Like Tree22Likes
Old 12-07-2011, 01:31 PM
  #8551
DBL15's Avatar
Originally Posted by dusty sweep
Does this mean Venom have some in stock?
thats why i gave you the info mate yes they have them in stock
DBL15 is offline
Old 12-07-2011, 02:41 PM
  #8552
1shnot's Avatar
which alum servo saver do you guys use? trey,racers edge etc etc?
when I see them on line.. they all look little diffrent
1shnot is offline
Old 12-07-2011, 02:53 PM
  #8553
Chief's Avatar
Trader Rating: 14 (100%+)
Originally Posted by tobamiester
You look pretty local. Call Critters in NJ. He's getting some in stock this week I believe.
I called my LHS and the V3's are shipping now!
Chief is offline
Old 12-07-2011, 03:15 PM
  #8554
does anyone know if the v3 can be converted to run b4/b44 style wheels?
cm.stites is offline
Old 12-07-2011, 04:57 PM
  #8555
Konich's Avatar
Yes you can use the old hex on the front and spacer/cone/pin on the rear and you can run AE/Losi Or older Durango wheels no problem
Konich is offline
Old 12-07-2011, 05:30 PM
  #8556
Chief's Avatar
Default V3 build
Before I start my 410v3 build I would like to be sure I up grade the weak points. I have the Tresrey servo saver so what's next? Would it be better to get the Tresrey rear diff hoop or the aluminum front/inner suspension holder? Am I missing anything? Thanks for the help.
Chief is offline
Old 12-07-2011, 05:39 PM
  #8557
BLKNOTCH's Avatar
Good question I to am very interested in this info
BLKNOTCH is offline
Old 12-07-2011, 05:52 PM
  #8558
Ty!!! that will definetly save me some $$$$ in the long run.
Old 12-07-2011, 06:56 PM
  #8559
Trader Rating: 29 (100%+)
Is there a better option for the Pivot ball studs, Pivot balls, and Ball ends. I keep getting slop with these stock Durango parts. There has to be something that fits tighter and lasts longer, like AE, Losi something. This is the only thing that I hate about this car. If I can get this sorted it will be perfect.
Walkman is offline
Old 12-07-2011, 10:10 PM
  #8560
Trader Rating: 16 (100%+)
I have heard the diff hoops are a worthy upgrade. I have not heard of anyone having a problem with the inner suspension holder. Outside yes, inside no.
The v3 has addressed many of the weak points. The one problem I have encountered on the 410r but have not heard a lot about are the bearings. Cheap bearings on the 410r. Hope they upgraded the v3.
zipperfoot is offline
Old 12-08-2011, 06:11 AM
  #8561
dangerwr's Avatar
Hmmm, Mine has a little slop too and appear to be the only one at my track that does not have trouble with the ball cups popping off. They are not easily removed but just some play . . .
dangerwr is offline
Old 12-08-2011, 07:06 AM
  #8562
TeamJammin!'s Avatar
I had posted a question regarding the castle MMP esc 1/10th.
Wanted to be sure that it would fit in the DEX410v3. Anyone know for sure that it will fit?
TeamJammin! is offline
Old 12-08-2011, 07:50 AM
  #8563
tobamiester's Avatar
Trader Rating: 360 (100%+)
I think it would be REALLY tight. I did see pictures way back early this year of someone who managed it, but its super tight in the 410/R and the chassis layout is the same in the v3. You'd need a micro receiver for sure.
tobamiester is offline
Old 12-08-2011, 08:00 AM
  #8564
Had a spectacular failure of parts on my buggy last night. Normal day at the track, no crash, just running in 1st qualifier, whole rear bulkhead broke included aluminum suspension holders.
I had run plastic suspension holders for 1 year without issue, decided to add the aluminum ones. I don't know if it the stress that the aluminum put on the plastic (not allowing it to flex as much as before), or temperature (it was a colder evening but not freezing).
Crappy picture below showing entire bulkhead severed from car. That was a fun rebuild between qualifiers
Old 12-08-2011, 08:36 AM
  #8565
Konich's Avatar
Get the aluminum suspension holders as the upgrade. The plastic suspension holders are a known problem that almost everyone as broke. The diff hoops are a nice upgrade to keep the driveline in-line but not necessary.
Konich is offline
