Like Tree22Likes
Old 11-29-2011, 06:37 PM
  #8401
dangerwr's Avatar
Originally Posted by RB FIVE
From what i've seen the 210 looks like a POS ! haha. The CR was never known for it's diff but if you built it correctly without a caged thrust the diff was fine.
You are a sad man to troll forums and post smack. Get a life worm and beat it out of this forum.
dangerwr is offline
Old 11-29-2011, 06:40 PM
  #8402
t8rtot's Avatar
Trader Rating: 14 (94%+)
Your still around?, the threads had been so peaceful, but look what the cat dragged in
t8rtot is offline
Old 11-29-2011, 09:53 PM
  #8403
Trader Rating: 16 (100%+)
Angry
Originally Posted by JJBTEXAS
I have the screws in the rear and have plenty of droop.
Discovered my second faulty bearing on this kit . its the 5x10x4 in the rear bearing carrier. I would upgrade to the bigger bearing carrier from the V3 but can't find the parts. The first one to go was a 10x15x4. Haven't even run a full pack through her yet .
I had the exact same bearing fail in the same area. Luckily a guy at the track had some losi bearings to spare. I ordered all new bearings, ceramic in the problem areas. My buddy is starting to have the same issue with his bearings as well. Cheap ass bearings. I have never had a bearing fail right out of the box.
zipperfoot is offline
Old 11-29-2011, 09:57 PM
  #8404
I think he may be breathing too much nitro.
Old 11-30-2011, 04:49 AM
  #8405
I have just purchased the Durango dex410 V3. Have a few 1/8 brushless buggies etc but this is my first 1/10.
Not sure what motor esc to get. I will only be running this car on a medium outdoor track. Main straights 15-20 meters. running 2s 5ooomah. No serious racing. Just racing mates at the track.
I am looking for a motor/esc that will run cool and last long. Not after a 6.5T. Maybe something like 8.5? (what would you guys recommend)
I have had great success with the hobbywing xerun in my other cars so would like to stick with them.
What combos can you recommend for the Durango dex410 V3. as I have no experience with 1/10.
I have always only run sensorless. Is this ok in 1/10 or should I go sensored. (is sensored more complicated) I am looking for plug and play. The programming is easy.
Which combo would you pick out of these.
Xerun
http://www.hobbypartz.com/hoxeco.html
Ezrun
http://www.hobbypartz.com/hoezco.html
dusty sweep is offline
Old 11-30-2011, 08:51 AM
  #8406
slow_jun's Avatar
Xerun sensored would be fine, so less cogging. Also this motor is only 3650 in size but the outside size is pretty much the same as a 540 can. kV rating is lesser than those of a tekin rs pro(equal to a (10.5) so no problem in over heating, just make sure to gear it correctly.
Cheers.
slow_jun is offline
Old 11-30-2011, 11:16 AM
  #8407
getpip's Avatar
Xerun
Ezrun
I would recommend the xerun sensored. You can then utilise all the latest boost software.
You can get away with the 60a version if you go for an 8.5 motor.
120a would be preferable and indeed necessary if you want to run a lower turn motor.
Pip
getpip is offline
Old 11-30-2011, 11:22 AM
  #8408
Trader Rating: 31 (100%+)
Pip
I have a couple xerun 60 amp and 2 120 amp esc and I tried to get boost ot work on a tacon 17.5 non sensored motor and it doesnt seem to "boost"
If I understand what your saying is that boost will only work when esc is in sensored mode with sensored motor? Thanks
cota4rt is offline
Old 11-30-2011, 12:51 PM
  #8409
TAMAK's Avatar
Trader Rating: 29 (100%+)
Hey guys,
Finished by rear skid weights. I will have 5 of these available this weekend at trackside hobbies for the Spektrum race. Or PM me if you are interested. These weigh in at 33g. Picture is attached.
Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-img_0357.jpg
TAMAK is offline
Old 11-30-2011, 01:21 PM
  #8410
gene1219's Avatar
Originally Posted by TAMAK
Hey guys,
Attachment 841514
Very nice! I just picked up a Durango piece and amazed how much it helped out
gene1219 is offline
Old 11-30-2011, 03:03 PM
  #8411
Thanks for the replies guys.
So it looks like I will be going for the xerun 120 esc with the 8.5t motor. http://www.hobbypartz.com/07e-8-5t-3...-120a-lcd.html
Do you know there is enough space in the Drango Dex410 V3 for the http://www.hobbypartz.com/07e-8-5t-3...-120a-lcd.html to fit.
Old 11-30-2011, 06:17 PM
  #8412
jayfinnRC's Avatar
Trader Rating: 17 (100%+)
Default Battery help
I have 3 different batteries. Protek, Racers edge, and Max amps all with dean's ultra. The max amps has the permanent (or fixed) wires which makes them low enough and flexible enough to fit under this ridiculously tight body. The others use the regular connectors that when plugged into the battery pop up a 1/4" or so before being able to flex them causing issues affixing body? Is the only fix those connectors that go flush into the battery? Are those bullet connectors? Does the gainabull body have the same problem or is it slightly higher in the area of the battery?
THANKS FOR ANY HELP!
jayfinnRC is offline
Old 11-30-2011, 08:00 PM
  #8413
ABBOTT's Avatar
The body does give some extra room(over5/8 in) in that area but I still solder wires on soild bullets at 90*. Up front its has loads of room. Mounted with Velcro and only the front clip and the body has never come off during a race. Cut the rear body mount off above the circle and leave rear of the body uncut to allow for flexing.[IMG][/IMG]http://[/IMG]
ABBOTT is offline
Old 11-30-2011, 08:06 PM
  #8414
Qwkrn U's Avatar
Trader Rating: 133 (100%+)
Originally Posted by ABBOTT
The body does give some extra room in that area but I still solder wires on soild bullets at 90*. Up front its has loads of room. Mounted with Velcro and only the front clip and the body has never come off during a race. Cut the rear body mount off above the circle and leave rear of the body uncut to allow for flexing.[IMG][/IMG][IMG][/IMG]
love that body, just wish it were cheaper.
Qwkrn U is offline
Old 11-30-2011, 08:34 PM
  #8415
ABBOTT's Avatar
Fixed it so they could see the rear mount not cut out. Yeah it looks even better from the front doesnt it!
ABBOTT is offline
