Like Tree22Likes
Old 11-14-2011, 12:17 PM
  #8131
Trader Rating: 19 (100%+)
Originally Posted by gene1219
awesome! Thank you. I don't know when I'll get it, but it just looks so cool.
Gene- Cush is running the Tresrey CF chassis (I believe it was a joint project with 8Racing) with great success. He shaved a half second off his laps at Leisure Hours and feels that the car is more planted through the corners. Its pricey but a good investment for the buggy. Plus it looks dialed!
Jonny5 is offline
Old 11-14-2011, 12:21 PM
  #8132
dangerwr's Avatar
Default Need your help. What is the difference?
Could someone please tell me the difference between these parts?
http://www.amainhobbies.com/product_...iddle-Bulkhead
http://www.amainhobbies.com/product_...ive-Gear-Plate
dangerwr is offline
Old 11-14-2011, 12:47 PM
  #8133
t8rtot's Avatar
Trader Rating: 14 (94%+)
the latter is the old 23.5mm piece. i believe
t8rtot is offline
Old 11-14-2011, 12:52 PM
  #8134
gene1219's Avatar
Trader Rating: 16 (100%+)
When we raced at Streamwood last month, his car appeared to handle extremely well. The most important thing is that carbon fiber makes any car DIALED!
gene1219 is offline
Old 11-14-2011, 12:55 PM
  #8135
dangerwr's Avatar
Thanks! That would make sense. I just saw they have two different motor plates and the one that came on the "R" version was considered an option for the 2010 Spec car--must be the whole 25mm thing.
dangerwr is offline
Old 11-14-2011, 02:39 PM
  #8136
Trader Rating: 125 (100%+)
2 NIP Left & Right Alum side plates in F/S section...pm me
kwiksi is offline
Old 11-14-2011, 03:44 PM
  #8137
dangerwr's Avatar
Anybody know if the stock dark blue/light blue springs that come on the BB are an decent place to start? All the setups on TD for the V3 are in Europe on cork or carpet surfaces. WTH?? Thanks!
dangerwr is offline
Old 11-14-2011, 03:55 PM
  #8138
Depends what you were using before with the small bores (or is it regular bores..?). The rates are nearly identical between the stock and big bore springs, and your desired spring rate should not be too far off of what you were running before. What I'm anxious to see is if we are able to gain considerable pack without increasing the low speed damping. Cush's car now handles very well but has a tendency to chassis slap if he overshoots a downside. Reducing this will help him out considerably.
Jonny5 is offline
Old 11-14-2011, 03:59 PM
  #8139
Konich's Avatar
Danger,
That is what Justin and I are using on the BB. Look at his setup sheet on the website for piston/shock oil info.
23 LAPS SON!
Konich is offline
Old 11-14-2011, 04:12 PM
  #8140
majorsmx521's Avatar
Trader Rating: 44 (100%+)
try 1.2x4 piston front 35 wt oil dark red spring/dark blue spring
1.3 x 6 32.5 wt rear with light green or light blue spring
i may try 1.3x5 pistons in rear
just fyi looking forward to guys helping on this bb set up thing?
1/8 track to very tight indoor that as a base has been pretty close
hope randy pike and the fast guys have been testing so we can use that knowledge
i run in a kyosho house track need lotsa help!!
majorsmx521 is offline
Old 11-14-2011, 04:19 PM
  #8141
dangerwr's Avatar
Originally Posted by Konich
Danger,
23 LAPS SON!
I got 23 laps? Nice! I assume you mean the Tresrey website so I will do take a look . . .
dangerwr is offline
Old 11-14-2011, 04:59 PM
  #8142
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Guys, I don't play with bumpsteer or ackerman much. So what would give the smoothest steering? Ackerman front/middle or rear hole? Also bump in or bump out? Thanks........
Bman's 3XNT is offline
Old 11-15-2011, 06:09 AM
  #8143
Anyone?
Old 11-15-2011, 06:10 AM
  #8144
I run one step softer F/R. I believe Dark Green Front, and Lt. Green Rear just like the standard size shocks.
Old 11-15-2011, 07:53 AM
  #8145
Konich's Avatar
I run mine in the middle on my DEX410/DESC410 and found for my setup that gives me the best steering response versus the other 2 positions. It gives me good turn in but I find in the middle of the turn the car turns on a dime as our track is pretty small and tight so it works well.
Here is a vid of our track. My car is dead last, but two laps in I get to second (where I finish) and you can see my Durango seems to be the best handling Also turned the fastest lap of the night in 4WD as well.
http://www.youtube.com/user/MHORRC#p/u/4/086qwUY635Y
Konich is offline
