Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
#8281
#8282
Last question for the day. Does thicker diff oil add resistance, and as a result increase ESC and Motor temps? I have an ongoing debate with another 410 owner.
#8284
#8285
Diff fluid only makes a difference thru the turns allowing the wheels to turn at different rates, the driveline diff to diff never moves so it never puts more of a strain. your diff ring gears still turn straight, any additional load is on the internal diff gears
#8286
Saw your doing pretty good at CRCRC. Whats your setup hotshot?
Anybody got tuning advice for the diffs? How long between rebuilds/fresh fluid? When to go thicker or thinner. My buggy came with 7000front/5000rear.Going to be racing at Raceworld Raceway which is med bite indoor.
Thanx
#8287
Hey Joel
Thanx
Thanx
http://www.petitrc.com/setup/durango...adBradley.html
I have been running, 5k / 3k and like it. I run mostly on tight and technical track. If I were to go to Raceworld, or Leisure. I may bump the fluids up a bit. most likely try Jorns 10k / 10k setup.
#8290
Hey Joel
Thanx
Thanx
The car is dope on the track
setup is this one
http://www.petitrc.com/setup/durango...ay20101201.pdf
#8292
#8294
Ive been running 10/7. Mess around a bit to get there. Just couldnt get the hang of it with the lighter stuff. Car is super easy to drive with 10/7, and with some good orings the fluid really statys nice and clean in there. Very impressed.
setup is this one
setup is this one
