Like Tree22Likes
Old 11-20-2011, 03:21 PM
  #8251
getpip's Avatar
Originally Posted by zipperfoot
Beautifully done. Where do you mount the transponder? Also it appears you routed the servo wire? Mine is on the same side as the servo saver. Not many places to run it without it rubbing on the linkage. The Spektrum micro receiver makes life a lot easier. That thing is small!
Thanks Zipper.
The transponder, an MRT, mounts on the small plate where the switch is mounted in the pic (I move the switch over).
The servo wire is indeed routed under the servo saver, there is a small gap between this and the side guard edge of the side guard where it can sneak through. No problems so far.
I agree the micro rx is great .... don't know why they bother making the big ones?
getpip is offline
Old 11-20-2011, 09:44 PM
  #8252
panic-rev's Avatar
For the few of you that posted on where to get YELLOW FRONT wheels for the 410, thanks!!
So older 410/410r and newer v3 are same rim?
panic-rev is offline
Old 11-20-2011, 09:50 PM
  #8253
dangerwr's Avatar
Originally Posted by panic-rev
For the few of you that posted on where to get YELLOW FRONT whees for the 410, thanks!!
Seriously? I refuse to help people that cannot read down on the same page. No rims for you!
dangerwr is offline
Old 11-20-2011, 09:56 PM
  #8254
panic-rev's Avatar
Danger, I said thanks!! I acknowledged your help man!! I saw the Losi Parts House link. I just don't know if they're all the same rim. 410/410r/v3
Old 11-20-2011, 10:19 PM
  #8255
BennyBagems's Avatar
Trader Rating: 15 (100%+)
My DEX410 on it's way to TQ and A main win yesterday.
BennyBagems is offline
Old 11-20-2011, 10:46 PM
  #8256
dangerwr's Avatar
Words bud! Let me know if I get outta line. V3 has 14mm hexes and all the others have 12mm hexes. Hope that helps a bit. The link I posted is supposedly the new rims and would not surprised if they actually have them in stock 'cause their website sucks and no one in their right mind would find 'em.
Cheers!
dangerwr is offline
Old 11-20-2011, 11:21 PM
  #8257
panic-rev's Avatar
It does!! Thanks!!
Old 11-21-2011, 12:34 AM
  #8258
Trader Rating: 19 (100%+)
I'm jealous you're still racing outside! Nice job man!
Jonny5 is offline
Old 11-21-2011, 12:46 AM
  #8259
Are these the 408 shock seals? Or the Kyosho ones people are using so the difs don't leak? Also, I thought v3 fixed these. You may be talking about something else I realize.
I didn't realize the V3 came with different o-rings, but I have used the updated o-rings in the past. They do work better than the original x-rings.
I was referring to the Tresrey P5 o-rings, but yes Kyosho also makes them- I'm pretty sure that P5 is the size of the o-ring in Japan where both Tresrey and Kyosho are made. We have been getting some great life out of the Tresrey P5's, about two months with oil changes every two racedays.
Jonny5 is offline
Old 11-21-2011, 05:17 AM
  #8260
ajj
ajj's Avatar
Trader Rating: 18 (100%+)
You're welcome to relocate to the southern hemisphere with us for our beautiful summer!
ajj is offline
Old 11-21-2011, 06:44 AM
  #8261
tobamiester's Avatar
Trader Rating: 360 (100%+)
Originally Posted by Konich
Tresrey Japan experimented with moving the front arms 5mm forward during Japan Nationals this past weekend (see pics)
Apparently it gave a little better stability and smoothed out the steering due to the geometry changes.
DISCUSS
Read about this last night on your blog. Going to get out the Dremel and make a set of these and hopefully test them Wednesday.
tobamiester is offline
Old 11-21-2011, 06:49 AM
  #8262
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Please do, interested to see the results. Also let us know if you change the Ackerman position. I run mine back. Thanks.
Bman's 3XNT is offline
Old 11-21-2011, 07:49 AM
  #8263
Cheers!
Hmm.. My 2010 spec has 10mm or 9.75mm front hexes.
ridgeracer is offline
Old 11-21-2011, 08:52 AM
  #8264
gene1219's Avatar
Trader Rating: 16 (100%+)
I wrapped the top half of my chassis with some textured vinyl wrap I got from autozone to mimic the look of a carbon fiber chassis. I tried it on the bottom of my 22 and due to the texture and how thin it is, it didn't hold up. So, I just did the top on the 'rango to give it a little bling! I stripped a plastic servo arm so that is why no servo is shown
I wrapped the goofy looking gensace packs. All though the vinyl is super thin, it made the packs a little hard to fit in the chassis
gene1219 is offline
Old 11-21-2011, 11:45 AM
  #8265
panic-rev's Avatar
That looks pretty dang sweet. Great blingy project .
