Like Tree22Likes
Old 11-30-2011, 10:39 PM
  #8416
Trader Rating: 19 (100%+)
Originally Posted by ABBOTT
Fixed it so they could see the rear mount not cut out. Yeah it looks even better from the front doesnt it!
Body looks great! It really allows a lot more room around the electronics- been loving it on Cush's ride. I trimmed/sanded the mount off of the front bulkhead brace so I didn't have to poke the front body hole either.
Jonny5 is offline
Old 11-30-2011, 10:53 PM
  #8417
Qwkrn U's Avatar
Trader Rating: 133 (100%+)
I've only seen the car if I look back while racing lately. once you get that esc brown out issue resolved it could be a different story.
Qwkrn U is offline
Old 11-30-2011, 11:11 PM
  #8418
ABBOTT's Avatar
Well I had to say something funny, and I think I have it fixed. I shall see thursday night. Got a couple new pack in this week and Im glueing up some new pistons now. Im really wanting to find something that works with the green spring setup I was useing.
See ya att practice.
ABBOTT is offline
Old 11-30-2011, 11:15 PM
  #8419
ABBOTT's Avatar
@Johny 5- Are you and Cush going to make the trip down to STL for the JConcepts Winter Nationals In Feb4-6? Met several people from up there last year hoping they make the trip down again.
ABBOTT is offline
Old 11-30-2011, 11:16 PM
  #8420
dangerwr's Avatar
Originally Posted by zipperfoot
I think he may be breathing too much nitro.
Perhaps this is true and maybe he is good at R/C but is obvious that he sucks at life.
dangerwr is offline
Old 11-30-2011, 11:24 PM
  #8421
I'm tentatively planning on it, but not totally sure yet. I think I bought enough brownie points with the wife to go since I decided to skip CRC. There should be a good group of Leisure Hours guys there too. I know everyone who went had nothing but good things to say last year. Hopefully we can make it happen!
Jonny5 is offline
Old 12-01-2011, 01:17 AM
  #8422
getpip's Avatar
Originally Posted by cota4rt
I have a couple xerun 60 amp and 2 120 amp esc and I tried to get boost ot work on a tacon 17.5 non sensored motor and it doesnt seem to "boost"
If I understand what your saying is that boost will only work when esc is in sensored mode with sensored motor? Thanks
Correct.
This is how the esc 'talks' to the motor.
There are a few HW threads on RC tech you can take a look at if you need more info.
getpip is offline
Old 12-01-2011, 05:27 AM
  #8423
finally finished mine,
ektoz is offline
Old 12-01-2011, 07:32 AM
  #8424
Trader Rating: 31 (100%+)
Originally Posted by dusty sweep
Thanks for the replies guys.
So it looks like I will be going for the xerun 120 esc with the 8.5t motor. http://www.hobbypartz.com/07e-8-5t-3...-120a-lcd.html
Do you know there is enough space in the Drango Dex410 V3 for the http://www.hobbypartz.com/07e-8-5t-3...-120a-lcd.html to fit.
That is the system I am using in one of my dex410s and it is tight but will fit depending on which receiver you have good luck
cota4rt is offline
Old 12-01-2011, 07:47 AM
  #8425
Trader Rating: 125 (100%+)
You'll be fine if you use a micro reciever. I run Speed Passion which is same size as Hobby Wing.
kwiksi is offline
Old 12-01-2011, 07:48 AM
  #8426
TAMAK's Avatar
Trader Rating: 28 (100%+)
The front and rear shock tower you should only need the three lower holes. I dremeled mine down. Looks good!
TAMAK is offline
Old 12-01-2011, 08:59 AM
  #8427
yes i was thinking that thanks
got any pics?
ektoz is offline
Old 12-01-2011, 11:42 AM
  #8428
Has anyone had problems with the spur assembly binding when the spur gear guard is installed? It spins nice and free with the metal clip out, and the bearings seem to be in good shape.
Any thoughts? Thanks
HeatSink5 is offline
Old 12-01-2011, 11:51 AM
  #8429
TAMAK's Avatar
got any pics?
ABBOTT did the same mod in his photos a few posts back?
TAMAK is offline
Old 12-01-2011, 06:27 PM
  #8430
dangerwr's Avatar
My spur is a little "cocked" actually when installed. You can actually see it is meshing the pinion at an angle. I do not think it has anything to do with the gear guard but believe the motor plate is tweaked a bit but have a hard time telling for sure. Let me know if you are able to remedy your situation . . .
dangerwr is offline
