Like Tree22Likes
Old 12-20-2011, 04:10 AM
  #8761
onekiwi's Avatar
Im on a tight carpet track and have a 6.5, I think a 8.5 would work fine, I also have a 8.5 in my 210 and thats really fast too
Get a 6.5 or even a 5.5 and turn down the gas on your radio.. that way when you go outside on larger tracks in the summer you won't need to buy a quicker motor
onekiwi is offline
Old 12-20-2011, 04:19 AM
  #8762
Joel Lagace's Avatar
My carpet track is very small and we have guys running 10.5 to 6.5 I ran a non boosted low timing 7.5 and felt it was too much. Also ran a well boosted 13.5 with good luck.
So hard to suggest a motor.best to talk to your local fast Guy at your track for a startting wind. I think your on the right track though with the two motors your looking at
Joel Lagace is offline
Old 12-20-2011, 04:33 AM
  #8763
spiro's Avatar
Alright, thanks guys!
spiro is offline
Old 12-20-2011, 12:55 PM
  #8764
Mopar's Avatar
What gear lube is recomended to tone down the car. It was bought used w/ very little run time. Previous owner wrote nothing down and doesn't remember what he used. Not sure that I'd trust his memory any way as I found many inconsistancies in his build of the car. As in some things thread locked and some not, shims on suspension differant from one side to the other, as well as other things. Using Carson's set-up for West Coast as starting point, runs ok but the rear is loose, but that could be tire choice. Will try some new mounted next time.
Mopar is offline
Old 12-20-2011, 01:26 PM
  #8765
I used moly grease in the gearbox cases, keeps the noise down. As for the diffs, depends what surface you are running on.
Chris-s is offline
Old 12-20-2011, 02:56 PM
  #8766
Mopar's Avatar
Medium - high bite clay, wet and swept.
Mopar is offline
Old 12-20-2011, 06:17 PM
  #8767
if anyones running sway bars what sizes are you using? seems most of the setups run no sway bars.
cm.stites is offline
Old 12-20-2011, 06:26 PM
  #8768
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
I run both front and rear, 1.3mm. I was able to run lighter springs and oil with them.
Bman's 3XNT is offline
Old 12-20-2011, 07:01 PM
  #8769
DBL15's Avatar
sway bars front and rear for me too , it feels nice and planted in turns and not to stiff with the V3 stock sway bars on there
DBL15 is offline
Old 12-20-2011, 07:07 PM
  #8770
Thanks may end up ordering when i can find em in stock.
Old 12-20-2011, 07:28 PM
  #8771
does anyone know what thread size the sway bar turnbuckles are? i know they are 28mm but not sure what size thread.
Old 12-20-2011, 08:35 PM
  #8772
Shark413's Avatar
Trader Rating: 24 (100%+)
They are 3mm (M3). I used these rather than the Durango Ti turnbuckles, about half the price and very light (aluminum).
http://www.amainhobbies.com/product_...inum-Tie-Rod-2
Shark413 is offline
Old 12-20-2011, 09:22 PM
  #8773
Trader Rating: 16 (100%+)
Thumbs up
Funny story. I was racing at Compitition Hobbies in Tucson, AZ over the weekend. We were told racing started at 2:00pm. Got there at 12:30pm and racing was well under way. No practice, new track, our race was next. I hit a pipe and broke a front arm. Guy next to me who is a B44 guy says, " you broke a Durango?". Durango apparently has a rep for being durable.
Unfortunately they also have a rep for lack of parts. The shop did not have a hinge pin to replace the one I bent. Luckily there was a guy racing a 410 who had boxes of parts. I mean packages of hinge pins front and rear and everything else you could imagine. Without him I would have been done after one race.
Am I missing something? Do I have to be my own hobby shop? The guy told me he and a buddy were spending $300 a week on parts to stock up. A car a week?
You Durango guys are a dedicated bunch.
zipperfoot is offline
Old 12-21-2011, 07:33 AM
  #8774
300$ a week might be a little excessive but i have to be honest, i have a ton of parts for mine. At least another kits worth. Not because it breaks often but because when it does the LHS never had them.
Culetto is offline
Old 12-21-2011, 08:20 AM
  #8775
GasserX's Avatar
Why isn't Durango making the parts we need? This is unreal to have to wait to race because you can’t get the parts you need. Worse yet......buy a whole kit to have spares.......
I am thinking about going to a brand my local hobby shop carries. I trusted I could order parts online, but a worldwide shortage (for a long time) is just lame.
GasserX is offline
