Like Tree22Likes
Old 11-23-2011, 10:42 AM
  #8311
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Originally Posted by dangerwr
Big bores are so smooth! I have not ran them yet but believe the PTFE (?) coating on the shock bodies are a bonus. Also the shock pistons appear to be better quality and perhaps a bit softer plastic. Add in the Nitride shock shafts and there is a marked improvement over the standards. I will see how they work on the buggy tonight . . .
It's going to seem like a different car! You will love it........
Bman's 3XNT is offline
Old 11-23-2011, 10:47 AM
  #8312
dangerwr's Avatar
I suspect you are right! I was looking at the Schumacher Cat and noticed they have even larger bore shocks so it all makes sense to me. I just look for improvements that make the car easier to drive so hope the BB shocks are one of those upgrades . . .
dangerwr is offline
Old 11-23-2011, 12:01 PM
  #8313
jesperolsen1972's Avatar
Hi.
Have anyone made a temporary mod on the V3, so you can use some other brand of front wheel? And if yes, what solution did you come up with?
It sucks that there isnt any wheels to the v3 on the market yet.
jesperolsen1972 is offline
Old 11-23-2011, 12:08 PM
  #8314
dangerwr's Avatar
Originally Posted by jesperolsen1972
Hi.
I have seen one V3 owner just put on the 2010 front hexes and run the old wheels. No real modification required . . .
dangerwr is offline
Old 11-23-2011, 12:13 PM
  #8315
Team Tekin
Randy_Pike's Avatar
That is correct. If you need to use the older hexes you can sue the original 410 hex and use the original 410 wheels and or Losi front wheels.
Randy_Pike is offline
Old 11-23-2011, 03:45 PM
  #8316
panic-rev's Avatar
Does stormerhobbies or Losipartshouse ever have coupon codes? I can't use anymore at amain, and gotta get a V3 coming soon hopefully.
Thanks if you can provide me a code too!!
panic-rev is offline
Old 11-23-2011, 04:56 PM
  #8317
ajj
ajj's Avatar
Trader Rating: 18 (100%+)
Hi.
Our Aus distributor has stock of white 14mm fronts. I'm pretty sure they ship internationally too.
ajj is offline
Old 11-23-2011, 05:55 PM
  #8318
jmackani's Avatar
Trader Rating: 14 (100%+)
Stormers never does. His theory is if others are offering you a coupon, then they are selling it for too much. Their prices are normally the lowest.
jmackani is offline
Old 11-23-2011, 10:39 PM
  #8319
tobamiester's Avatar
Trader Rating: 360 (100%+)
Tried out the 5mm Mod tonite. The car felt noticeably more stable on power down the straightaway, but didn't really get enough track time to conclusively say how it affected the car in the infield. (Had some mechanical issues in the qualifiers and switched back to stock arms for the mains).
Ran on a small, tight indoor clay track. Hope to get some more track time over the holiday weekend.
tobamiester is offline
Old 11-23-2011, 11:50 PM
  #8320
Trader Rating: 155 (100%+)
I am using 12mm kyosho hexs on the front and back of my 410, ground out the side of a metal hex so I could push the pin through and used 22 hexs on the back
Breeze is offline
Old 11-24-2011, 05:23 AM
  #8321
Chief's Avatar
Any photos of the mod guys? Thanks.
Chief is offline
Old 11-24-2011, 06:07 AM
  #8322
Check out the Tresrey Blog http://tresreyusa.blogspot.com/2011/...t-arm-mod.html
Old 11-24-2011, 09:54 AM
  #8323
Chief's Avatar
Great, Thanks.
Chief is offline
Old 11-24-2011, 11:19 AM
  #8324
Konich's Avatar
Well I tried out the 5mm front arm mod at MHOR tonight and there are a number of pro's and con's to it. Our track is indoor high traction clay with 2 sweepers and 5 180 turns.
Pro's:
-Car is more stable and carried more speed through the two sweepers
-Steering is "dulled down" slight and the car doesn't react to steering inputs as fast, but still turns on a dime.
-More consistant over the whoops section and doesn't seem to get out of shape
Con's:
-Removing 5mm of material make the arms fragile. I tapped a pipe in Q2 while running second and that was it.
-Takes away off-power steering. I may need to adjust my ackerman on the steering plate but running it to the forward position I noticed the car wouldn't turn as tight when I was off power
Right now I'm going to continue to run it with the 5mm mod. I think I may try cutting some arms at 3mm to bring back a little material. I need some more track time with it but initially after running Q1 with standard arms and Q2 and the main with the 5mm arms I like the 5mm mod at this point.
Konich is offline
Old 11-24-2011, 11:30 AM
  #8325
Pro's:
Con's:
Yeah that was a concern for me, once I'd cut away the 5mm, there wasn't alot of supporting plastic left... I'll definitely give it some more track time over the next week or two.
