Like Tree22Likes
Old 12-21-2011, 08:30 AM
  #8776
TeamJammin!'s Avatar
I can see my new Durango DEX410v3 sitting under the x-mas tree. So close, yet cant event touch it yet..
TeamJammin! is offline
Old 12-21-2011, 08:37 AM
  #8777
t8rtot's Avatar
Trader Rating: 14 (94%+)
are you guys still whining?
yes parts aren't plentiful right now, we know. Durango has come on here and apologized.
ok we get it. if its a problem, run another brand.
you guys get on here and whine like 5yr olds everyday. doesn't it get old...
on a lighter note, the guy isn't spending $300/wk, maybe total, but there's no way someone could need that many parts, i've only spent about $100 in parts and i have enough to rebuild/maintain my car at least 3x's
on an even lighter note, has anyone tried the new D-Joints??
t8rtot is offline
Old 12-21-2011, 08:57 AM
  #8778
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
By any chance you have big bore shock caps hanging around? I have every other fffffing part......except those. Please let me know. Thanks!
Bman's 3XNT is offline
Old 12-21-2011, 08:58 AM
  #8779
ABBOTT's Avatar
d Joint, that sounds like something worth reading about
ABBOTT is offline
Old 12-21-2011, 09:24 AM
  #8780
Trader Rating: 31 (100%+)
Default Anyone figured out how to make SC10 hex wheels fit?
I dont want to have to double up on anymore tires and wheels!! Any ideas?
Dont tell me to not run associated! lol
I would run 2wd Durango if they had one
cota4rt is offline
Old 12-21-2011, 09:31 AM
  #8781
tobamiester's Avatar
Trader Rating: 360 (100%+)
I am 99% sure my LHS has them. I'm going there late today. PM me if you want a set.
tobamiester is offline
Old 12-21-2011, 09:37 AM
  #8782
I've only ran the D-Joints, so I can't compare it before and after. I bought the car used and the center shafts needed to be replaced.
They feel nice and smooth by hand, although they may be a bit heavier over the originals. I don't have a scale to verify that...
HeatSink5 is offline
Old 12-21-2011, 09:45 AM
  #8783
Pm sent, thanks
Old 12-21-2011, 10:37 AM
  #8784
dex210? i think the sc10 hexes could be made to work using the cone spacers and pins from a ntc3 that may need trimmed down.
cm.stites is offline
Old 12-21-2011, 10:45 AM
  #8785
oops I meant to post this in the desc thread
I will look into that thanks
cota4rt is offline
Old 12-21-2011, 11:22 AM
  #8786
Trader Rating: 16 (100%+)
Talking
He said $300 a WEEK. You should have seen his stock. He could not find what he needed in the box he had with him at his pit table, so he went out to his car and retrieved ANOTHER box FULL of parts (A 24x18x18 box). It may be a case where a few guys are buying up all the spare parts! HA.
No whining intended, just sharing my story.
zipperfoot is offline
Old 12-21-2011, 11:24 AM
  #8787
Konich's Avatar
He must be the worst driver in RC history. I've spent about $50 on my 2009 spec that I've been racing for 3 years!
Konich is offline
Old 12-21-2011, 01:58 PM
  #8788
1shnot's Avatar
little help please... am I going crazy or with alum blocks, and TD330033(alum pivot ball) my hinge pin wont fit... seems TD33033 hole is too small? do I need a different hinge pins?
1shnot is offline
Old 12-21-2011, 01:59 PM
  #8789
onekiwi's Avatar
+1 I heard that it will help the drive shaft from getting hot, I have noticed that mine get hot but not sure if i need a shorter drive shaft as well or if the djoint will fit the early 410 with out mods
onekiwi is offline
Old 12-21-2011, 02:15 PM
  #8790
Trader Rating: 44 (100%+)
i thought the length of the centre drive shafts hasn't changed from the original dex410? i'm hoping to pick up a djoint for my v1 car so here's hoping it's a direct swop
as for stocking up on spares .. just buy another kit and use it for spares. that's what i've done
but chances are .. i'll find that it's just a handful of parts that break often. 70% of the spare kit will be untouched but you never know ...
zipperfoot - if it's any consolation, i've broken a front arm & bent hingepin at the same time
wyl03 is offline
