Like Tree22Likes
Old 12-06-2011, 10:49 AM
  #8536
TeamJammin!'s Avatar
Just got off the phone with amain, was asking about the motor as well. GUess another important question is, I will be taking my mamba max pro out of the b4. Im am hoping that will fit in the durango. Anyone out there using MMP in the dex410v3?
TeamJammin! is offline
Old 12-06-2011, 02:11 PM
  #8537
DBL15's Avatar
does any one have a quick link to Randy Pike setup for these buggys
i know i have seen it on here but i cant find it now
any link would be great please
DBL15 is offline
Old 12-06-2011, 03:14 PM
  #8538
Default who has kits in stock
Anyone know of a rc store/website that has a dex410r V3 or dex410 V3. in stock.
Everyone seems to be out of stock.
dusty sweep is offline
Old 12-06-2011, 03:17 PM
  #8539
Briguy's Avatar
Trader Rating: 125 (100%+)
That is because they are back ordered .
Briguy is offline
Old 12-06-2011, 03:34 PM
  #8540
Trader Rating: 96 (100%+)
Anyone have access to the Losi equivalent of Durango #330037 ( suspension pivot ball ) ? The XXX4 uses something very similar, only its plastic. I'm wondering if it would fit.
K.Copeland is offline
Old 12-06-2011, 03:44 PM
  #8541
DBL15's Avatar
in stock as i got mine yesterday mate $379
Manuel Correia
Venom Group International
Ph: +61 2 9698 2166
Fax: +61 2 9698 2199
Email: [email protected]
http://www.facebook.com/venomracingaustralia
DBL15 is offline
Old 12-06-2011, 06:20 PM
  #8542
tobamiester's Avatar
Trader Rating: 360 (100%+)
My LHS told me they got a call today that the v3's are shipping!
tobamiester is offline
Old 12-06-2011, 06:27 PM
  #8543
1shnot's Avatar
hopefully that means parts too...
1shnot is offline
  #8544
DBL15's Avatar
wow finally Australia got them before the USA 1st time for everything as mine is all ready 1/2 together and i got it yesterday and shipped on monday
DBL15 is offline
Old 12-06-2011, 08:36 PM
  #8545
A mate wants one desperately.
Old 12-06-2011, 08:39 PM
  #8546
Manuel Correia
Ph: +61 2 9698 2166
Does this mean Venom have some in stock?
Old 12-06-2011, 08:47 PM
  #8547
Trader Rating: 19 (100%+)
Originally Posted by HeatSink5
I took the motor plate and rear center mount out of the car and loosened to spacer that connects them. I then installed the spur assembly and gear guard with the wire clip and it was still binding. When it's spun it feels like it is cogging, binding in one spot. Maybe the slipper clutch shaft is out of round? I'll check the motor plate and shaft tonight after work...
I raced the 410 for the first time this weekend (and my 210!) and my first time in the dirt! Both cars were solid and easy to drive with no broken parts!
On another note, is anyone else running spacers on the front lower shock mounts on the arms to get the springs away from the front driveshafts? I added a 2mm spacer as the springs were almost touching the front dogbones... Is this an issue with running big bores?
It's not an issue if you use spacers on the lower mount But yes if you are running big bores you need 2mm spacers to allow room between the bottom of the spring and the dogbone.
Are your slipper pads seated fully into the spur gear? I have seen the hub bend before, but a gnarly crash coming up short on a huge triple flexed the chassis enough to do it. No other issues though.
Jonny5 is offline
Old 12-07-2011, 07:06 AM
  #8548
JOJOHAMBONE's Avatar
Trader Rating: 31 (100%+)
Default new bodys
just got some new bodys from rob majors at 521 designs (desc410r dex410r)
great job rob!
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-dsc02947.jpg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-dsc02946.jpg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-dsc02945.jpg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-dsc02944.jpg
JOJOHAMBONE is offline
Old 12-07-2011, 07:37 AM
  #8549
At least some people are getting theirs. Here in the U.S, they are backordered. AMAIN stated ETA December 29th. No X-Mas present I guess.....
Old 12-07-2011, 12:09 PM
  #8550
You look pretty local. Call Critters in NJ. He's getting some in stock this week I believe.
