Like Tree22Likes
Old 12-16-2011, 08:47 AM
  #8686
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Originally Posted by Jonny5
Cush has been running it since February or so. He was immediately faster by about a half second with the same suspension settings. The chassis itself is about half the weight of the original (128g vs. 64g) so there's the obvious benefits of being lighter, but the car also looks more planted going through corners. You do need to run the aluminum side pods with it to prevent excessive chassis flex.
How do you know there is to much flex? Are driveshafts popping out, or stripping gears? Just wondering, Thanks........
Bman's 3XNT is offline
Old 12-16-2011, 08:58 AM
  #8687
Konich's Avatar
When Tresrey Japan first tested the chassis without the aluminum side pods the chassis had to much flex and didn't give the proper handling characteristics the team drivers were looking for. The aluminum sides add the stiffness to the chassis but still allow a bit of flex which has proved to be a benefit on a lot of track conditions. Also too much flex could adversely affect the carbon layers and separate.
You still have the option of running either the plastic or carbon rear brace as well to change the flex characteristics.
Konich is offline
Old 12-16-2011, 09:15 AM
  #8688
1shnot's Avatar
Originally Posted by Chris-s
5k front, 2k rear.
Thanx will try that
Has anyone used orings from other then kyosho p5?(for diff) for some reason it's really hard to get a hold of kyosho parts here..may be hpi? or other companies?
1shnot is offline
Old 12-16-2011, 09:18 AM
  #8689
Konich's Avatar
My personal favorite
http://www.tresrey-usa.com/products/...7D8pcs%29.html
There are a number of Canadian dealers that can get you taken care of
Konich is offline
Old 12-16-2011, 10:29 AM
  #8690
1shnot's Avatar
that's even harder brand...lol
just received my 410 and would love to build it sooner then later for this weekend track time,that's why I am looking for what is available locally.
1shnot is offline
Old 12-16-2011, 10:32 AM
  #8691
Konich's Avatar
DNX408 shock seals will work as well.
Konich is offline
Old 12-16-2011, 10:48 AM
  #8692
Default dex410 2010 spec
I have a barely used dex410 2010 spec for sale as a roller with a couple sets of wheels and tires, Tresery diff holders , big bores, and everything that came with the kit. ran 3 batteries through it. $425.00 shipped. If anyone has any interest shoot me a pm . It will be listed in the for sale thread sometime this weekend. I havent taken pics yet but will this weekend as well.
CTEKTOOL is offline
Old 12-16-2011, 11:00 AM
  #8693
1shnot's Avatar
I appreciate your suggestion, but at the momment, I cannot get a hold of kyosho or Durango parts... locally it's HPI,AE,LOSI,XRAY that's what is available
1shnot is offline
Old 12-16-2011, 11:45 AM
  #8694
Ive used the losi ones before in a pinch. They werent bad at all and leaks were minimal. I rebuild mine pretty often so i couldnt tell you how long they would last but they worked.
Culetto is offline
Old 12-16-2011, 07:04 PM
  #8695
Trader Rating: 96 (100%+)
A bit stumped with this one, but before anyone asks, yes the wires are soldered on correctly. I found the ambition to fit the electronics into my 410 and with everything hooked up, the car only runs in reverse. I"ve changed the settings on my radio, programmed the esc, but nothing. Do I have to switch the a/b/c wires to get this thing to run in the right direction?
K.Copeland is offline
Old 12-16-2011, 07:08 PM
  #8696
Briguy's Avatar
Trader Rating: 125 (100%+)
Sounds like you have the diff assemblies in wrong . The screw heads should be facing the chassis .
Briguy is offline
Old 12-16-2011, 07:12 PM
  #8697
lol yes, that's the problem. Thanks for the quick reply.
I traded a b4.1 for this Durango, and the car was already built.
Old 12-16-2011, 07:13 PM
  #8698
Briguy's Avatar
It is a common mistake .
Briguy is offline
Old 12-16-2011, 07:28 PM
  #8699
tobamiester's Avatar
Trader Rating: 360 (100%+)
The most fun can be had when you put just one of the diffs in upside down, then drop it on the track and realized the front axles spin one way, and the rear in the opposite...you only make that mistake once
tobamiester is offline
Old 12-17-2011, 12:34 AM
  #8700
1shnot's Avatar
Finally got all the peices to put the car together.... and guess with much excitement I have goofed up big time!!
I have mixed up the cvd's front to rear etc etc.. and with awesome red lock tight, I cannot get the little grab screw from the cvd pin holder.. am I SOL or is there someone here have this experience and have a tip?
or should I just order other set of cvd's... was looking forward to get some track time this weekend. lesson learned
1shnot is offline
