by annonymous
yes, it fits quite well - - - i fit it, a futaba rx, and a MRT PT in mine just fine
would you like to buy one? i have one with the worlds kit
I already have one
mackyrocks is offline
Old 07-21-2010, 09:18 AM
  #872
Jmuck69's Avatar
Trader Rating: 14 (100%+)
This is slightly off topic, but refers to the Lipos. Im new to lipos and getting back into RC. Im looking at Team Orion carbon molecular 45C 5400 mah packs. Does the 5400 mah refer to capacity (run time)? bigger number=longer run time?
Jmuck69 is offline
Old 07-21-2010, 09:26 AM
  #873
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
Yes and yes.
t0p_sh0tta is offline
Old 07-21-2010, 09:28 AM
  #874
Jmuck69's Avatar
Originally Posted by t0p_sh0tta
Yes and yes.
got it! thanks.
Jmuck69 is offline
Old 07-21-2010, 09:38 AM
  #875
t0p_sh0tta's Avatar
The C relates to the amount of current that the pack can deliver over a period of time. For all intents and purposes, a higher C value is better than a lower, however there is no standardized process for measuring C values.
I haven't run Orion packs yet, but I run 40C Pro-Tek packs. I definitely have more oomph than the guys running 25-30C lipos at my local track (stock class).
Old 07-21-2010, 09:45 AM
  #876
Jmuck69's Avatar
I was actually looking to get either the Pro-Tek 40C or the Orion packs. RCMart in HK has the 4600 mah 45C Team Orion packs for $65.90 a pack vs. the 5000 mah 40C Pro-Tek packs from Amain for $79.99. My local track only runs 13.5 super stock.
Jmuck69 is offline
Old 07-21-2010, 09:57 AM
  #877
Xchange's Avatar
Trader Rating: 10 (92%+)
you need to be careful with the 5000mha 45C Molecular they are bigger and dont fit on the durango
Xchange is offline
Old 07-21-2010, 09:58 AM
  #878
bigBoyBigToy's Avatar
Trader Rating: 23 (100%+)
just remeber the orion only makes to lipo saddles that are 25mm and under the other 2 that are bigger mah and c rating are alot taller that cant be used in this car
bigBoyBigToy is offline
Old 07-21-2010, 10:01 AM
  #879
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Ya, I believe the 5400 is to big. I looked into this as well........
Bman's 3XNT is offline
Old 07-21-2010, 10:52 AM
  #880
t0p_sh0tta's Avatar
I believe the 4600 has a height of 25mm, so it should work fine. For what it's worth, anything over 4000mah should be more than enough, even for 8min mains.
Old 07-21-2010, 11:03 AM
  #881
Xchange's Avatar
my orion 4500 touch a maybe 2mm the slipper nut and the rear cvd.
but once it's used a bit, there is ok and do not wear much more.
Please note, i have a DEX410 2009 with old motormount and old slipper mount.
I used double side tape to fix the lipo on the chassis and removed the plastic lipo retainer.
Xchange is offline
Old 07-21-2010, 09:22 PM
  #882
t0p_sh0tta's Avatar
What kind of servos are you guys running? I have a spare Futaba BLS451 (.1sec and 147oz), and I wanted to know if this will be enough.
If not, I've been itching to try one of the Savox offerings.
Old 07-22-2010, 01:03 AM
  #883
mdowney's Avatar
Trader Rating: 21 (100%+)
That's the same one I'm running. Works really well for me though I am tempted to step up to the BLS352 for some more torque.
What's this Savox that you're referring to?
mdowney is offline
Old 07-22-2010, 01:23 AM
  #884
MaTt 93's Avatar
I had alot of trouble getting my SMC 4900 to fit in my dex410r. I had to shim the motor mount up to make it fit
MaTt 93 is offline
Old 07-22-2010, 05:52 AM
  #885
t0p_sh0tta's Avatar
Savox SC1258TG, 167oz/in, .08 sec. and $60. They're pretty popular with the european guys and I've seen nothing but positive reviews. The only complaint that I've found is that they're loud.
